Projects The Adventure of a Boy and His Edsel
Discussion in 'The Hokey Ass Message Board' started by guthriesmith, Oct 4, 2021.
  1. guthriesmith
    guthriesmith
    Yep, pacing is what we did too. The 292 is still in the car although mostly unhooked. We spent Sunday afternoon cleaning up hardware, bolting the intake on, and getting the engine ready to pull. Pretty sure we have everything loose on the top side, just need to unhook everything underneath and pull it out.
    I did learn something Sunday. We went to put the intake on and one of the gaskets wouldn't line up right with the intake ports when it went over the studs in the head. I could have sworn that the gaskets were the same side to side, but apparently there is a left and right on a y-block? I have changed intakes twice on my 292 and sure didn't remember that. Anyway, I ran over to Sid's house and dug through gaskets and found a "set" and when I stacked them on top of each other, the ports were shifted over about 1/4" or so side to side. Apparently I just didn't remember this or got lucky when I put gaskets on my engine a couple times.
  2. guthriesmith
    guthriesmith
  3. guthriesmith
    guthriesmith
    Little more progress today a****st other work needed on other stuff. Loaded it up and took it to the car wash to try to clean up the engine bay some.
    41 GMC K-18, Stogy, winduptoy and 9 others like this.
  4. bobss396
    bobss396
    I pressure washed my bay using Simple Green. Then hit it with a wire wheel followed by VHT paint. Probably blew a day with that task. But worth it.
  5. guthriesmith
    guthriesmith
    I actually reverted back to Easy Off Heavy Duty oven cleaner on this one. I figured it didn’t work as good as it did 30 years ago the last time I had used it. Seems most chemicals have been modified to be so safe to the point they don’t even work anymore. Anyway, seems it still works well and even still takes paint off. We may spray it all down a second time then do like you did. After having grease all the way to our armpits pulling the motor, some time cleaning up should make it nicer to work on going forward. :D
    brEad, 41 GMC K-18, drdave and 9 others like this.
  6. That PINK car is hiding the GOOD car!! :D:D
    Ben
    Okie Pete and guthriesmith like this.
  7. Dustin 257
    Dustin 257
    from Dallas
    Looking good. Cleaned up engine bay always makes things look better. Wire wheel has always been my favorite also. Good thing is your son is learning the trade. He won’t have to call AAA to change a flat tire lol.
    brEad, 41 GMC K-18, Okie Pete and 3 others like this.
  8. bobss396
    bobss396
    I like to use the cheap dollar store oven cleaner. Forget anything lemon scented, it is too weak to be effective. I use it to strip paint from model cars mostly.
    41 GMC K-18, drdave, Sancho and 3 others like this.
  9. 38Chevy454
    38Chevy454
    X2 on oven cleaner as an effective degreaser. I use the dollar store cheap stuff. Name brand easy off too expensive in comparison. Plus oven cleaner washers off easily without any real residue.
    Thor1, 41 GMC K-18 and guthriesmith like this.
  10. guthriesmith
    guthriesmith
    Good to know on the cheap dollar store oven cleaner. I actually went to the dollar store to get that, but they also had the name brand stuff. I bought cans of both, but used the Easy Off stuff since I ***umed it might work better. I now have 4 cans of the cheap stuff on the shelf in the shop for the next one I need to clean. :D
    Oh, and went back to the car wash this evening for the second oven cleaner cleaning. It is pretty clean now so shouldn’t take much s****ing and wire brushing. Getting there slowly. It was 106 today and is supposed to be 108 tomorrow. Hard to want to be in the shop too much right now.
    Thor1, 41 GMC K-18, winduptoy and 6 others like this.
  11. aussie57wag
    aussie57wag
    from australia
    Very cool. Irrelevant that it's not a 2 door. He can load all his mates in with ease. Running a 292 it should great as a daily driver. The y-block is arguably the best small cube v8 made. If the 2 speed trans dies you can get an adapter to fit the gm T 700 to the y-block.
