Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. mad mikey
    mad mikey
    Gary. As Root stated, high build primer is your friend. Looking good buddy.:)
    Stogy and Just Gary like this.
  2. I always thought it sanding, sanding, even more sanding and then a dose of your favorite adult beverage. Lol
    Stogy, lothiandon1940, ol55 and 2 others like this.
  3. Just Gary
    Just Gary
    I screwed up.
    In hot weather, body filler jumps from honey-smooth to flaming-hot-oatmeal in nanoseconds. On a 93*F afternoon a few weeks ago, I reduced the amount of catalyst in one batch to compensate. When sanding it a few days later, I marked some low spots with a pencil and the point sank into the filler like play-dough! :eek:
    After calming down, I gouged out all the soft filler & ground the surrounding area down to a rock-hard layer...
    ...then re-filled it and checked (pencil-poked) the whole car. Fortunately, that was the only bad spot.
    Pushing forward:
    A smear of filler in each remaining low, then #120 on a 16" Dura-Block 'til the guidecoat disappeared.
    @Dino 64 dropped by to offer encouragement and discovered a couple of flaws that my hands (or ego :oops:) p***ed over.
    So I did them again.
    Yeah- I'm finally finished with filler & #120 and celebrating .:D
    But first I'm trying some glaze in the pits & pinholes.
    shortypu, Joe Blow, Stogy and 8 others like this.
  4. Dino 64
    Dino 64
    from Virginia
    Must have been a strange sight to see the two of us gently running our hands over the body with a far out glazed look on our faces:eek::D:D.
    Just have to see with your hands !!
    Great job :):)
  5. swade41
    swade41
    from Buffalo,NY
    Just like polishing valve covers, you'll be a pro after a thousand hrs in ha ha ha
  6. mad mikey
    mad mikey
    Looks real nice Gary. Sometimes a extra set of hands and eyes is all it takes. Good job Dino.:)
  7. catdad49
    catdad49
    As long as you weren't chanting, but I sure would love to see a video of it!
  8. 1971BB427
    1971BB427
    from Oregon
    For those of us not blessed to own a climate controlled work shop, the issues of too hot and too cold can be very frustrating. When I was doing both filler and paint I had to sometimes wait a long time to find days that weren't too hot, or too cold to be able to proceed forward and know I wasn't messing up the process by pushing through temps outside the range for good results.
  9. ol55
    ol55
    from Virginia
    Looks great!
    Stogy, Dino 64 and Just Gary like this.
  10. Just Gary
    Just Gary
    My first spraying attempt beyond 16 oz. rattle cans:
    TAMCO HP5310 Direct-To-Anything high-build epoxy primer:
    <DTM Primers Kit | Tamco Paint Products >
    This ***an Vaper HVLP gun with a 2.3 tip earned great reviews at Summit.
    Full suit & mask with fresh charcoal filters 'cuz I'm no longer immortal.;)
    Box fans & filters on inlet side (1) Push clean air in, (2) Maintain positive pressure to keep dust out, and (3) Eliminate exhaust explosion risk.:eek:
    Exhaust filters contain any overspray.
    Sunny skies, mid-70s, 50% humidity, 5-10 knot breeze.
    Everything got cleaned with wax/grease remover (twice) then dusted with a tack rag.
    I suited up, set the compressor regulator at 75 psi, and rehe****d my gun/hose/stepstool/body panel "dance sequence".
    A little over a half gallon of primer and hardener got mixed 4:1. I chose not to add the reducer.
    I set the gun regulator to 28 psi with the trigger pulled. I'm left-handed and kept bumping the fan knob with my knuckle after tuning the spray pattern.
    Three coats, 50% overlap, and ~15 min flash time between coats.
    Shut the door and let it dry.
    Lessons Learned:
    Practice
    , practice, practice!
    TAMCO primer seems a great product at a reasonable price ($174 for the kit). The finish is a bit rough- Not adding reducer sacrificed flowout for higher film build. It'll get sanded anyway.
    The gun sprayed very well but its regulator was trash.:mad: I resorted to tuning gun pressure (~33 psi) with the compressor regulator. I also made a mess while pouring, so cleanup took a LONG time.
    The compressor was sufficient; it cycled a lot but that didn't seem to matter. I cracked its drain during flash times.
    The disposable inline filter worked well- no detectable water, oil, or fisheyes. But its length made spraying the bottom edges challenging.
