Projects Building a foldable, stowable Roadster top
Discussion in 'The Hokey Ass Message Board' started by wstory, Jul 3, 2018.
  1. 40ply
    40ply
    You'll need the top up here unless you're bringing the sun with you, it rains every second day. The profile with the top is very sinister. Love it.
    brEad likes this.
  2. Blues4U
    Blues4U
    from So Cal
    haha, sounds very familiar. I built a removable insert for my A pickup roof, because I thought I would remove it for open roof drives once in awhile. I can have the insert off in about 5 minutes or less. But I found after it was installed how much nicer the truck is to drive with the insert in place. It might be OK to open it up on nice warm evening drives, but other than that, whether it's hot or cold out, having the top closed up is far better. If I was to do it again I'd just make it permanent, no need to remove it.
  3. Six Ball
    Six Ball
    from Nevada
    Thanks for the update and the insight! When mine gets to the point where a top is an issue I'll be back checking this out again. You could always put a chin strap on your hat and wear ear muffs?:rolleyes:
    brEad likes this.
  4. RB35
    RB35
    So I've been trying to create irons for my coupster so I'd have a folding removable top. Since it was originally a Sport Coupe, the ****pit is longer than a roadster so roadster irons are too short and lengthening them would make the top fold funny. Then I added the rest of the door window frames that had been cut off and now have roll up windows and a square opening where the roadster is curved. I could get all the wood and stuff for a Sport Coupe, but that's permanent and I was trying to figure a way to do a non-folding but removeable roof. Did you know that a 7/8" dowel fits in a 3/4" copper plumbing fitting as a press fit? So while I'm waiting for the over a year back ordered Spring for the woody project, I'm going to try and ***emble something that fastens to the regular roadster fittings behind the door frame, snaps around the back of the ****pit and run dowels for framework and gives me something to staple to. If I get going with it, I'll start a thread. Last top I did was made out of a Home Depot drop cloth which flapped like crazy. Now going to add bulap stips after getting the top and rear bows braced and/or run 1/2" dowels from the top bow to the header to stiffen it up. We'll saee.
    brEad and Six Ball like this.
  5. milwscruffy
    milwscruffy
    I just think that profile is so spot on and not an easy feat to accomplish, well done !
    Tim, PONTNAK123, brEad and 2 others like this.
  6. vintagehotrods
    vintagehotrods
    I just discovered your thread and I am truly amazed and impressed with what you have created. The thoght and engineering you have put into this is incredible. I have done many miles ******* but many more with a Sid Chavers Bop Top. It was a great top but the downside like everyone says, is you can't stow it when you want to. What many people don't realize is how brutal the sun is in the Southwest. If I take a half hour drive into town with my arm out the window of my '32, I'll get it sunburned! In fact, I have an appointment at the VA tomorrow to have some precancerous lesions cryogenicly (frozen) off on the sides of my face. Without the comfort and protection of a top, it just isn't that much fun on a long trip, like when my wife and I used to do 5000 miles roundtrip to the LARS from South Dakota. My old roadster belongs to a friend now but I'm hoping to get my next roadster on the road for next year's LARS. I have stock irons for it but I'm going to ditch them and follow your path for a top. Thanks for sharing this!
  7. Giving your thread a bump Bill...'cause it's to f#@king cool not to! These are the kind of threads that make the HAMB what it is!
    I also got a kick out if the cruising shots following Connie and leading Wayne.
    Algoma56 likes this.
  8. wstory
    wstory
    from So Calif
    Thanks Bud! I'm still flirting with the idea of making the top rigid. And if I do that, I'll be able to refine the surfaces of the fabric. I was never satisfied with the conestoga wagon look when the top is tensioned and the fabric "caves" between the bows. I'd still like to see some "definition" of the bows but a much smother look.
    In the mean time, I'm focused on the header project. For those who may be interested,....check my build thread. https://www.jalopyjournal.com/forum/threads/poly-begets-a-hemi-begets-a-model-a.1194565/page-20
    Deutscher, Six Ball and Algoma56 like this.
  9. RICH B
    RICH B
    Top pads between the bows help keep the top from "caving in" at the corners. Retains a more rounded look.
  10. wstory
    wstory
    from So Calif
    Yes sir Rich,...done that. I have straps and padding. Problem is that to make my top tight, the fabric is tensioned "crosswise" and that pulls it down between the bows. :(
    Deutscher and Six Ball like this.
  11. Tim_with_a_T
    Tim_with_a_T
    First time seeing this. Totally rad. Thanks for sharing.
  12. Deutscher
    Deutscher
    from Germany
    Your skills are exceptional.
    I read through the thread and am absolutely thrilled.
    Your header construction is fantastic, too. I was also impressed by the ride the old guys took; you drove through a fantastic landscape.
    With enthusiasm, and greetings, Harald
  13. John R.
    John R.
    love threads like this, thanks for sharing.
    Tried making tight tube bends with a HF hydraulic pipe bender, got kinks. Eventually made some decent hollow-tube bends by filling the tubing with sand and making bender shoe "inserts" cut from EMT or PVC 90 deg bends to take up the difference between pipe and tube sizes.
