Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Dave G in Gansevoort
    from Upstate NY
    Marty, I don't have any good pictures from way back when in the injected dirt cars, however what we did for throttle linkage might work for you. Briefly, if the engine doesn't rock, solid mounted, we ran a section of tubing sized to fit over the throttle shaft on the right bank, that had a slit cut along one side about a half inch long. Then a split collar matched to the od of the tube locked it on the throttle shaft.
    The tube then extended back thru the firewall and a heim joint supported from a crossmember in the roll cage. Just behind this was a clamp on arm, made from another split collar with an arm welded on. It was located just above (7-8 inches) the throttle pedal, so a short link up made it operate.
    In your car, you could mount the extension on the left bank throttle shaft, and maybe use a spherical bearing in a flanged housing bolted to your firewall.
    If the engine can move, it could still work, just insert a small u-joint between the engine and firewall in the extension.
    Just a thought...
    Stogy likes this.
  2. Marty Strode
    Marty Strode
    Dave, My friend, Lonnie Gilbertson came to see me yesterday, and he came up with what could be the solution. Lonnie is a long time quality car builder (won the AMBR twice) and a very good problem solver. Thanks for the sound advice, there will be some engine movement.
    Stogy, bchctybob and Graham08 like this.
  3. neilswheels
    neilswheels
    from England
    Lonnie sounds like a good friend to have, looking forward to seeing what you both come up with.
    Stogy likes this.
  4. Marty Strode
    Marty Strode
    Neil, Lonnie and I have been working together for nearly 25 years, and we both have different specialties, that work well in our projects. He came up with the idea of a plate that attaches to the screws that mount the stacks, with a bell crank pivot. IMG_9519.JPG IMG_9520.JPG IMG_9521.JPG IMG_9522.JPG IMG_9525.JPG IMG_9526.JPG So, I made one out of steel, that serves as a prototype, the final one will be aluminum. I had purchased some bell cranks from Speedway, and once I get some more 3/16 rod ends, it should work slick, I didn't want to use a cable.
    1biggeorge, Stogy, brEad and 8 others like this.
  5. Marty Strode
    Marty Strode
    I an earlier post, I mentioned fabricating a panel to cover the large slot in the firewall required to get the Mag in and out. I finished the cutout today and whipped up an aluminum cover, that will be retained with 6 - 10-32 screws, and plan on punching 4 louvers, to add a little eye appeal, along with ventilating the trapped air in that area. IMG_9527.JPG IMG_9528.JPG IMG_9532.JPG IMG_9533.JPG IMG_9534.JPG IMG_9535.JPG
  6. Marty Strode
    Marty Strode
    Here is the cover, louvered and mounted. Since I have Covid, and can't go anywhere, I was able stay busy and get the result I wanted for the throttle linkage. Other than the temporary link ( that looks like junk) it works great. My goal was to set it up, so where the linkage p***es through the firewall, it will also work with a set of carburetors. IMG_9537.JPG IMG_9538.JPG IMG_9541.JPG IMG_9543.JPG IMG_9544.JPG IMG_9546.JPG IMG_9549.JPG IMG_9550.JPG IMG_9552.JPG
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Really nice as always, Marty.
    Sorry about the Covid. I had it at the beginning of May. Not real sick but the recovery is very slow. My get up and go got up and went!
  8. embyman68
    embyman68
    Marty, I hope you recover quickly and fully! Hope to see you in Toutle next month.
    Stogy, bymanr and Dean Lowe like this.
  9. Marty Strode
    Marty Strode
    I did a little work on this project today. A while back I had some 3/8" steel doughnuts water jet cut, for the flanges on the headers. Since one of the tracks I plan to run, (Portland International Raceway) requires mufflers, and friend, HAMB Member @Alan Davis gave me some Supertraps, it was time to get them mounted. When mating a flange to the middle of a bend, it is never round or even the same size. So, I measured both sides, 90 degrees apart, and took the happy medium for the dimension to machine the inside diameters. Now, I need to drill the bolt patterns in both and weld them on. Then it's off to Finish Line Coatings, for the final product. It's good to be back to work, thanks to those who follow. IMG_9590.JPG IMG_9591.JPG IMG_9593.JPG IMG_9595.JPG IMG_9596.JPG IMG_9598.JPG IMG_9599.JPG
    Stogy, cactus1, alanp561 and 33 others like this.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Glad to see you're back at it, Marty. Those rings look good.
    Stogy, tractorguy and rod1 like this.
  11. Marty Strode
    Marty Strode
    Bruce, I think I will turn a radius on the back side, to get rid of the square edge.
    Stogy, bchctybob, Dean Lowe and 4 others like this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That lathe work is addicting! Just one more tweak and it will be perfect, no wait just one more thing.
    Stogy, bchctybob, alanp561 and 2 others like this.
  13. stillrunners
    stillrunners
    from dallas
    Glad your well and back to playing....uh...building !
