Hot Rods 1934 Ford panel gas tank same as Pickup?
Discussion in 'The Hokey Ass Message Board' started by modified1927, Aug 1, 2022.
  1. modified1927
    modified1927
    I have a 34 panel I finally got running and now on to making it on the road, Runs and steers and stops all original but bottom of gas tank Swiss Cheese. are the Panel tanks the same as the Pick ups? No answer from Rock Island and a no from Drake. Is that like a hard no or you need to change the fill tube? any insight would really help IMG_8892.JPG
    LOST ANGEL likes this.
  2. Fordors
    Fordors
    They are completely different, the Panel tank is under the driver’s seat, in fact it supports the seat. Standard was 10 gallons with an optional 17 gallon tank offered. ‘33 and ‘34 Pickups have the tank mounted at the rear of the frame, the filler is behind the fender.
  3. modified1927
    modified1927
    My 32 BB is under the seat and this 34 panel is at the rear with the cap coming through the body. The seats in a panel are 2 buckets and the backs fold forward. The tank is behind the axle and filler comes through the left side like a pickup.
    jd34delivery likes this.
  4. Fordors
    Fordors
    Do you know if yours might be the optional 17 gallon tank?
  5. modified1927
    modified1927
    I will be dropping it as soon as I can get the transmission back into my roadster and off the rack. Way too hard to get up and down off the floor in your 70'sI'll do some quick measurements and see how many CI I have
  6. jd34delivery
    jd34delivery
    I have a 34 panel and the tank is the same as in my 34 pickup
    Beanscoot likes this.
  7. modified1927
    modified1927
    They are the same I got the info from Tanks, but the fill tubes are different lengths the panel is longer for the wider body than the pick up bed. Found out the Vicky uses the same tank also but haven't been able to find out about the fill tube. I may just go with a gas door and not worry about it :cool:
  8. ronzmtrwrx
    ronzmtrwrx
    If the length of the neck is the only difference, couldn’t you just cut the filler neck somewhere between the tank and cap, and use a piece of gas neck hose to make up the difference in length?
  9. modified1927
    modified1927
    The filler on this style tank is threaded into the tank. I had to cut it to remove the tank since it was seized. Free now and that’s in the works, thank you
  10. Taboo56Chevy
    Taboo56Chevy
    All 32 Pickups and Trucks had the tank under the seat. 33/34 Pickups and Panels went to the rear where the trucks stayed in the cab.
    lurker mick likes this.
  11. modified1927
    modified1927
  12. rust&patina
    rust&patina
    Here's a pic's of my 34 Ford panel delivery gas tank.. 031.jpg 034.jpg 035.jpg
  13. modified1927
    modified1927
    Thank you so much, my steel one didn't survive the Radiator Hot tank, I ordered one from Tanks and will be installing it as soon as it warms up a little bit. Will be converting to 12 Volts and adding a sending unit and changing gauges
    rust&patina likes this.
