I got a new work bench.
Discussion in 'The Antiquated' started by Bruce Fischer, Jul 13, 2022.
  1. alanp561
    alanp561
    That engine stand idea is just ***s. Doesn't take up a large footprint in the shop and can go somewhere out of the way when you're not using it. Really clever idea.
    ekimneirbo and Bruce Fischer like this.
  2. 5window
    5window
    When I built my shop, steel was affordable so my bench top is 1/4" plate. No dents so far.
    VANDENPLAS and Bruce Fischer like this.
  3. Sky Six
    Sky Six
    from Arizona
    Jeez Louise, I would hope not!!!!:rolleyes:
    catdad49, Bruce Fischer and 5window like this.
  4. I really like your set up. Bruce.
    ekimneirbo likes this.
  5. I am going to add more L E D lights and insulation but nothing fancy with the floor. Thanks.
    Okie Pete likes this.
  6. NICE!
    Sky Six likes this.
  7. Thanks!
  8. Ziggster
    Ziggster
    My “work” bench for most part since my other OT project had occupied my garage. Lol!
  9. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Just in case anyone decides to make a similar bench with engine stand. You need a substantial bench to begin with so that it doesn't tip forward. This is a bench I built about 40 years ago out of 2x6s and plywood......because I could not afford new stuff. Actually I like it better than metal ones. Its 16 ft long and full of car parts. The engine stand mount sticks all the way thru the bench so its not trying to support all that weight with just the front 2x6. I also made a "leg" that goes between the bench and the mount to give a bunch of extra support for when I have a complete engine on it.
    What I would like to point out here is the "topical" approach I try to use in each area of my shop. Thats what I was trying to suggest when I mentioned using fans rather than A/C to stay cool. If everyone looks at the picture closely, you can see that I have "small" fans positioned to provide a breeze at the places where I'm likely to be working. I find that if I'm working hard, I'll sweat even in an A/C building, but the fans keep me nice and cool most of the time. I tried one of those giant fans one time. Hated that thing. Took up too much space, made an irritating wind noise, and blew way too hard. Sold it......
    I do have a couple industrial (round) fans mounted on poles for my crane that I can swivel easily. The trick is to put the fans where they are out of the way and don't blow too hard. I'll repost my shop pictures and also one of my son's shop showing a fan on a crane upright. Its pointed right where work will be done if using the lift. Another was mounted on the other pole after this picture was taken.
    Another thing I'm a big "fan" of is cranes in a shop. They just make everything so much easier and buying used steel keeps the cost down. Again, I try to put things where they are the most convenient and effective. So thats my point, plan your shop out and put things in strategic positions so they work well for you. The small crane in my shop picture makes it easy to lift an engine and install it on the stand.......but it also lets me lift things onto carts or either workbench. Simple little 4" I-beam with upright legs attached to the floor and walls. Probably $150 and another $100 for the trolley and comealong.
    Anyway, hope this gives you some ideas, as this really works well for me, as I find a light breeze from a slow fan keeps me cool better than a marginal temp A/C when you are trying not too spend too much money on the electric bill. The A/C will often provide plenty of cooling if you crank it down, not saying it won't, but a fan provides immediate cooling at a reasonable cost. Just gotta install them in the right places.
    (Oops! Kinda got the workbench thread and the shop cooling thread mixed together)o_O
    I was talking to my son the other night. His "pole barn" in the picture is well insulated and has stud walls. The original owner was a builder who made it really nice. Got divorced and now my son owns it. It is air conditioned (and has a real bathroom :D). I asked him about how much he uses the A/C. Said he doesn't use it other than to cycle it for a little bit in the summer. Its a heat pump, so he does use that in the winter.
  10. Oldtmtech
    Oldtmtech
    My dad’s old welding “table “ a press die lots of threaded holes and t slots for holding things 15A1BE44-D2BC-40F1-A7C2-B66427825C40.jpeg 8CB385E2-F0D6-453F-9F6E-90CAF76FA1D0.jpeg DD8FE0F0-41E0-4C45-8C49-1405B749C9A9.jpeg B7109592-8BB6-4213-BEC1-40176E37155A.jpeg 5FD3616A-7B61-4508-BE36-399DEA80AACD.jpeg
    Okie Pete and tractorguy like this.
  11. Okie Pete
    Okie Pete
    D7E42FEB-F376-4D12-B5DD-D667032E1A37.jpeg E0C5DB33-5F12-483E-A0AD-9610220DB058.jpeg Half of a Moline industrial table saw table that I bought from a estate sale . I wasn’t happy with the legs under it so I made another set with wheels to be able to move it around.
  12. woodbutcher
    woodbutcher
    :D Hi Bruce.Good to see you back.
    Good luck.Have fun.Be safe.
    Leo
  13. Dave G in Gansevoort
    from Upstate NY
    Hey I got a new bench again today! I cleaned up the old one again... I didn't remember painting it, but it's a different color than I remember. Oh wait, that's dirt!
