Hot Rods Stormin Bonneville contest
Discussion in 'The Hokey Ass Message Board' started by Lucky Burton, Jul 30, 2022.
  1. hotrodjack33
    hotrodjack33
    If running a record (or near record) speed would be considered a REAL SUCCESS for @Lucky Burton ...just curious why 75% of HAMBers are predicting/rooting for failure:(. Is it just for a free T Shirt? Just seems wrong.:(
  2. ironfly28
    ironfly28
    from Orange, CA
  3. I am not going to guess, just be safe and may the Salt Gods be kind to you.
    Lucky Burton and INVISIBLEKID like this.
  4. mlagusis
    mlagusis
    I'm guessing 153.42
    Lucky Burton likes this.
  5. Stan Back
    Stan Back
    ". . . just curious why 75% of HAMBers are predicting/rooting for failure . . ."
    Well, flathead-powered entries were not now or ever rare at Bonneville. The record is from 2013 at 156. So's there's been lots of compe***ion through the years. It's definitely not a cherry-picking one at all. And it was a Lattin-Stevens entry who also hold the unblown **F record at 182, 20 MPH over the blown **F record. That're some sizable records from a well-known team. Yes, they can be beaten, but it ain't easy.
  6. K13
    K13
    Being realistic is not predicting or rooting for failure. Lots and lots of people go to Bonneyville every year hoping to break a record and lots of them don't achieve those goals. I doubt they or any of the other compe***ors consider them failures.
    kevinrevin, Stogy, Tim and 3 others like this.
  7. WalkerMD
    WalkerMD
    152.300 Good luck, God be with you.
    Stogy and Lucky Burton like this.
  8. Lucky Burton
    Lucky Burton
    Ok so we are on the road but I felt compelled to respond to this. first of all yes the record is 156. Every mph equates to dollars. I am no a rich man and did not spend 30k to go after that record. Can I do it? Yes maybe but probably not I don’t really know that’s why I do it. In no way do o think Any of these guesses are insulting! In fact a lot of these guys know Exactly how hard it is to push a flathead. At any rate this was simply to invoke some like minded guys in my quest. Supposed to be fun….
    WalkerMD, Paul, kevinrevin and 16 others like this.
  9. Ken The Coug
    Ken The Coug
    Since your doing multiple runs I am guessing for one of the early runs. 125.575 hope you knock out your personal best.
  10. RonaldR
    RonaldR
    141.329 go Lucky go.
  11. hotrodjack33
    hotrodjack33
    Sorry Lucky, I just thought there should be a lot more confidence in (and encouragement for) a fellow HAMBer. The car is absolutely beautiful...it looks like record breaker to me:):cool: Wish you all the luck possible...and a 40
    mph tail-wind (both ways) :D
    WalkerMD, Stogy and chryslerfan55 like this.
  12. Floyd Lippencott III
    Good Luck, and be safe!
    142.5 mph
  13. Lucky Burton
    Lucky Burton
    I have plenty of confidence with what I’m doing and Not sure why I need to encourage anyone here.
    kevinrevin, Stogy and Bandit Billy like this.
  14. 122.22 OK 222.22
  15. hotrodjack33
    hotrodjack33
    Sorry you mis-read my post...again refering to some of the "low speed guesses"...I should have been more clear and said:
    "I just thought there should be a lot more confidence in (and encouragement for) a fellow HAMBer...who is going for a record run."
    Stogy, Bandit Billy and chryslerfan55 like this.
  16. 62pan
    62pan
    Stogy likes this.
  17. Stan Back
    Stan Back
    Every run you make is a potential record-qualifying run. Sometimes you gotta creep up on it, maybe for a year or two or more. If you pay good attention you'll learn something on each run. Here's a not very sophisticated chart that we kept thru the years. I'm sure Lucky does this better.
    Stogy, Lucky Burton and Tman like this.
  18. Stogy, Lucky Burton and chryslerfan55 like this.
  19. y'sguy
    y'sguy
    from Tulsa, OK
    Go fast and be safe.
    127.73
    Stogy likes this.
  20. Chavezk21
    Chavezk21
    157.321. got get ya some!
    Stogy likes this.
  21. Dave Gray
    Dave Gray
    No matter what speed, have fun and be safe!
  22. Marty Strode
    Marty Strode
    For injected gas, you were quite consistent, jetting can be like balancing a BB on a razor blade, as the corrected al***ude changes in a hurry.
  23. 4psi
    4psi
  24. ENUF 41
    ENUF 41
    142.666 GOOD LUCK
    Stogy likes this.
  25. Stan Back
    Stan Back
    Thanx, Marty. We worked hard at going faster without breaking anything -- which you can certainly do on any one run. Proud to have set 4 "C" records at Bonneville over the years in a very compe***ive cl***.
    (Also glad to have had a street-licensed old car without phony headlights, doors that don't door, disappearing body seams, etc. And wrestling the records back with compe***ors that could not cut it at SpeedWeek and cheated it away at the smaller meets when no one was looking or even remembering that they were tossed out of Impound. Bitter -- until the wrongs were righted.)
  26. A Boner
    A Boner
    How much $$$$ did you dump into your flathead engine since last August?
  27. panhead_pete
    panhead_pete
    Good luck Lucky, its been awesome to follow along on your journey from a afar. Wishing you a fun and safe week and looking forward to seeing how you go!
    chryslerfan55, Stogy and Lucky Burton like this.
  28. Lucky Burton
    Lucky Burton
    It’s best not to count
