Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. aussie57wag
    aussie57wag
    from australia
    A simple solution. Don't build a shop from wood. A steel framed and walled shop won't burn.
    das858 and Boneyard51 like this.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Gizzy, seb fontana and Cgrgrspt10 like this.
  3. RICH B
    RICH B
    The stuff inside will burn causing the steel trusses will warp and pull the walls in, and take the roof down.
    Need block or brick walls and wooden trusses or bar joists; the wood can burn and fall in without pulling the walls down.
    Jet96 and aussie57wag like this.
  4. The best and safest is heavy timber construction with sprinkler system.
    klawockvet and clem like this.
  5. choptop40
    choptop40
    good to know as my new shop is cinderblock and wooden roof....
  6. twenty8
    twenty8
    Sorry, But his name was Burt Munro.
    Just had to correct this for Burt's sake. He is a hero of mine.
  7. Six Ball
    Six Ball
    from Nevada
    As someone who's name is misspelled by over 90% of the people who try it I should have been more careful. Sorry Burt! :(
    Jet96, fauj and twenty8 like this.
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Having had a couple of thieves visit my shop some years ago, I'll say that one of the best things you can do is to take pictures of all your stuff and save it in a folder on your computer along with scanning any receipts you have. That way you always know where to find them when something bad happens.
    clem and Six Ball like this.
  9. b-body-bob
    b-body-bob
    I fold the edge of the tape under (if I remember). I would just lose those bread bag clips and spend more time searching for them than I save by not having to search for the end of the tape roll.
    X-cpe, ekimneirbo, Bugguts and 4 others like this.
  10. Boneyard51
    Boneyard51
    We had a Continental Trailways bus barn burn here in Muskogee that was build years ago with steel framing. It had several layers of roofing on it and years of diesel fumes in the rafters. Absolutely could not put it out! Burnt to the ground!
    Bones
  11. Six Ball
    Six Ball
    from Nevada
    The only thing here that seems to be fireproof is the wood I'm trying to light in the stove. Too late to change the house & shop now.
    reagen and Algoma56 like this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Haven't seemed to be able to read all of this thread. Pardon please if its repe***ive.
    Tried to share, without much success in the past.
    When replacing front shocks on a car with A frame suspension and the top stud nut won't let go. The stud just turns freely. To conquer this simply find the tightest fitting deep socket and a long 1/2 inch extension ( use adapter if socket happens to be 3/8 ).
    Now simply grasp the extension with both hands, push and pull back and forth. keep increasing the distance. The shaft stud will break away.
    Done.
    The same is true for a wheel lug stud that spins in the axle. ( usually a combo of crossed thread and corrosion ) Any socket short or long. Half inch Extension Longer heavy pipe ( jack handle ).
    Swing the pipe to and fro on the same plane.
    Once the stud gets hot.
    Done.... Just poke the piece left in the axle out. There's nothing holding it.
    das858, Bugguts, rod noken and 2 others like this.
  13. atch
    atch
    I was helping a friend ***emble his engine yesterday and he was using Tygon tubing pieces to do this. We've all got some kind of tubing laying around that we can cut a couple of 2" pieces off of.
    Boneyard51, osage orange and fauj like this.
  14. This dashboard has really thin decorative aluminium strips and of the 16 tiny clips that slide into the strips to fasten them i only had 6 clips. A blob of solder from the inside would only melt the paint . So i spaced the 6 clips out and fastened everything down with tie strips . Then mixed up some JB Weld and forced it into the aluminium strips from behind with a small kitchen knife. A day later and solid as a rock.
    X-cpe, Jet96, Todd Wallin and 17 others like this.
  15. Boneyard51
    Boneyard51
    I use gas hose to put pistons in, but I use more than two inches. I take a length of hose and run it up from under the engine , around the crank throw, and up through the cylinder then push it on the rod bolts. This makes a loop and guides the rod on for me. Just easier way for me!
    Bones
    fredb, ekimneirbo, b-body-bob and 5 others like this.
  16. blowby
    blowby
    from Nicasio Ca
    Stopped by to help a friend with a clutch adjustment today, and was rewarded with a gallon of tricloroethane, some kind of solvent, he's a retired elevator mechanic. Anyone heard of this stuff? Is he trying to poison me? He also gave me some Slick 50, so maybe he trying to do me harm.;)
  17. blue 49
    blue 49
    from Iowa
    Dry cleaning fluid?
