1952-59 Ford 2 door sedan door window glass removal on a 56.
Discussion in 'Off Topic Hot Rods & Customs' started by jimmy six, Jul 23, 2022.
  1. jimmy six
    jimmy six
    Helping a friend remove side window gl*** for replacement. Any ez hints you guys have. I’ve never done it.. thanks.
  2. flyboy89
    flyboy89
    from So. Cal.
    Try taking the regulator loose, then take the gl*** channel off of the regulator. I think thats the way I did it on the Club Coupe rear windows.
  3. nosford
    nosford
    Been a long time since I have done this (35+ years) but as I remember on my 56 Customline I removed the vent window complete with the front gl*** run. Some screws at the top of the door then a bolt at the bottom of the gl*** run. Then there was enough room to slide the side gl*** up and out by rotating it and lifting it out the top. IMG_1574[1].JPG
  4. Nalakaya
    Nalakaya
    I’m going to be doing this soon. Nosford, can you share what manual you have that the picture is from?
    Thanks!
  5. nosford
    nosford
    I have a 55 Ford car shop manual, it is a reproduction I ordered from the internet somewhere. On the back cover it says FORM 7098-55.
    Dos Cincos likes this.
  6. Dos Cincos
    Dos Cincos
    Picture of mine.
    nosford likes this.
  7. nosford
    nosford
    Thanks Dos Cincos!
  8. customline joe
    customline joe
    Would this be covered in the hotrod reverends post ?
  9. nosford
    nosford
    I went through the CD I got from him and there was parts diagrams but didn't see actual R and R instructions. Maybe I wasn't looking in the right place?
  10. danman55
    danman55
    nosford likes this.
  11. nosford
    nosford
    danman55, once again the teacher in you comes out! Should have known! When I first saw this post my first impression was 1937 Ford vent window....... Mark
    danman55 likes this.
