Technical Front carb whistles!
Discussion in 'Traditional Hot Rods' started by oj, Aug 8, 2022.
  1. oj
    oj
    This is a set of rochester triple two barrel, not original but modified to look original, the front carb whistles on throttle blade tip in. I don't see any different from it to the other two, I have adjusted the throttle blades so they are sealed when seated, none of that sealant goo was added, they set naturally tight to the venturii wall. It is not very loud but its there and a puzzle, any ideas?
    sbc with early edelbrock intake, small base rochesters.
    Thanks, Oj
    Dino 64 likes this.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    No clue, but maybe a small burr or sharp edge on the throttle blade is the culprit. Try stoning the edge of the throttle blade. Is it also possible the throttle shaft bore may be worn? Another trick may be to swap the carb positions and see if the whistle stays with the position or moves with the carb. Good luck - let us know of the resolution.
  3. oj
    oj
    Swapping front to rear is a great idea! Thanks for that Frenchie.
  4. ClayMart
    ClayMart
    Does this occur with and/or without air filter(s) installed?
  5. mustangsix
    mustangsix
    Had one that had a whistling gasket. Drove me nuts trying to find it.
    Air was getting ****ed in past the base of the carb. The carb base was just a little warped a teensy bit and needed to be tightened a bit more.
  6. oj
    oj
    No air filter, going thru initial startup/troubleshoot
    lothiandon1940 likes this.
  7. lippy
    lippy
    from Ks
    You could always put a harmonica on the other end carb. ?:D
    Budget36, Just Gary, oj and 1 other person like this.
  8. I understand the annoying part when everything looks tight and good. If I was in your spot I'd grab a 2-foot-long piece of rubber Vacc hose and go hunting. I'd set the throttle so it's making the noise, stick one end of the hose in my good ear (I only have one) and start moving the open end around the Carb in question till I located the sound. It's just like using a Stethoscope and works. Then I'd address the issue and move on to next little problem.
  9. wraymen
    wraymen
    X2, I ended up having to mill the spacer under the Autolite 2100 and installing a thicker gasket.
  10. oj
    oj
    It only does it as the throttle blades sweep open, not continuous, it sounds like that whistle in cartoons when somebody falls on their ***. I had a 4bbl that did that when the front and rear linkage was connected 1:1, not progressive, it was louder and annoying so I put the stock Holley linkage bar back in.
    Okie Pete likes this.
  11. lippy
    lippy
    from Ks
    Could it possibly be around a throttle shaft? Lippy
  12. If you squirt some ether (starting fluid) around the throttle shaft on the outside of the carb, and the RPM changes, air is getting ****ed in there and whistling dixie.
    OzMerc39 likes this.
  13. oj
    oj
    I had it back apart yesterday dealing with intermittant dribble and found the seat part of the needle & seat bore to be overly large and allowing the needle to seat at a slight angle in the bore so it wouldn't shut off the fuel proper. We'll see if the whistle is still there now that all 3 carbs are starting to work right.
    Okie Pete and Just Gary like this.
  14. Bandit Billy
    Bandit Billy
    If that doesn't work check your hearing aid batteries. Worked for a friend of mine.
    oj likes this.
  15. jimmy six
    jimmy six
    Keep the hood closed and tell everyone it a Rochester FI…. Guys set them to whistle.