    The booth was great.:) A bit cozy and the inside temp warmed up ~15* above outside. Its framework was too flimsy to hang the doors, so next time I'll lay them on sawhorses.
    The fan/filter combo worked OK but they really weren't stress-tested. There was very little overspray inside the booth & none outside; so Wifey & the lawn are both happy. :D
    This was a gun, compressor, booth, ap***ude "proof-of-concept" exercise just as much as priming sheetmetal.
    Overall I'm thrilled with the results.:)
    Thanks to @Roothawg, @Gearhead Graphics and @Bill's Auto Works for their TAMCO spraying advice.:cool:
  11. Dino 64
    Dino 64
    from Virginia
    Great job Gary !! :):)
    OK, party’s over, back to sanding :eek::rolleyes:;)
  12. dalesnyder
    dalesnyder
    3E30B9E6-8021-4880-B790-B43DAF92ED2E.jpeg B16052BA-7F19-4B61-B8DF-9052D0180F69.jpeg 71BF0FCB-025C-48D4-AB5C-2D3006923301.jpeg This is my project , it’s like we’re in parallel universes or something.. a tad scary. I’m aiming for spraying color tomorrow.
  13. ol55
    ol55
    from Virginia
    Looks fantastic!
    Stogy, mad mikey and Just Gary like this.
  14. Awesome @Just Gary !
    For a first time with all the new variables, you did fine!
    A couple of things : the cheap regulators that come with the cheap guns are well...CHEAP! I have 4 or 5 of them laying around, I don't know why I keep thinking they will work better next time:D
    I always use 10% reducer in the 5300 series as it will flow easier & with the level of build it has you will not sacrifice any with that much reducer. No problem though as you said...you are willing to do the sanding & that is really all the reducer does is save you sanding time!
    Lastly if you were going to do much paint work, put a good in line filter somewhere closer to the booth than the compressor & throw away that filter at the gun! More paint jobs have been botched by hitting that damn thing on the floor or someplace on the car itself!
    Congratulations!!!
    God bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  15. catdad49
    catdad49
    Are you selling those spray booth kits?!
  16. Tim
    Tim
    from KCMO
    Great idea! Looks wild in one color! Livin the dream haha
  17. mad mikey
    mad mikey
    A job very well done Gary, looks great. One step closer to a finished hot rod.:) Congratulations buddy.
  18. @Just Gary ,
    I forgot one comment in my previous post, I know that picture of the dis***embled gun was for me!:D Glad you took that advise, many times the price or name of the gun has less to do with the quality of the job, than making sure you clean it properly for next time!
    By the way...to ensure a gl*** smooth paint job in the end, I would offer you the opportunity to come visit me for a "Block Party" ...Not what most would think! I have an OT Toro here that has been sitting in paint & 3 coats of high solids clear for almost a year that you could practice on!!!!:rolleyes::rolleyes: By the time you did a round of 800/1200/1500/2000/2500 & 3000, you would be an expert!
    God Bless
    Bill
    lothiandon1940 and Just Gary like this.
  19. Just Gary
    Just Gary
    1) Yeah- I tossed that regulator in the trash the next day when putting everything away.:rolleyes:
    2) I gotta have filtration somewhere. I'll look into other options.:)
    No- but the Coleman Camping Store does.:p
    Thanks, guys!
  20. Just Gary
    Just Gary
    Took a break from bodywork to finish weld the last few brackets.
    And detail the drivetrain.
    More rustoleum flat antique nickel metallic.
    I'd already sprayed it on the front wheels because it matches the ET III rear wheels' paint. :)
  21. Tim
    Tim
    from KCMO
  22. caprockfabshop
    caprockfabshop
    Looking great Gary!
    ~Peter
    Stogy, Just Gary and mad mikey like this.
  23. mad mikey
    mad mikey
    Very nice Gary, everything looks great painted.
  24. Stock Racer
    Stock Racer
    Can't believe I just now found this thread. Great build and nice work! Subscribed
    Stogy, lothiandon1940 and Just Gary like this.
  25. TFoch
    TFoch
    Lookin' great!
  26. Roothawg
    Roothawg
    Great progress Gary!
  27. brEad
    brEad
    That's a great shade of silver (nickel) paint! Thanks for sharing it.
  28. Just Gary
    Just Gary
  29. Tim
    Tim
    from KCMO
  30. mad mikey
    mad mikey
    Nice. You gotta love those valve covers.:)
