Hot Rods model a front spring
Discussion in 'The Hokey Ass Message Board' started by V4F, Jul 23, 2022.
  1. V4F
    V4F
    from middle ca.
    1931 ford coupe .
    can not get the shackles to line up .
    one side is laying against the spindle .... other side is inside (almost on axle) .
    im trying to get a little travel up front .
    im stuck because im not sure how to fix this ............ any thoughts appreciated
    thanks .. steve
  2. Pictures would help us understand what you're dealing with...
  3. rusty valley
    rusty valley
    Put just the main leaf on by itself, then ***emble the spring while its on
    Flathead Freddie and Just Gary like this.
  4. SwampLedge
    SwampLedge
    The Model A front spring shackle shouldn’t be laying against the spindle. They shouldn’t be near the spindle. The end to which the spring attaches should be towards the center of the car. Like 28phonebooth said, pictures would help.
  5. Andy
    Andy
    Aftermarket axle? A lot are made shorter so the disk brake set ups did not move the tires out too far.
  6. V4F
    V4F
    from middle ca.
    thank you . after market axle .......... taking close measurents tomorrow ........ steve
  7. V4F
    V4F
    from middle ca.
    thank you all for great info . i have changed everything but axle (near new)
  8. fiftyv8
    fiftyv8
    from CO & WA
    It sounds like maybe your spring needs resetting or you have an old axle with a different perch hole spacing and hence either your sproing or axle are not compatible with each other.
    It happens...
    Then you have to know if your spring eyes have been reversed or the shackles are stock or something else??? Axles 1972_June_Street-Rodder_005.jpg Axles.jpg
    Tow Truck Tom likes this.
  9. nobby
    nobby
    check your spring is 29.25'' long and 1.75'' wide
    1929-1934
    IF its 39.5'' long and 2'' wide then its for spring in front
    35-40
    what you need to do its go to the sids axle website and learn
    the perch widths and king pin distances
    only then can you cross reference them against 4'' dropped axles that are aftermarket or modified originals
    IF the spring is ANY different from the above, either 31 ish o2 33 ish, its aftermarket
    you have to learn perch distances
    rusty valley likes this.
  10. There are so many ways to get in trouble with what you're trying to do. Without photos and numbers, it's tough to try and advise how to fix it. Sounds like your parts combo isn't a good one.
    clem and X38 like this.
  11. V4F
    V4F
    from middle ca.
    yes im finding out ........ i have expensive parts that do not fit .............. but joe fixed me up
    Pist-n-Broke likes this.
