Hot Rods Wicked Coupes...
Discussion in 'The Hokey Ass Message Board' started by LOU WELLS, Jul 19, 2022.
  1. DaveyJonez
    DaveyJonez
    from Houston
    Driveshaft speed at 1 second/ fuel pressure at the hit?? Let’s really talk nitro racing!
  2. 19Eddy30
    19Eddy30
    from VA
    ^^^^ Just asking ,
    I know the feeling of 125inch modern A/Fc, they just do not go straight !!
  3. I dont run a computer so i cant provide those numbers. If you want to talk nitro racing i will be talking about plugs; bearings; leakdown; look of the pipes etc. A data logger is the next big investment over winter.
  4. Al Consoli
    Al Consoli
  5. DaveyJonez
    DaveyJonez
    from Houston
    Ah- gotcha, what pump are you running (volume), total nozzle area, how much (gpm) at the hit?? Are you running a BDK? Where do you have it set??
  6. Al Consoli
    Al Consoli
  7. Black_Sheep
    Black_Sheep
  8. -Brent-
    -Brent-
    I couldn't just lurk on this thread:
    AMT-R2-770-3.jpg 03-151[1].jpg 9009212 (1).jpg 05.jpg 9C113E1C-1E1A-43E9-AE08-DB7D9BC6B1CC.jpeg 1930 FORD STREET GASSER.jpg Mallicoat Bros Willys.jpg ALTIZER FINDERS KIBLER TRAVELER.jpg Kiwi Kev Altered Model 40.jpg Bill Wineland Model A Coupe.jpg 79821387_2610632392389428_5931909985410744320_n.jpg Hells Messenger.jpg 34'!.jpg Sheldon Schmidt Blown 1934 Panel Striped.jpg IMG_9002_zpsq2tcu96g.jpg a5f530a618468e6bc085d44916ebff4f.jpg
  9. deathrowdave
    deathrowdave
    from NKy
  10. mad mikey
    mad mikey
  11. Johnny99
    Johnny99
    I've heard rumors that the Ben Rizzio car survived in as raced condition sitting in a garage next to his Lamborghini. Sure would like to see a current photo if that is the case. Those fuel coupes are certainly wicked!
  12. Johnny99
    Johnny99
    And then there's wicked Chevy coupes.
    Ron Funkhouser, Jet96, brEad and 20 others like this.
  13. 41 GMC K-18
    41 GMC K-18
    I like everything about this coupe!
  14. Rickybop
    Rickybop
  15. The pump is a enderle 24 gal dual spur gear steel pump. I would have to look at my notes for the total on the nozzles. I run four nozzles in the blower with 48s. I run both idle and run nozzles in the manifold. The blower is a littlefield retro with the pie opening. Its moved back on the manifold. 8-71 black strips only. It is a street car. Barrel valve set at 80 percent with the pipes damp. Timing is 45-50 nitro is 80-85 depending on the track.
  16. Jalopy Joker
    Jalopy Joker
  17. Al Consoli
    Al Consoli
  18. Al Consoli
    Al Consoli
  19. Stogy
    Stogy
    :rolleyes:...I consider this Sport Coupe wicked in it's own way...especially being an inspired Vintage Hotrod...it's truly been a timewarp for me every time I get in and turn the key...Kudos to Jerry for his truly nostalgic vision for making it happen...;)
  20. Dean Lowe
    Dean Lowe
  21. LOU WELLS
    LOU WELLS
    from IDAHO
  22. joel
    joel
  23. 1940Willys
    1940Willys
    GREAT Thanx for that Post!
    chryslerfan55 and LOU WELLS like this.
  24. Nacifan
    Nacifan
    from Pat-G's book, 1 of my fav chevy coupes !! wasn't there some line art in St Rodder mag with a coupe like this ??
  25. Johnny99
    Johnny99
    Thanks Dean,
    Sure would be fun to get a peek at that time capsule.
    Stogy and mad mikey like this.
  26. Johnny99
    Johnny99
    Another wicked survivor roto.jpg roto1.JPG roto1.PNG roto4.JPG roto5.jpg roto6.jpg .
  27. Dean Lowe
    Dean Lowe
    Or put a fresh load of nitro in the tank and fire it up!
    Ron Funkhouser, Stogy and mad mikey like this.
  28. BrandonB
    BrandonB
    from nor cal
    Jerry Dilbecks altered 34.
    On a side note, I ended up with the motor that was in this record holder. 283 w/4x2 & 4 speed hydro.
    74541D49-0C3D-47C3-95E9-3D13496CE73A_1_201_a.jpeg B31A8BCE-AE94-4D36-B2D3-0569581FCFF5_1_201_a.jpeg EDF778DF-ADA3-4A30-99D7-EA5360A40E4B_1_201_a.jpeg
    rod1, Ron Funkhouser, Jet96 and 19 others like this.
  29. Johnny99
    Johnny99
    Yes, that would be icing on the cake! I was lucky enough to see the Mooneyham and Sharp car make a tire smoking p*** at a Seattle nostalgia race a long time ago with the "Mad Austrian" Gerry Steiner at the helm. What a sight it must have been seeing two of these cars going at it! I'm pretty sure this shot is from Puyallup. Hey look there's some traditional aluminum heads!
  30. Stogy
    Stogy
    https://www.jalopyjournal.com/forum/threads/1939-chevy-coupe-drag-car-info-found.1198388/
    :rolleyes:...The Owner of this Hotrod/Drag Coupe just became a member and chimed in yesterday. Apparently it remains pretty much as you see it there...I encouraged him to get the tarp off and get out and enjoy it...its been in storage for many years...and he's going to do just that...awesome...​
    Jet96, brEad, Speed Gems and 6 others like this.
