Hot Rods Nature Abhors a Vacuum, Or, The Hemi A Roadster fills a void.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jul 18, 2020.
  1. flynbrian48
    flynbrian48
    Christmas in July! Radiator support rods in polished stainless, and a beautiful '32 radiator cap and bezel arrived, and of course I got them unboxed and on the car. I like how the radiator cap and it's bezel compliment the peak on the windshield. It looks great.
    In other news, the overflow tank is ****oned down, and I took care of the awkward terminal strips and wires on the radiator shell I tucked in a little better. I made gas tank retainer clips from conduit clamps and some little bits of rubber fuel line. The tank sets on a wood riser on the wood floor, resting on the tank lip. It looks tidy, although I'm now thinking that straps made of polished stainless might look nice on the painted tank, and be a little more secure in the event of a collision. 3E936D70-C41C-4D07-9773-C6274D5F6CC8.jpeg D2C5C412-EB77-4863-B619-22AB2C61D820.jpeg EE1EA44D-F93D-4AA7-9D87-1C865DF5171A.jpeg 2B0A7CB4-E64B-41FA-8E74-8A80F787CD0F.jpeg
    Stogy, winduptoy, brEad and 6 others like this.
  2. charleyw
    charleyw
    ^^^^^For a minute there I thought it was hovering!, the stands sorta blend in. Nice work by the way.
  3. flynbrian48
    flynbrian48
    Haha, they do, don't they? I made those things at least 45 years ago, they've been pretty handy.
    Stogy likes this.
  4. Bandit Billy
    Bandit Billy
    Why does the front of your car look like Marty Feldman?
    '28phonebooth likes this.
  5. j hansen
    j hansen
  6. flynbrian48
    flynbrian48
    I polished the windshield frame this morning. Now I can get gl*** cut and get the thing mounted, which means I have to drill holes in the cowl to bolt it in. Which means I'll probably drill holes in the wrong place... C71E9BBD-0996-4DFB-9780-C8E9D4BD8210.jpeg 73B87A05-EE07-434D-82CB-A1F28B3CD994.jpeg 4065A929-213A-4F28-9B9C-10936DB89DB7.jpeg
    Stogy, bchctybob, rockable and 4 others like this.
  7. Dick Stevens
    Dick Stevens
    I would have thought you would have drilled them before you painted it.
    Stogy likes this.
  8. flynbrian48
    flynbrian48
    One would think, wouldn't one? :p On the plus side, there's a reveal on the cowl that I had to make to meet the w/s frame, the mounting studs in the frame will go through that, so, unless I'm REALLY off, a wrong one will be covered by the frame and the little gasket between body and w/s frame.
    Stogy likes this.
  9. flynbrian48
    flynbrian48
    Lots done today! Front end alignment done, and the front and rear axles squared to the frame and each other. They were about 1/4" out from each other. I gave it 3/16" toe, and clocked the wheel where I want it. Still can't see the gauges through it, a 3 spoke wheel would have been better for that, but oh well. I got the air cleaner finished, decided to use the small chrome one I bought last summer at a swap meet that looks like a Snellings and Hellings, still had to make some relief holes to clear the radiator support rods, but it looks really cool. 2030A99A-C448-4821-A9D7-B9B8D7DD3C06.jpeg 7805CF89-6529-4365-B91D-D09EA82937DC.jpeg 29526E1B-57CE-4F20-B5EC-AA7AD05E280D.jpeg 1D92FE60-5AF2-4749-BAAB-AAC753C53EA9.jpeg
  10. flynbrian48
    flynbrian48
    I FINALLY got the fuel filler hose made and connected the tank to the Crafty B gas cap. I ended up having to braze the filler pipe pieces together, I had to **** them together after t******* each to get the angle right. It's made from a s**** of exhaust tubing bend I had and 2" to 2 1/2" adaptor. The rubber hose has a wire reinforcement which made it very difficult to clamp onto the tank neck, as it was a little less than 2 1/2" OD, but I got it. I'd thought I'd get the brakes bled, but this, and correcting the mount for the coolant recovery tank (the fan would have hit it the way I had it) took all afternoon.
    4CD8A0F1-AFBE-41CB-9B8A-7799ADD30F2A.jpeg F70A3B66-8D9E-4ECC-937C-76F791187F7D.jpeg
    GordonC, Stogy, brEad and 5 others like this.
  11. flynbrian48
    flynbrian48
  12. Bandit Billy
    Bandit Billy
    Looking good Brian! You make fast progress when you get to it. Love that Crafty B cap. He does nice work.
    Stogy and flynbrian48 like this.
  13. flynbrian48
    flynbrian48
    I realized when I set it on there that the bracing for the body (3/4" plywood), installed after the cap was initially mounted, covers the holes for mounting bolts. So I've got to get some bolts long enough to go through the plywood and be able to access them from inside the trunk.
    Duh...
  14. jim32
    jim32
    Looking good Brian. Hoping to see you and the roadster at Relix Riot in two weeks.
  15. flynbrian48
    flynbrian48
    My goal is to have it there, even if I have to winch it on the trailer! I think it'll be drivable by then, but we have a REALLY busy week between now and then!
    Stogy and Bandit Billy like this.
