Technical Stanchion repair / cast bronze?
Discussion in 'The Hokey Ass Message Board' started by wandi harry, Aug 4, 2022.
  1. wandi harry
    wandi harry
    The windshield stanchion for my a model is broken at the pivot cup. I could actually just run with it as it is but l thought l may as well give it a go at repairing it.
    My first attempt was a fail ,l tried a fluxed brazing rod that l had laying around but it just would not take.
    From what l could find on the www they are made from a cast bronze,
    Cheers 23836A69-E323-4CF1-A811-1573FE14B8EB.jpeg E532ABDB-5EF8-453D-BF82-A22E5C10E1E0.jpeg 0D0D03FA-6CC3-4331-936E-C3D660879C8D.jpeg 7926FF1F-07F8-4E68-AF66-C4F1F8842223.jpeg
    winr likes this.
  2. That's a job for a Tig welder and Silicon Bronz filler rod. Well at least that's my personal opinion.
  3. I've tigged bronze with bronze rod, no issues
    gimpyshotrods and wandi harry like this.
  4. NoelC
    NoelC
    I'm going to make the long story shorter. Oxy acetylene gas, Silver brazing alloy, BAg1.
    Final answer.
    Why, because not everyone owns a Gas Tungsten Arc Welder.
    winduptoy and wandi harry like this.
  5. As above- oxy and silver solder.
  6. woodiewagon46
    woodiewagon46
    from New York
    I second the TIG with silicon bronze filler method.
  7. BJR
    BJR
    Question for those who know, why can't you braze it? The OP said he tried but it would not stick. I would think br*** would melt into bronze, what gives.
    WalkerMD and wandi harry like this.
  8. Bcap55
    Bcap55
    from PA, USA
    Like NoelC said, get some 45% BAg1 silver braze wire and the proper flux. Put flux on both pieces, **** the parts together and clamp them so they can't move if you can. Start heating the joint and watch the flux, it will dry up first then it will turn to a clear syrup. This will indicate that you are close to the brazing temp. Add more heat and try to add the filler wire to the joint, when you have reached the correct temp, the silver braze will flow into the joint like solder.
    I use this silver braze to connect regular and stainless steel parts and it will make a repair that is as strong or stronger than the base metal.
  9. NoelC
    NoelC
    You could actually, if you get it all hot enough. Key word hot enough. The difficulties will be the flux coated br*** rod, RB CuZn-C and it's composition is it's high zinc, that burns off in the high heat required to melt it all, base metal and filler into a molten m***.
    They mention silicon bronze and GTAW, well it could as well be used with oxy acetylene. Almost the same issue.
    While of a different composition, heavy copper content instead of zinc. Most ***ociate silicon bronze fillers with GTAW. But they also make GMAW silicon bronze wires.
    wandi harry likes this.
  10. gimpyshotrods
    gimpyshotrods
    TIG with silicon bronze rod IS brazing. It is TIG brazing.
    G-son and Pist-n-Broke like this.
  11. gimpyshotrods
    gimpyshotrods
    In this case I might argue that a gas torch would be better, or a whole lot of gas preheat before TIG.
    Fairly hard to reliably pre-heat with a TIG torch.
    metlmunchr likes this.
  12. wandi harry
    wandi harry
    Thanks for the feedback
    I will post up some photos when l get the right flux/wire
  13. Marty Strode
    Marty Strode
    I would Tig the areas that you can reach, and torch silver solder the valley that the Tig won't reach. That way it will look good where you see, and have the added strength in the middle.
    continentaljohn and wandi harry like this.
  14. My Granddad (he was a real Blacksmith) would tell me to throw it on the Forge and get er hot and I'll show ya one time sonny. It's all about what you have to work with, and do you know what you're doing with it.
    Okie Pete, winduptoy and wandi harry like this.
  15. Torana68
    Torana68
    from Australia
    By the looks not enough heat.
    wandi harry and gimpyshotrods like this.
  16. continentaljohn
    continentaljohn
    As said tig and silver solder will do the trick
  17. Joliet Jake
    Joliet Jake
    from Jax, FL
    Just as others have said, silver solder will do the trick. At one time I did it for a living, I used white low temp flux and a small gas torch. Even a Mapp Gas torch will work just fine in this case, which is what I now use at home. The mistake a lot of people make is thinking you need to get the base metal as hot as when you braze it, in my experience a big mistake.
  18. When in doubt, or to the untrained find out the recommended flow temp for your fill rod. Get a temp stick for that range. Now bring your base part up to it and get busy.
  19. Karl Wescott
    Karl Wescott
    If that is cast bronze... There is a possibility is was made for Wescotts in the 1970's-1990's, if so it is aluminum bronze (for high strength) and will require special attention with a tig welder to get a good weld. (pia to machine also).
    wandi harry and jimgoetz like this.
  20. ct1932ford
    ct1932ford
    That's the ticket! Wish you were close by, I would do it for you.
    Pist-n-Broke and wandi harry like this.
  21. Rand Man
    Rand Man
    I used to do a lot of Silver Solder, with Borax flux. It depends on what they call “bronze”. Some alloys have something in them that will never stick with a torch and flux. I say need to find a TIG welder with experience.
    wandi harry and Pist-n-Broke like this.
  22. NoelC
    NoelC
    Darn shame there wasn't 3 or 4 broken ones, to be fixed. Yea...then we could vote on which repair turned out best. Really, when you say, this is what I got, what I can afford, what will work, what will be the least amount of work, what will require the least refinishing, do the job, serve the purpose, please the critics and with in the skill set to accomplish the task, 3 or 4 may not be enough?
    But when it comes down to probably have around, will do the job, simple clean up, not much effort, work like a charm, most would be impressed, and the average Joe can do it...JB weld and tuck tape shouldn't be ruled out.
    I'm still voting for silver brazing.
  23. wandi harry
    wandi harry
    Just because l have oxy/acy available that’s the method l went with.
    Got hold of some silicone bronze wire 1.6mm and flux to suit. Definitely didn’t have enough heat into the first time around so l cranked it up a bit.
    The silicone bronze didn’t flow like silver solder would and l was worried about the amount of heat that l was putting into the stanchion as it was well past cherry red to get wire and base material to meld together.
    I cleaned it up and it turned out ok, could be better but good for me
    I reckon it’s a weak spot in the design so wouldn’t be surprised for it to crack again ] 7028F9A0-E9B7-4B9A-AF72-7BAD64B3E394.jpeg 0C73D0EB-7062-48CE-9F4A-EB5695EF770E.jpeg
    NoelC and Big Al like this.
  24. NoelC
    NoelC
    You got it to actually melt is what you did, and it does take a lot of heat to do so. Well done.
