Technical Spark plug reading thoughts
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Aug 5, 2022.
  1. wheeltramp brian
    wheeltramp brian
    Got a 57 Cadillac here that is all stock runs pretty good has a little rough idling. Timing is good has a pertronix in it and Autolite 85 plugs , going to do a compression test so I 16597187613698633380506216117908.jpg 16597187856494073552313757056814.jpg Pulled all the plugs to check them and they're all about the same except one. Seven of them are white and ashy on the electrode and one is a little bit red. Looking through online charts I can't really see anything in here except maybe the plugs are overheated. What are your thoughts?
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Running too lean, incorrect plug heat range or retarded timing will cause plugs to become hot and white in color.
  3. Hitchhiker
    Hitchhiker
    I agree with @Petejoe. Running way lean.
    gimpyshotrods and jimmy six like this.
  4. wheeltramp brian
    wheeltramp brian
    That's what I was thinking too. It does run fine doesn't have bad power and I can't find vacuum leaks anywhere. Going to put some new plugs in and search for some leaks and see what I come up with. Did a compression test it's equal across the board about 135 which is a bit low but they're equal so that's okay
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Check your timing too. I’d slightly advance it.
    Don’t ignore the problem just because it’s running well. You don’t want burnt valves.
  6. Fabber McGee
    Fabber McGee
    Someone may have screwed in the wrong plugs sometime. Entirely possible that every plug change since was plugs that match the wrong ones. I would check the numbers to be sure you have the right ones instead of way too hot. Just a thought.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Supposed to have AC 44
    VANDENPLAS likes this.
  8. jimmy six
    jimmy six
    Autolite 85’s are listed as the correct plug when I looked them up online and are extended tips, but I would go to an AC 44 as it was the stock plug and not extended.
    Today they say extended tips are better but were not stock in 1957. IMO Autolite’s belong in a FOMOCO not in any GM….
    J. A. Miller likes this.
  9. wheeltramp brian
    wheeltramp brian
    I just put a set of AC 45s in because I had them. Ran better but still a slight Miss. Found a bad plug wire and replaced them all and it's running smooth. Going to go drive it
    jimmy six likes this.
  10. wheeltramp brian
    wheeltramp brian
    Driving good but found that the balancer has slipped and it is retarded, don't know how much. Advanced it by ear a few times and drove it a few times and running a much better. Going to have to get the balancer rebuilt sometime soon before it completely falls apart
    kadillackid likes this.
  11. harpo1313
    harpo1313
    from wareham,ma
    With petronix being electronic shouldn't the gap be higher?
  12. wheeltramp brian
    wheeltramp brian
    They say you can open it up but I just leave it at 35 Gap
  13. jimmy six
    jimmy six
    Damper Doctor in central California turns a damper around in a day after he has it. Pleased with his work. Was $150 when I had it done a few years back.
  14. Dooley
    Dooley
    from Buffalo NY
    Petronix should be slightly bigger gap...
  15. Truckedup
    Truckedup
    F024BB53-2088-409C-AE7E-53539315F77D.jpeg how many miles on those plugs?
    Look at this plug, 3 miles of wide open land speed racing...Lean or rich?
  16. larry k
    larry k
    About 2 jet sizes from perfect , if you are runnin racing gas !!!
  17. jimmy six
    jimmy six
    Can’t see the base of the porcelain. You need a light brown ring at the bottom. The first 2 threads need to have a blue coloring..
    Personally the plug is to high a heat range. You need a lot less porcelain showing.
    what’s your compression?
    427 sleeper likes this.
  18. Mike VV
    Mike VV
    from SoCal
    You...TOO LEAN...guys don't see many spark plugs with a few miles on them do you ?
    As one guy above said, the jetting is VERY close !
    AND...without seeing down at the bottom of the porcelain, you have NO clue where the timing should be. You only see the the ground strap...that's only HALF of the story !
    Mike
  19. Truckedup
    Truckedup
    Yes leaded racing gas. Aircooled O/T bike...run one jet size rich as a hope not to go into detonation and piston seizure...Set two two speed records that day..
