Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. sheparj2
    sheparj2
    Thank you. I’ll be sure to double check the ***embly of the rockers. I’ll retorque, say a little prayer and give it a whirl….
  2. Roothawg
    Roothawg
  3. Roothawg
    Roothawg
  4. I love this Thread!
    kadillackid, Roothawg and lumpy 63 like this.
  5. Hank37
    Hank37
    Here's some info on the Hydro trans. a friend of mine had a Hilborn injected 49 Olds. he made a foot operated pedal to control the pressure valve instead of the linkage to injectors. It burned the tires on every shift !
    Roothawg likes this.
  6. sheparj2
    sheparj2
    Got the rockers back yesterday and started for the first time. Fired right up and sounds so smooth. I had to fabricate a bracket for the alternator, the factory exhaust manifold bracket put it sticking out to far into the inner fender. My bracket is not pretty. Has anyone found any aftermarket brackets that work or any nicer set ups?
  7. Roothawg
    Roothawg
    Nice. Glad to see it.
  8. When I first fired up the 365 on the run stand I was disappointed on how quiet it was even with only 2ft pipes off the manifolds.
    Otherwise smooth as and quiet internals, a great feeling.
    panhead_pete, Roothawg and lumpy 63 like this.
  9. Roothawg
    Roothawg
    So I have been wondering what guys are getting for gas mileage ? I know new they were only rated at like 12. But back then gas was .50c/gal….
  10. lumpy 63
    lumpy 63
    Gas mileage or smiles per mile? I prefer to gauge mine in the latter:D
  11. Roothawg
    Roothawg
    At $5 gal you may have to…..
    lumpy 63 likes this.
  12. Frames
    Frames
    I'm running Studebaker rocker arms the LONE RANGER 007 - Copy (2) - Copy.JPG and solid lifters.
    rod1 and winduptoy like this.
  13. Roothawg
    Roothawg
    I have a set, but who knows where they are…
    winduptoy likes this.
  14. warbird1
    warbird1
    Worst I've gotten is 10 mpg, going mostly uphill... best is 16, going mostly downhill. 390 with dual AVS carbs, Isky 270H cam in my '40 with 3.78 gears. Usually get about 11 to 11-1/2 just driving around.
  15. Roothawg
    Roothawg
    That’s about what I figured. Hoping the 6 speed will gain me a couple.
    winduptoy and warbird1 like this.
  16. arkiehotrods
    arkiehotrods
    I owned a '57 Coupe DeVille from 1984-1992.
    It had a 365 with a Rochester 4-Jet.
    I was just looking at my records (gas, oil, repairs, etc) from when I owned it. The worst mileage for a tank of gas I ever got was 7.5. The best was 12.7. Overall, I typically got 10-12 mpg depending on how and where I was driving it.
    rod1 and Roothawg like this.
  17. Roothawg
    Roothawg
    Just trying to decide whether to save the 390 for a light roadster. The 36 may get a 301.
  18. winduptoy
    winduptoy
    Hell, that's what I get driving my bangers with my foot all the way down its throat... ******* off everyone behind me on the two lane
  19. Roothawg
    Roothawg
    Ha ha….
  20. rod1
    rod1
    Umm, Respectively No. The Caddy will rekindle the fire that your soul most desperately needs;). Think Gravy Sandwich ..
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    My 40 with a 49 331 stock 40 3spd and 3.78's with 4 97's jetted at 41 gets 14.5 mpg around town....
  22. Roothawg
    Roothawg
    That’s what my OT 2002 F150 gets with all that fancy computer stuff.
  23. sheparj2
    sheparj2
    ok. So looking for some advice:
    I got the rockers back and installed and it started right up but was getting a ton of water and steam out the drivers side tail pipe. I did a quick compression check and seemed low in all 4 cylinders on that side (110-120). I think I saw bubbles in radiator but wasn't 100% sure. I probably should have just tried to retorque the head bolts but I got over zealous and removed the head today.
    I don't see anything obviously wrong with the head gasket or the head itself. There is only about 15 minutes of run time on this motor. The rebuild process for this motor is a long story with multiple shops going out of business so it took about 2.5 years for me to get the motor back. In other words I don't have great do***entation on what all was done to the motor and heads.
    I'm wondering if I should just try to install a new head gasket and see if that was the issue or if I should take the head in to a cylinder head shop and have them check it out? Just wondering what you guys would do.
  24. warbird1
    warbird1
    While you have that head off I'd look it over very carefully... they have been known to crack. Also check the deck and head surface for warpage.
  25. sheparj2
    sheparj2
    Ok. I don’t see anything as far as what is visible. And a straight edge across the surface lies flat….
  26. Roothawg
    Roothawg
    Interesting that it was all 4 holes….makes me wonder about the head gasket.
  27. sheparj2
    sheparj2
    Right. Maybe I put a new gasket in, torque it and do a compression test with just the starter. If the compression looks good then re***emble the whole thing. Can I do a decent compression check with just the starter? Not sure I've done that before. I did notice some noise when I put my ear to the valve cover... Like the noise your tongue makes when you click it off the roof of your mouth.... I'm ***uming that a really poor sealed head gasket is going to give you some funny noises....
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    that is how a compression test is done, with just the starter...
  29. sheparj2
    sheparj2
    ah. Ok. Thank you.
    Moriarity likes this.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    I coat head gaskets with copper coat
    warbird1 likes this.
