Technical ***July 2022 - May You Be Lucky***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2022.
  1. panhead_pete
    panhead_pete
    That's a load off, thanks! Its silly of me as never noticed it before even though have spent quite a bit of time under the car. Cheers!
    Outback and 282doorUK like this.
  2. joemac05
    joemac05
  3. So
    This is a solution,
    that has so far prevented this, which happens to be a **** crank
  4. 5280A2
    5280A2
    Yes, the combination running with those two crankshafts included lightened and balanced flywheel and clutch ***emblies. I believe the cause of the breakage was excessive spark advance, the set-up running at that time had about 30 degrees of total advance.
    My solution was a new Burlington crank, steel main caps, inserts and pressure oil to the mains. Ten years later it's still running and taking some occasional abuse.
    Dustyp489, brjnelson, Jet96 and 3 others like this.
  5. joemac05
    joemac05
    Thanks for the reply, I will let him know.....
    Outback likes this.
  6. Crazydaddyo
    Crazydaddyo
    There really isn't a rear main seal. Is your engine modified for oil pressure? If so then the oil from the rear main is being forced out of the rear main past the oil slinger that was stock. If you have a B engine, then the fix is to install the after market oil seal that is available from the Model A parts houses.
    If your engine is not modified for pressure, then you may have a plugged rear main drain pipe, or have to much blow by creating too much crank case pressure forcing oil out the rear bearing.
    Dustyp489, Old Dawg and panhead_pete like this.
  7. panhead_pete
    panhead_pete
  8. Friends, can anyone identify this?
    I know it's somewhat related to the "SM" Smiley Martin Magneto Drives, but this one is a little odd.
    It's got a drive, but there isn't a base to mount a mag.
    Leaving me puzzled, I'm curious.... What would this be used for?
    Barrelnose pickup likes this.
  9. Outback
    Outback
    from NE Vic, Oz
    Does the shaft have a key way? It looks parallel?
    Maybe it is for some type of coupling or auxiliary drive for something? ?
  10. It could most definitely be an aux drive. As far as the shaft, there is no keyway and the hole isn't threaded.
    I'm considering reproducing some shaft driven water pumps, and might run this with them. Screen Shot 2022-07-17 at 8.41.00 AM.png
  11. Water pump would be a good thing, it addresses part of the inadequate cooling system in the "A/B".
    The fact that there is no key would lead me to believe it is for a magneto, using a clamping collar for timing.
    It's all good, keep it up!
    J
    Old Dawg likes this.
  12. Full ***embly
    Outback, Jet96, Old Dawg and 2 others like this.
  13. I think the water pump could be pretty cool. My friend, @chevahaulic took a Chevy 216 pump and adapted it. Apparently the flow of water was backwards.
    I'm working on this, despite being super rough. Plan is to start cleaning it up, and possible 3D print it for mockup. I'm hoping to have it setup for a Wico X mag or Bosche MJC. untitled.png
  14. Stovebolt
    Stovebolt
    Seems as though this email address may not correct.
    Can anyone verify this for me?
    29 Speedster and Old Dawg like this.
  15. Airborne34
    Airborne34
    from Texas
    Does anyone have the directions to FAB the throttle Pivot Arm that is used with aftermarket manifolds. I have the Riley Downdraft aka Equalizer.
    Used to be a PDF floating out there.
    Thanks
  16. V4F
    V4F
    from middle ca.
    John , you have the best toy's
    Outback likes this.
  17. Steve,
    Yeah, I wish, I am just doing some work on it for Bonneville.
    It is going in the 4E4 tank, turbo and fuel. One of the first 5 main girdles I ever did.
    J
    Outback likes this.
  18. V4F
    V4F
    from middle ca.
    i read where the salt is bad this year . bummer
  19. We will not know until we get there.
    Usually, the online chatter is "It's the best we have ever seen" until you arrive.
    Couple years ago, it was like soup, car stayed in the trailer, my liver did get a work out though...
    J
    Retson,
    Yes, keep building on this platform. Only comment, make the pad larger to fit a rectangular pump flange.
    John
    Outback, 4bangerbob and raaf like this.
  21. Fabber McGee
    Fabber McGee
    Perhaps a mounting pad in front of the accessory gear too, then something could be driven off the front of it. It would be easy enough to remove some metal and smooth it over if someone didn't like the looks of the extra metal.
  22. Stan Back
    Stan Back
    "We will not know until we get there.
    Couple years ago, it was like soup, car stayed in the trailer, my liver did get a work out though..."
    "It's the best we have ever seen" -- said the rookies.
    "Couple years ago, it was like soup, car stayed in the trailer . . ." -- We weren't that smart, but we did set a record. Logged 4 miles getting to the 3.
    Old Dawg, Outback and Dustyp489 like this.
  23. Stan
    How many spin revolutions does it take to go a mile? Got that Martini driver still?
    I missed the stuffing party, work you know, or don’t
    John
  24. Stan Back
    Stan Back
    Nah -- sold the roadster after 57 years. Great new owner that knows and appreciates its history. The Martini guy just drove his banger roadster from Arizona to Montana, allegedly cruising at 70 mph on the way. The two of you musta figured it out.
    Old Dawg, Dustyp489 and Outback like this.
  25. Rocky
    Rocky
    Classified Editor
    My 30 closed cab is still stolen.....sigh.
    Outback likes this.
  26. Crazydaddyo
    Crazydaddyo
    John,
    Is this a wet or dry sump set up? There doesn't look like there is any plumbing for an external oil sump.
  27. Definitely will do! At the end of the day, I'm just a kid learning CAD!
    Here's what I've made so far. It's quite rough, but I'm still getting the hang of it.
    I'm considering having it secured with some longer oil pan bolts, which I feel might help with rigidity since it kicks out to clear the oil return tube.
  28. That’s good to know, it is the enthusiasm that needs to continue. I watch so many collections just dumped by the surviving families.
    I think of it as being a curator in the history of these cars and working on p***ing it down to Owen.
    That’s great Martini is in Montana, don’t tell him the warranty ended at the end of my driveway.
    John
    Old Dawg, Jet96 and Outback like this.
  29. CDO
    This is wet sump only single stage pump
    I typically run belt drive on dry sump ***y
    The pump would stick out pretty far
  30. Outback
    Outback
    from NE Vic, Oz
    That sux