    Cool car.
  12. aussie57wag
    aussie57wag
    from australia
    Definitely fix the radiator first. If he forgets to top it up and cooks the engine it's a big cost to fix. A radiator is a small cost.
    guthriesmith likes this.
  13. guthriesmith
    guthriesmith
    Yep, new radiator was in right before we decided to pull the motor. So, hopefully that is covered. :)
  14. Okie Pete
    Okie Pete
    Great job Jeff and Sons .
  15. guthriesmith
    guthriesmith
    Thanks Kurte! Speaking of, I’m ready to have this thing back together so we can get back to doing stuff together. Photo by Dan Greenberg. I did crop it as well, since Samuel’s car isn’t HAMB-friendly. :D
    40two, Thor1, v8flat44 and 19 others like this.
  16. aussie57wag
    aussie57wag
    from australia
    The 56 looks way cool too. Is it still y-block powered?
  17. guthriesmith
    guthriesmith
    Thank you and yes sir. It still has the original 292 and has about 103k miles on the odometer. The 312 we are putting in the Edsel was actually slated for the 56. But, my son needed it more.
  18. Okie Pete
    Okie Pete
    I’m going to have to hang around on Sunday at the SK 500 . Dan takes great pictures
  19. guthriesmith
    guthriesmith
    Hoping to stab an engine back in this evening. We didn’t spend a lot of time cleaning and painting, but it does look a little better. Pay no attention to the rusty battery tray... :oops:
    89BA683E-356B-459E-8AAC-39CF6BEDE1E8.jpeg 1FFF015A-524A-4A53-9E26-7B96C0AF43F9.jpeg
  20. Dan Hay
    Dan Hay
    I love a good Rustoleum restoration!
  21. Dustin 257
    Dustin 257
    from Dallas
    Looking good. He’ll be back on the road in no time.
    I forgot to tell you if you need a new master cylinder I’ve got one, I would make your son a hell of a deal on. Bought for the wagon and went to a dual setup for safety.
    Thor1, Okie Pete, 41 GMC K-18 and 2 others like this.
  22. guthriesmith
    guthriesmith
    I’ll keep that in mind. Thanks!
    Well, motor still isn’t in, but should be tomorrow. We should have spent more time on cleaning up the engine compartment, and I wish the paint was less glossy... But, it will do for what this is. Took most of the day to clean up more stuff and swap from old motor. And, I decided to clean up the shop some...tired of tripping over stuff.
    93E03261-5819-4ABA-9A5E-DE39DDD59F2C.jpeg AA6FFDBF-0307-4578-9240-AC2114D189C8.jpeg
  23. guthriesmith
    guthriesmith
    Just got this last night too. Silas asked a friend of ours, Alan Childers, about drawing the car. Alan is a very talented young guy that works for Steve Cook Creations building some amazing cars. Anyway, drawing turned out pretty kool. Now we know what it might look like with Supremes and skinny whitewalls.
    1stGrumpy, brEad, Copper Top and 21 others like this.
  24. bobss396
    bobss396
    I did my engine compartment with VHT ch***is and roll cage black, not a gloss. It blended well for touch ups.
    WhitewallWill, Thor1 and guthriesmith like this.
  25. Budget36
    Budget36
    I don’t get out much;). Are those factory or aftermarket exhaust manifolds?
  26. guthriesmith
    guthriesmith
    They are factory 57 manifolds as best I know. They also appear to be the same as the ones on my 56 and what was on the Edsel originally as well. I am no expert and still learning this stuff as we go. :D
    Thor1, Okie Pete, Sancho and 5 others like this.
  27. Budget36
    Budget36
    Sweet. Fine looking they are!
  28. You're going to have to nickname Silas "The Bean"
  29. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Can we get some chrome nuts for those valve covers??????
  30. ClayMart
    ClayMart
    It's Pinky and the "Brain", isn't it? :confused:
    '28phonebooth and guthriesmith like this.
