Hot Rods T bucket laced front wheels
Discussion in 'The Hokey Ass Message Board' started by silent rick, Sep 12, 2019.
  1. silent rick
    silent rick
    anybody have a pic of the hub where the rotor mounts? whether if be a hallcraft or total performance wheel. i guess while we're at it, a pic of the caliper mount also.
    with both those companies gone, is anyone selling a spindle mount laced wheel/disc brake kit for a T bucket now?
  2. Fordors
    Fordors
    16994AD8-E553-43E1-9EC0-4803F6F00079.jpeg 155E2837-C956-4CF7-AFAC-F2E5748888A1.jpeg 18E4EB33-FAB9-43B8-8419-D15119CB9B64.jpeg 35493E65-CE82-48DA-B924-864D93B27481.jpeg Rick, here are some shots from a Total Performance catalog from the early ‘90’s. You can put calipers on but they will be small given the spoke wheels and small footprint of the tire.
    silent rick likes this.
  3. 34Phil
    34Phil
  4. silent rick
    silent rick
  5. Might contact Hall Craft wheels. That's been a major spoke wheel co for years. I did not search for them direct.
  6. silent rick
    silent rick
    they went out of business
  7. silent rick
    silent rick
    oh and thanks Larry for not showing the prices. my heart just wouldn't take it.
    Fordors likes this.
  8. Fordors
    Fordors
    7943E9F6-3C96-4715-BC2A-3313B464DC45.jpeg F89FDABD-7F85-4828-AADD-3E56AC49243A.jpeg Here’s one adapted to a 12 spoke, not what you asked about but it does show an alternative way to mount a rotor.
  9. 34Phil
    34Phil
  10. I ran hallcrafts on a Total Performance T in 1980.Look real cool with 3.00x18 tires,but not very good on turns.The tires would scrub,and try to roll off the rim.They cost a lot,and I was really sorry I didn't use a modern disc/rim set up.The T should go into corners like a slot car,and mine cornered like a bus.
  11. silent rick
    silent rick
    i know, that's what i was afraid of. i have bent (40)spoke kelsey hayes with 6.00x16 firestones on it now with lincoln style drum brakes.
    i've been letting those guys on the photoshop thread have some fun with it. i have to admit, i'm really digging the cheater slicks and laced wheels up front. gives the car a whole new vibe.
    bchctybob, indyjps, Lil'Alb and 2 others like this.
  12. chromedRAT
    chromedRAT
    My T uses 70s Triumph T140 or so brake rotors and calipers. I think this must have been a "thing" in the late 70s-early 80s when mine was built. My Hallcrafts and a no-name (but probably Hallcrafts) set of wires are both drilled and tapped to accept those Triumph brake rotors, and it is just a matter of having the right bracketry to mount the caliper.
    The original 16" wires on it are crusty from about 35 years of neglect and I was lucky to find some almost perfect 18s this spring. Same hub, drilled for the same brakes, all I have to do is switch the inner wheel bearings since these are set up for early ford axle stubs and mine has Total Performance Chevy-style spindles with the Econoline axle stub. Same bearing cup/race, just a different diameter to the inner hole that the axle shaft p***es through. Was quite the education to get to the bottom of that... Total Performance basically made any and all combos of Ford, Chevy, Econoline and maybe even Anglia axle stubs and backs, whatever the hell you call the back part of the whole spindles that mounts to the straight axle.
    I can supply pictures if needed.
  13. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, cR;
    That would be handy, & informative. Maybe if it's not too much to ask, you could do some dimensions?
    TIA.
    Marcus...
  14. chromedRAT
    chromedRAT
    Let me see what I can do! I'll be taking one of the old wheels off to see if the new wheels are true before I put the tires on soon.
  15. chromedRAT
    chromedRAT
    Ok, here goes. I tried to take the pictures aa perpendicular to the plates as possible and did my best to measure center-to-center. Didn'thave a lot of time at all this weekend Getting ready for the school year with 5 different cl***es to teach and helping dad get the hay in all summer delayed the wheel swap AND the ba*****t renovations that my wife wants finished so i tried to make a big push over the three day weekend. I got the new wheels on just in time to run it down the road before the rain picked back up. Let me know if you need anything else.
  16. chromedRAT
    chromedRAT
    Think i hit a limit.
    I'll add that the caliper holes are drilled and tapped for the caliper bolts.
    The picture without the entire caliper in view is center to center of the spindle bolts; couldn't get this stupid phone to focus on the readout.
    Just Gary likes this.
  17. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, CR;
    Thank you for taking the time n posting pics.
    Marcus...
    chromedRAT likes this.
