Art & Inspiration Just Louvers////////
Discussion in 'The Hokey Ass Message Board' started by Stogy, Aug 1, 2016.
  1. Jalopy Joker
    Jalopy Joker
  2. Jalopy Joker
    Jalopy Joker
  3. Stogy
    Stogy
    uncleandy 65, hfh, brady1929 and 6 others like this.
  4. primer31
    primer31
    from Aurora, CO
  5. 65pacecar
    65pacecar
    from KY, AZ
  6. Jalopy Joker
    Jalopy Joker
  7. Stogy
    Stogy
    Thanks Everyone for your following, sharing and appreciating...;)
    I finally started up ole faithful and got out for a few short jaunts...it's running just fine after the winter slumber...
  8. Stogy
    Stogy
    Jim Bouchard and Bowtie Coupe like this.
  9. Stogy
    Stogy
    brady1929 and Bowtie Coupe like this.
  10. Stogy
    Stogy
  11. Jalopy Joker
    Jalopy Joker
  12. Stogy
    Stogy
    https://www.jalopyjournal.com/forum/threads/pat-ganahl-r-i-p.1272122/
    :rolleyes:...A very sad day at The Hamb today... We lost a Fellow Hamber Pat (Pgan) Ganahl...Things are still evolving as to what happened but it was at a Drag Racing event in Washington...with heavy hearts we will remember Pat by his incredible legacy within the Culture...The Thread is at the link above...
    May He Rest in Peace...
    Deepest Condolences to Pat's Family and Friends
    Regards, Stogy
    Credit to Photographer, Owner
  13. Stogy
    Stogy
  14. Stogy
    Stogy
    https://www.jalopyjournal.com/forum/threads/tired-of-homogenized-hotrods.1002926/
    I wish I'd of known there were clecos...:oops:
    Some did...;)...modern methods...good enough for an airplane good enough for Hotrod/Custom...There were holes to fill...that's what welding of rivets plug...
    Sounds like there's a Hand pounded Smithing versus a alternative period method of mixed panel fabricating...Those would be the Knight Clubs...:D
    Credit to Photographers, Owners
  15. Dean Lowe
    Dean Lowe
    The streamliner was built by Bob Herda. Bob would lose his life in it when a fire severed the oxygen lines to Bob's breathing mask. The fire went straight to his lungs and killed him instantly before the car even coasted to a stop.
  16. Stogy
    Stogy
    Thanks for sharing that Dean, hard to like that post...a true and horrible tragedy...These deaths at these events are nasty...Condolences to those that were affected in this loss...The pictures here show the Adventure and Beauty of the Culture with danger as a force to avoid at all costs as we all have been touched by this here...May They Rest in Peace...soooooo many...
    brady1929 likes this.
  17. Stogy
    Stogy
    :rolleyes:...I don't know if that liner had louvers but its cool anyway and the others did...it may have...;)
  18. Stogy
    Stogy
  19. JOHN H EDGE
    JOHN H EDGE
  20. Jalopy Joker
    Jalopy Joker
  21. Bandit Billy
    Bandit Billy
    I just couldn't hit the like ****on on that one Dean but I also couldn't just walk on by. That is tragic. Thanks for sharing.
    Stogy likes this.
  22. Dean Lowe
    Dean Lowe
    Sadly, as with so many other times in racing, someone had to loose their life to change the rules for the better. Guys had been using oxygen in cars like this for a while. There was nothing in the rules about where to mount the bottle. In Bob's case the bottle was mounted behind the engine. The big Hemi poked a rod out of the block and the schrapnel severed the supply line and caused a flash fire. SCTA then wrote a rule that the bottle must be mounted in the driver compartment.
    Stogy and Lil32 like this.
  23. Stogy
    Stogy
  24. JOHN H EDGE
    JOHN H EDGE
    39C7798F-FAF4-48A3-A852-95A81789B5B4.jpeg 549E0AED-3ADF-40E9-B2E4-3BE53C1958B4.jpeg F222567B-42E7-425B-83CB-FE2C966349F9.jpeg 112490CE-82A7-4579-A607-7168338934E1.jpeg A102903D-69C9-40CE-B947-2162DD3D45C2.jpeg 29F14EF9-26C0-4B5F-BF41-54B501D9E6BA.jpeg We love louvers. Nothing like cruising down the highway and looking down that hood in front of you and seeing a hundred plus louvers. It’s says you’re driving a hot rod
  25. Mark It Zero
    Mark It Zero
  26. Stogy
    Stogy
    Thanks for posting @Mark It Zero...it's an honor to have your 4th post in this Thread...nice captures and stellar rides...
    Your 34 is nicely loaded with ventilation...;)
    Mark It Zero likes this.
  27. Stogy
    Stogy
  28. Stogy
    Stogy
  29. Mark It Zero
    Mark It Zero
    @Stogy Thanks for your kind words....
    My 34, when you run out of room on top go below!
