Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. wrenchbender
    wrenchbender
    That’s the way the factory cars are done mostly done at a upward angle I’ve noticed
  2. topher5150
    topher5150
    I have an idea about using some fabric with patterns in my door panels. Is there a way to protect this from UV
  3. stanlow69
    stanlow69
    Scotchgaurd.
    loudbang and topher5150 like this.
  4. topher5150
    topher5150
    I was thinking up some ideas for the trunk area of my 47 Ford. What can I use for the panels along the side? I was looking at some pics online and it looks like curves a bit.
  5. Whoamel
    Whoamel
    from So Cal
    I'm currently doing the trunk in my '40 Ford. I used 1/8" plywood for the sides, and used 5.2mm plywood for the back. (The 5.2 is about .20" thick)
    I was looking into 1/8" ABS, but the only place local to me has a 4x8 sheet priced at $200. The plywood was a total of about $40 for both sheets.
  6. Dos Cincos
    Dos Cincos
    I am in the process of making some door panels using the no sew method but have run into an issue.
    The upper panel is a pre-made 2" pleated boat vinyl with a 3/8" foam backer and the bottom section is some zodiac vinyl on top of some 1/4" foam. I removed 1/2" of foam from the joint between the pleats and zodiac and stapled that down. Then used a tack strip (placed on top of the 1/2" stapled section) to join the zodiac material to the bottom of the pleated material before I placed the 1/4" foam down. When I got it all glued down I could see where the tack strip was under the zodiac material.
    Do I need a thicker foam backer for the bottom section or is the zodiac material less forgiving to imperfections under it? Anything I should be doing differently?
  7. Whoamel
    Whoamel
    from So Cal
    Just a quick heads up if anyone (like myself) doesn't have a lot of room for their machine. Costco has a folding table that is 24'x48' and has adjustable legs. At the tallest setting, it is 29" which is exactly the same height as my sewing table. It's $40-ish.
    I did some carpet binding before I got this, and really struggled with folding the material up to get it through the machine. I did this large pleated section today and it made a huge difference.
    It's not a pro setup, but it really works for me in my tiny bedroom/office space.
  8. steve hackel
    steve hackel
    In addition to nearly the same setting as above, I added a folding leaf in front of both the
    sewing machines table and the side extension table shown at the left. When I needed to
    use it I just folded it out and it has a support frame leg that is hinged to the back of the
    extension. This allows for the material - carpet - large canvas etc to have its bulk or weight
    supported past the sewing machines working surface. It's just a suggestion to another
    way of setting up your work station.
    chryslerfan55, loudbang and Whoamel like this.
  9. Whoamel
    Whoamel
    from So Cal
    After playing around a bit, I decided I'm NOT going to use the 1/8" plywood on the sides of my trunk. I put self tapping screws in it to temporarily mold the wood into the curves, but it's showing signs it's not going to hold up.
    I have some Auveco clips I plan on using to hold the panels in, and I think the first time I try to remove the plywood, it'll fail. Depending on cost, I'm going to try some .060"-ish aluminum. There are some curved, upholstered aluminum panels in the back of my car that are doing well. I'm guessing there is little to no expansion or contraction due to weather, so I guess we'll see...
  10. topher5150
    topher5150
    What are some batting ideas for the door panels? I don't know of any upholstery places by me so something from Jo-Anns or hobby lobby or something like that
    I used neoprene on the kick panels and, but that's to hard to work with
  11. A 2 B
    A 2 B
    from SW Ontario
    Maybe a Hamb infraction but abs sheet is easily cut, molded, even bent into a tight 90 with heat and it's lightweight. It can even conform to slight compound curves. Impervious to moisture. Just doesn't like UV light. Once covered its "out of sight, out of mind".
  12. Torana68
    Torana68
    from Australia
    would anyone know how many yards of material for a Model A coupe, doors seat, rumble etc? not including headliner.
  13. Whoamel
    Whoamel
    from So Cal
    I never touched a sewing machine until the first of this year. Just wanted to touch base on my first project, and post a follow up photo or two. I struggled with a few things, got frustrated a time or three, but I kept at it and re-did the trunk, all interior panels, and the carpet. I still have to sew a heel pad on the driver's section and glue it down, and hope to get that all done tomorrow.
    Quite a learning experience to say the least.
    Mark
    whoops! I should mention this is a '40 Ford Coupe....
  14. Dick Stevens
    Dick Stevens
    Just shows that it doesn't have to be fancy to look good!
    chryslerfan55 and Whoamel like this.
  15. brEad
    brEad
    Awesome work! Your trunk came out great! Interior is also beautiful!
  16. topher5150
    topher5150
    I'm having trouble getting the fabric to stick all the way to the MFP panels. I've been using weldwood on everything but some areas aren't really holding that well.
  17. continentaljohn
    continentaljohn
    @Torana68 the model a seat is 5 yards and door panels 3 and rumble I would think 4 to 5 as I haven’t done a rumble in awhile.. I just did this standard roadster and was 8 yards of vinyl . If adding pleats add more yardage 25% as it’s amazing how much pleats eat materials . 340C4543-8917-444D-8DF5-30EE11C7C5A9.jpeg
  18. Torana68
    Torana68
    from Australia
    thanks, appreciate the help.
  19. Whoamel
    Whoamel
    from So Cal
    Not sure what MFP is. Is it maybe MDF board? That Weldwood contact cement is really good stuff. Did you coat both surfaces and give it about 15-20 minutes of dry time before sticking them together?
  20. topher5150
    topher5150
    Could have been I didn't wait long enough. I'm not the most patient lol
  21. Roothawg
    Roothawg
    Bravo my friend! It looks great.
  22. Nice!
  23. Whoamel
    Whoamel
    from So Cal
    I can relate to being a bit impatient.
    If the surface is very smooth, you could try scuffing it up with a bit of sandpaper.
    topher5150 likes this.
  24. buzz4041
    buzz4041
    from Texas
    ABS works great and you can heat it to form the cuvature and retain it.
  25. Roothawg
    Roothawg
    You have to be careful with ABS though. I have a buddy that is an interior guy and he used it on a high end roadster. He finished the car, loaded it on a trailer and it traveled approx. 45 minutes in the Oklahoma sun. By the time the car got to where it was to be delivered, they called and asked what in the **** was wrong with the interior. It had warped and bowed up so bad, it was unusable. He ended up re-ragging the whole car.
    chryslerfan55 and drdave like this.
  26. Whoamel
    Whoamel
    from So Cal
    I know people say that it's not too expensive, but the cheapest place here in So Cal wanted $200-ish for a 4x8 sheet of 1/8" abs.
    I did end up using the 1/8" plywood for the curved areas, but I reinforced the backside area where the screws go through. At first, I didn't care for the two screw heads being exposed, but then I reminded myself it was in the trunk. :)
  27. 1pickup
    1pickup
    Didn't see any discussion on this, sorry if I missed it: Does anybody use one of the cylinder arm / cylinder bed units for auto upholstery? I can see the advantage for small stuff, but looks like it would be a pain in the *** when doing something with a long continuous straight line, like a door panel.
  28. Roothawg
    Roothawg
    What thickness scrim foam are y'all using for door panels?
  29. Boxcar's 1928
    Boxcar's 1928
    I've got that same machine and have to sew much with it. Currently the tension is not correct...need to sort that out first. How do you like it?
    R/
    Larry
  30. rob-redm
    rob-redm
    Paul R. Cedardale Uph. did my 36 3w @fireballroadster.. top notch ! 36 dash.jpg