    Stogy and tractorguy like this.
  14. bskustoms
    bskustoms
    from Aloha, Or.
    As always Marty great work. Just picked up '29 sedan to occupy my spare time haha
    Stogy likes this.
  15. Marty Strode
    Marty Strode
    Sam, we need to get together.
    Stogy likes this.
  16. Marty Strode
    Marty Strode
    Drilled and in place, now back to the tunnel cover. IMG_9607.JPG IMG_9603.JPG IMG_9604.JPG
    Stogy, cactus1, catdad49 and 23 others like this.
  17. Marty Strode
    Marty Strode
    A friend dropped by for a visit today and it inspired me to work on the trans and bellhousing cover. So, I annealed, beat and wheeled a piece of aluminum. I got it roughed into shape, now to do a little more tomorrow. IMG_9838.JPG IMG_9839.JPG IMG_9840.JPG IMG_9841.JPG
  18. Bandit Billy
    Bandit Billy
    Stogy likes this.
  19. Marty Strode
    Marty Strode
    Now that’s a silly question Bill !
    Stogy, brEad, Dean Lowe and 5 others like this.
  20. Hitchhiker
    Hitchhiker
    Whoa. That thing is wicked, evil, mean, and nasty!
  21. catdad49
    catdad49
    Marty, another Bad machine! Hope you are getting back up to snuff.
    Stogy and Hamtown Al like this.
  22. The car looks bad*** Marty! Nice work mate!
    Stogy likes this.
  23. Marty Strode
    Marty Strode
    I am starting the new year out working on my own stuff, primarily the '29. I finished last year on Sat, getting a long (time frame) project done and out the door. I posted pictures on 2 of my other threads about this unique Roadster. It was built in Portland in the early 50's and was featured in Hot Rod in the Nov. 55 issue. The car is a rare combination of parts, starting with a 23 Fiat body, hot flathead and Kinmonts on all 4 corners. The lucky part was, all of the sheet metal was there and in decent shape, I had the build a new frame, and get all the pieces lined up.
    Puritan 2.jpg Puritan 1.jpg puritan 3.jpg puritan 4.jpg IMG_2785.JPG IMG_7895.JPG IMG_9880.JPG
    Stogy, bchctybob, alanp561 and 14 others like this.
  24. AmishMike
    AmishMike
    Nice rebuild!! How thick a wood is seat back. Picture makes it look real thick
    Stogy likes this.
  25. Marty Strode
    Marty Strode
    5/8"
    Stogy, AmishMike and Hamtown Al like this.
  26. Outback
    Outback
    from NE Vic, Oz
    What a cool lil roadster!
    Stogy likes this.
  27. catdad49
    catdad49
    Wow, that lil roadster looks like it’s straight out of a Stroker McGurk cartoon!!
    Stogy likes this.
  28. Wowee that’s neat!
    Stogy and stanlow69 like this.
  29. Marty Strode
    Marty Strode
    Now that my customer work is on hiatus, I have been organizing the shop and am back on 2 of my projects, the 29 and my 40 pickup. I have been putting off finishing the steering shaft support, but it needed to be done before dis***embly. Drilling and installing threaded bungs in the frame, while on your back, in a crowded area, is not a lot of fun, but I got it done today. One thing that helped a lot was a headlamp given to me by a friend over a year ago. I have found this to be most handy, as being a lighted headband, it gives plenty of light right where you are looking. After transfer punching, drilling and knocking in the insert, it was simple to install the second one. Every time I try to do both at the same time, I have trouble maintaining the centers. The inserts will be welded once the ch***is is apart. I made the inserts by cutting the head off a bolt, and locking on 2 raw steel nuts, stick it in a drill, turn on the belt sander, and grind to the size, while the drill is spinning. Now it's back to finishing the firewall to floor, and on to the roll bar mtg.
    IMG_9903.JPG IMG_9890.JPG IMG_9891.JPG IMG_9892.JPG IMG_9897.JPG IMG_9902.JPG IMG_9907.JPG
    Stogy, bchctybob, charleyw and 14 others like this.
  30. Marty Strode
    Marty Strode
    We had planned to undercoat the cab, and inside to fenders on the '40 today, but wind and rain from the south, changed our minds. The big shop door, faces south, and we didn't want to have problems, but it looks good for next Sat. We are using a Raptor coating kit, that is black and rubberized. The cab will be hung from the ceiling using a chain and a spreader bar. Also, my old race partner sent me this photo that he took when we were racing at Fremont, Ca. in 1988. It's in the staging lanes, and I am talking to veteran Top Fuel racer Sammy Hale, his ride, (the Champion Speed Shop) is right behind ours, and the Charlie's Business Coupe, Fiat is behind us. Those were fun days ! IMG_9905.JPG IMG_9906.JPG Ruthless   Marty and Sammy Hale at Fremont.jpg
    Stogy, bymanr, Hamtown Al and 19 others like this.
