Technical Help to ID a '41-'48 Ford frame
Discussion in 'The Hokey Ass Message Board' started by Kelly Burns, Aug 8, 2022.
  1. As I study these pictures, the reason I think this is a '41 is the lack of the small front cross member. But it could just be missing?
    And the "hump" in the X-member being flat, not having the X stamped into it.
  2. rusty valley
    rusty valley
    I always thought 41's were all by themselves. Really, though I am no expert on this topic
    Kelly Burns likes this.
  3. Budget36
    Budget36
    Is there a readable s/n on it? Looks clean rough to still maybe be there.
    warbird1 and rusty valley like this.
  4. The guy selling it just sent me a picture of some numbers that are hard to see, on the rear cross member. He said he would try to get something clearer for me.
    Budget36 likes this.
  5. Budget36
    Budget36
    I see part of a “star” if you look at van pelts site, you’ll know how many of the first numbers you’ll need to ID it. Tell I’m to just hand wire brush them off, I’ve had luck with spitting on my finger and wiping over them a few times, kinda makes the numbers stand out enough to ID
  6. FritzJr
    FritzJr
    The prefix was often not included in the serial number stamped on the frame in some locations. I read the number as *1513501* . That would make it a 1947 frame. The prefix would have been 799A if i had been included.
    Carter likes this.
  7. gary macdonald
    gary macdonald
    I come up with 1946 ser num being 1318501.
  8. 1947coupe
    1947coupe
    My 47 is stamped on the drivers side of the frame just behind the front crossmember.
  9. X38
    X38
    I agree the second digit is a 5.
  10. 1947coupe
    1947coupe
    Forgot to add on top of the frame.
  11. andy dewitt
    andy dewitt
    Not a 41 ,sold one a while back and the brackets on side of frame are different on a 41, the frame in question matches 46-48 which I have several
    Kelly Burns and Carter like this.
  12. choptop40
    choptop40
    thats a clean ch***is....get it while the gettins good
    Bandit Billy likes this.
  13. JROTTEN
    JROTTEN
    Kelly, that is a '42 to early '47 frame with the welded style x-member. The only difference than a '41, is the side body mounts that bolt on the side. It will also work on a '48. If you moved the front crossmember forward, you could also use it in a '41 Mercury, or a '42-'48 Mercury, with slight modifications. Hope this helps.
  14. Thank you @JROTTEN yes it does! There is a little damage where it looks like they ripped out the front cross member, but other than that this sees like a decent frame. I hope your doing well Johnny.
  15. JROTTEN
    JROTTEN
    All is good Kelly, thanks for asking, Johnny.
  16. I recently looked up frame specs and 35 to 40 cars and 40 to 41 1/2 ton trucks had the same frame. It looks like some one modified this frame for a v 8 at some time
  17. 31 Coupe
    31 Coupe
    This might help, as mentioned earlier the center X area is different.
    Otherwise your frame looks similar to my '46 Tudor one. upload_2023-1-30_21-5-28.jpeg
    Just Gary likes this.
  18. BJR
    BJR
    I'm seeing 1518501
    '34 Ratrod likes this.
  19. 42merc
    42merc
    The trans mount cross member is '42-'48.
