Technical **August is for a Bang of a Good Time**
Discussion in 'The Hokey Ass Message Board' started by winduptoy, Aug 3, 2022.
  1. winduptoy
    winduptoy
    Link to previous month: July 2022
    Coming Events: (PM Jiminy with additions/corrections)
    September 18 Auburn, CA NorCal F.A.S.T. Fall Hill Climb
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there maybe more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. winduptoy
    winduptoy
    Hoping that @Jiminy is OK, but thought that we needed an August thread and maybe updates from the banger bunch at Bonneville
    I haven't figured out links yet...
    Edit: did change the link to last months meet
    Old Dawg and Savage Coupe like this.
  3. denis4x4
    denis4x4
    from Colorado
    Finally got the info and parts from Randy Gross to adjust the F-100 steering on the CCPU. Seems the unit I bought 15 years ago from Mel had a different adjustment system. Kudos to Randy.
    chryslerfan55 and winduptoy like this.
  4. Back again, can’t keep away.
    winduptoy likes this.
  5. wheeltramp brian
    wheeltramp brian
    Checking in
  6. winduptoy
    winduptoy
    IMG_20220803_080218731.jpg been trying to drive them and on the last leg of about a 250 mile run, hit a railroad crossing. I was running about 35 mph. Up in the air and landed on two wheels...busted the right rear dog bone for the shock and put the fan into the radiator. I'm rethinking railroad crossing approaches
    Happy motoring
  7. noboD
    noboD
    Hope Jimmie is OK.
  8. winduptoy
    winduptoy
    Yes, me too...he was on the board on Monday morning but "June ****ed" was his last post.
    I know sometimes life gets in the way...his month off this month and then we will review the situation
    @Binger hasn't been around but I talked to him and he got a new position at work that is keeping him hopping along with starting a Model RR layout
  9. V4F
    V4F
    from middle ca.
    just same ol me
  10. Thanks for Aug thread
    Heading to Bville in a couple days
    Going with Madole coop, 4E4 tank and my VGL tank
    Will update as can
    J
    Old Dawg, Jet96, BeaverMatt and 3 others like this.
  11. 62pan
    62pan
    Checking in with a new addition to the roadster. 1949 Halibrand, this is the odd one that uses Model A bells but has 1-3/8 change gears. And before anyone comments, yes I stayed with the mechanical brakes. 20220721_092205.jpg 20220721_092222.jpg
  12. joemac05
    joemac05
    Just a note from an ol' hot rodder to say thanks for you folks who keep this thread up and running. Both the maintainers and those who post.... I don't say too much but feel right at home here each day.
    Jet96, Crazydaddyo and winduptoy like this.
  13. Crazydaddyo
    Crazydaddyo
    Hope all is well with Jimmy.
    Good luck John and the entire 4E4 group.
    Sometimes you have to do stuff just to get home.
    Lil'Alb, Old Dawg, BeaverMatt and 5 others like this.
  14. Dustyp489
    Dustyp489
    Checking in, hope all is well with everyone
    stillrunners and winduptoy like this.
  15. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Bad ***....
    From another Mechanical brake bandit...
  16. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Thanks @winduptoy for posting the meet up...
    Checking in, just been driving mine when the temps are lower than 100... Hit the ole logging roads for a new neighborhood around here,....
    Hope Jimmy is good...
    Good luck and safe travels to those hitting the salt...
  17. Stovebolt
    Stovebolt
    Checking in - no news from me.
  18. raaf
    raaf
    Present - updates coming this month.
    Best of luck to our friends headed to the salt! @johnneilson Et al!
  19. V4F
    V4F
    from middle ca.
    *** john , good luck on your trip . now you can use what you worked on all year !!!!!!!
    let them know you were there !
  20. Looks like my shopping has arrived.
    Baumi, Lil'Alb, Old Dawg and 13 others like this.
  21. winduptoy
    winduptoy
    may the 'salt gods' treat all you Bonneville bound bangers, nice...
    @patina steve is going for a record...again
  22. Kevin Pharis
    Kevin Pharis
    from Califunny
    Anyone out there have a Fronty water manifold they can pull some dimensions from...? I am looking at making something similar for my Akron-Hed conversion. I won’t be using the Fronty side drive, but instead will be routing water from the stock water pipe in an attempt to cool the hot spots I experience with the current Sherman flat head.
    I would like to make the water manifold reasonably correct, and so am asking for tube diameters, flange dimensions, and outlet angle...
    Thanks in advance!
    75121463-B3B9-4195-A39B-433306749EE3.jpeg EDD44D13-7DAC-4BEF-8CFD-664FFF06C51D.png 5A9DA63B-388F-4E92-9F90-C1C744725F22.jpeg D0153417-F998-42AE-B07F-82422967D929.jpeg D6B249F3-FFB4-4896-B93E-556E168E6A25.png
  23. set me on fire
    set me on fire
    Berts called and told me all 3 blocks I brought up are s****...bummer Im 0 for 4
    my quest continues! tally-ho
    leon bee and winduptoy like this.
  24. V4F
    V4F
    from middle ca.
    DIDTO
    Jet96 and winduptoy like this.
  25. 51 mercules
    51 mercules
    My friend just got his the other.Looks really nice.
    Dustyp489, winduptoy and hotrodfil like this.
  26. raaf
    raaf
    Santa Burtz has been making his rounds…
    Lil'Alb, Jet96, BiscayneBrain and 4 others like this.
  27. winduptoy
    winduptoy
    Got my Burtz engine together and about 500 miles on it
    Deburr everything and until you do all the edges are real sharp. Do that first unless you like to bleed
    Look everything over real critically, I found flashing and burrs that needed removed, everywhere
    Measure and verify everything dimensionally, mine was OK but I've heard stories of ones that were not
    My casting exterior was nasty rough and lots of blemishes so I ground/sanded it smooth
    You can't clean it enough and clean it one more time wash, brush and blow all p***ages. I ran a drill driven 3/8 cable with the end frayed all thru the water p***ages...the amount of casting sand was remarkable
    I used Lock***e 620 on the oil p***age plugs which are not tapered and require sealant so they do not leak
    Lock***e 5699 on the main cap bolts and main cap to block mating surfaces, nothing else for sealant but these two products...as the recommended products failed..
    These two products are all I've used in the past with great results
    DO NOT remove the tension spring for the rear main as suggested in the build guide
    Spend a little more and buy the Detroit Diesel application seal...it is silicone and usually can be found on ebay for less money, that's where I found bearing shells too..
    Buy extra shells as I had problems with the tab slots on a few
    Read the ***embly instructions multiple times but rely on your past engine ***embly experience as well
    I am reasonably happy with mine at this point but time will tell
    I know @Crazydaddyo built his but don't know if he had similar experiences...
    Good luck
    Old Dawg, G Baese, barrnone50 and 7 others like this.
  28. raaf
    raaf
    @winduptoy - this information is much appreciated!
  29. Are you going to repro these, Kevin?
  30. Kevin Pharis
    Kevin Pharis
    from Califunny
    My plan is continually evolving... but right now it’s looking like a small run of about 5 water manifolds for myself and a couple others who have expressed interest. These will be 3D printed sand molds, and so will have very little economy of scale. If you are interested, please send me an email and I will add your name to the list. I will have the ability to make more in the future, but have no intentions of maintaining inventory
    40 Olds, Jet96, Crazydaddyo and 3 others like this.