    Gary
    seb fontana likes this.
  18. Mart
    Mart
    ^^Just a couple of posts above it mentions using gas hose to put over the con rod bolts to protect the crank journals while fitting the pistons. On a flathead this might not be possible depending on the bore size and other factors.
    I did use some heat shrink tubing though, which was a close fit and much thinner wall. Some is naturally flat when unheated and that can be a help. Just mentioning it in case anyone else has a situation where conventional tubing is too thick.
    Doublepumper likes this.
  19. impala4speed
    impala4speed
    I believe that Trichloroethane was used as a solvent but either is being phased out, or has already been phased out, due to its ozone-depleting and cancer-causing properties. Must be some pretty old stuff ya got there. Be careful with it.
    seb fontana and blowby like this.
  20. phat rat
    phat rat
    Take the "Be careful" warning to heart that's some wicked **** if you breath in too many of the fumes. Years ago at work the used it for degreasing parts and the guy who was the regular degrease operator ended up with health problems. When he'd been off the job for a few months he started looking a lot better
    blowby likes this.
  21. blowby
    blowby
    from Nicasio Ca
    Thanks guys. I hope one big whiff won't hurt, 'cause that's the first thing I did. :oops:
    WalkerMD and RICH B like this.
  22. mohr hp
    mohr hp
    from Georgia
    In the aviation world, we called it "trike". It's a degreaser, and yes, it's long gone, very effective, and causes cancer in California and everywhere else. I wouldn't be afraid to use it, because you won't have years of exposure to wreck your internal organs. But don't let the neighbor's kid go huffing it!
    scotty t likes this.
  23. jetnow1
    jetnow1
    from CT
    Years ago I had a house that the well tested for that ****, the chemist who ****yzed the water told me the fact we drank it while finishing the house was not good, but the real danger was breathing it, ir steam from the shower, dishwasher etc. Bad stuff, found out later the adjacent property the owner had been burying metal machining s****
    from Pratt and Whitney. Had to install activated carbon filters on the water for the house.
  24. blowby
    blowby
    from Nicasio Ca
    Last weekend I borrowed a floor jack while on the road. One of those lightweight aluminum jobs, carried it across a parking lot. In addition to being a breeze to maneuver into position, it had a fast pump that brought it up to the car frame in one or two pumps. In comparison, my floor jacks, all decades old, would break my back to carry around, and don't have the fast pump. Maybe time to upgrade..
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @blowby,
    I've been thinking about this too. Do you remember what brand it was?
    Six Ball likes this.
  26. Yes please post, with any comments on it. I've been thinking about quicker jack, as my shoulders are taking a beating pumping the handle as it's usually so close to the ground. Most of the jack is under the car, reaching to the rear end housing.
  27. blowby
    blowby
    from Nicasio Ca
    Sorry no, it was at night. It was light enough it even had a carrying handle on the side, and the jack handle came off with a thumb screw. It was bigger than the typical old mini floor jacks. It was anodized purple..:)
  28. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I bought 2 of those and put one in each of my daily drivers. PITA to deal with a factory jack, and most of them are not well designed. Believe I paid about $99 or so at Harbor Freight. Hate to buy Chinese, but where ever you get one, its probably made in China. Be glad when they start putting high tariffs on all the Chinese stuff and "encourage" companies to manufacture stuff here again.
    56don, reagen, Six Ball and 2 others like this.
  29. b-body-bob
    b-body-bob
    FWIW I've got a harbor freight light weight jack that struggles to lift anything. It's handy when I need to carry it but useless in the garage where I've got a real jack.
    klawockvet and vtx1800 like this.
  30. Almostdone
    Almostdone
    Need more vacuum ports or want to hide them - No problem! I drilled holes in one steel tube and soldered the smaller steel tube pieces into them - done deal. The tubing was steel fuel and brake line. About 4000 miles so far, no leaks.
    First pic shows the prototype, second the real deal prior to tidying things up.
    John
    7DE1A8BD-3F31-4453-8AB0-0E66A22962E3.jpeg 51ED855C-82AE-4CB4-AA13-2B51B67933B1.jpeg
    X-cpe, mario711, olscrounger and 17 others like this.