  16. flynbrian48
    flynbrian48
    Todays project was to muck out the shop, put away tools and parts I've left laying around since late April when we got back from Florida and I started working on the roadster again, so I could walk around the shop without tripping over stuff. I did pretty good at that, but stopped before I got to the benches to work on the car again. I got the brakes bled, which was easy once I tightened all the fitting up so there were no more leaks, finished up a few loose ends and greased the ch***is. 50/50 coolant in the radiator, everything good to go. Then I dumped what little gas I had, maybe two gallons, in the tank and tried to fire it up. Fires instantly on a little gas squirted the carb, but never picked up any fuel from the tank. I took the line off at the fuel pump and could blow through it with no "bubbles", and couldn't siphon any from the tank, so I think it just needs more in it.
    I can't blow back towards the fuel pump from the in line filter just ahead of the tank, and can't siphon any there either. Tomorrow I'll get some more fuel and we should have smoke and noise. 006A5225-A72D-4042-BAFD-1A64684632F6.jpeg 2AFDA15D-AD2F-4E20-99C7-A26A9AD33C61.jpeg 2A0F4F8A-391B-402D-8EEF-585FDAAFA76A.jpeg 78A73C44-541E-498E-8227-540056483BC1.jpeg
    GordonC, Stogy, winduptoy and 13 others like this.
  17. flynbrian48
    flynbrian48
    The fuel tank turns out to have a pinhole in the bottom, as the bottom of the tank got wet after overnight with gas in it. The distributor rotor fit was VERY sloppy on the shaft (how didn't I notice that?) which probably explain why it ran so erratically and poorly. So, new tank on the way from Tanks Inc., and a Pertronix ignition system. Both should be be here tomorrow so I think I'll make Relix.
    GordonC, Stogy, brEad and 6 others like this.
  18. flynbrian48
    flynbrian48
    Yay! All my new stuff is here! Gas tank, filler, proper ohm sender, Pertronx, coil, rotor that fits the dizzy shaft. I'm tickled pink.
    Stogy, Bandit Billy, brEad and 5 others like this.
  19. flynbrian48
    flynbrian48
    No stupid leaky gas tank is gonna defeat me, no sir! Tomorrow I'll get a hose barb to push the fuel line onto, make some straps from some stainless steel I have, and get the Pertronix unit in. 44D36049-423F-4B07-8201-95D5F6D85418.jpeg 8E5447AE-92A9-422E-BD18-BAA3D2F826E7.jpeg
    GordonC, AndersF, Stogy and 9 others like this.
  20. Guthrie1068
    Guthrie1068
    I'm gonna try to make it to Relix, I'll be looking for you. I wanna see this car in person finally!
  21. flynbrian48
    flynbrian48
  22. flynbrian48
    flynbrian48
    Here it is, in repose. I changed the oil, topped off the trans fluid, it moves under it's own power, starts instantly and sounds great with the 2 1/2" straight pipes. I'm happy. E0ADD343-239A-468E-9209-929498C1D618.jpeg 12878FA1-2800-4290-8FBE-C99AE27B555A.jpeg 7CE6B0C8-0589-4BD1-8000-EFE199EFFBF5.jpeg E12F16F8-2379-4D4C-9D6C-1AB442E41357.jpeg
    GordonC, drdave, AndersF and 14 others like this.
  23. flynbrian48
    flynbrian48
    Hope to meet you! We have good friends who just bought a place in Rives Junction, the meat market there is great!
    Stogy, Guthrie1068 and jim32 like this.
  24. flynbrian48
    flynbrian48
  25. Stogy
    Stogy
    Congratulations Brian it looks and sounds awesome...you certainly are a motivated Hamber and have a great eye for detail and quality. Have a whole lot of fun with it...;)
    winduptoy and flynbrian48 like this.
  26. Stogy
    Stogy
    Oh and nice race track...:D
    I liked the old coupe in the distance...next project?
  27. Stogy
    Stogy
    Brian curious in an interesting way...I have a similar squeak in the front WW Backing plate to Buick drum area...you have those don't you?...it's usually after a bit of driving...I think it may be the drum to the backing plate...or it may be a shoe to the drum too...a mechanic mentioned a lip/step worn on the shoe perhaps it something internal...I've read about it here...
    It might not be that on your ride but it sure sounds the same...
  28. flynbrian48
    flynbrian48
    Good question. I THOUGHT it was a brake dragging, a shoe against the drum, because I noticed it only after it'd been driven a couple miles, and I found the master cylinder pushrod needed to be adjusted. The pedal got hard after a couple miles as well. So, I adjusted the pushrod, and it now has what feels like the proper amount of free travel but I still have the "squeak".
    With the front wheels off the ground, there's a spot where rolling the wheel back and forth I get the same noise at the right front wheel. I think it is indeed the Buick drum contacting the backing plate in that spot. Tomorrow I'll pull the wheel, drum, and see if there's a shiny spot on the backing plate where the drum might be touching it. They do run VERY close to the backing plate. We'll see. I can live with it if it's something that a little work with a grinding wheel won't cure.
    Note that the "squeak" disappears when the brakes are applied.
    Stogy likes this.
  29. SS327
    SS327
    You know, I’m almost embarr***ed to admit this but I did not care for the color or car in the shop. But out in the wild that thing knocks my socks off. One hell of a job.
    flynbrian48 likes this.
  30. Johnboy34
    Johnboy34
    from Seattle,Wa
    Cool! And that's a nifty racetrack to test drive on. :)
