Projects BENNETTS ‘Midnight Special’ speedster
Discussion in 'Traditional Hot Rods' started by jordabennett, Mar 3, 2022.
  1. 282doorUK
    282doorUK
    Trying to predict what you'll put in the shaft center is a bit tricky, but I'm thinking I'll get it wrong......
  2. alchemy
    alchemy
    Are you going to cut threads on the rod ends and tap the drag link center tube so you can adjust the length?
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Very ***y design and excellent execution.
    On the windshield I think I'd be tempted to use a center mounted flip-up "monocle" style.
    Your cowl steering design is hauntingly familiar.
    Stogy likes this.
  4. Blues4U
    Blues4U
    from So Cal
    Creative use of a pillow block bearing.
    Stogy, Okie Pete, lurker mick and 2 others like this.
  5. You’ll never guess! Buts it’s pretty cool!
    Probably not, hahah maybe I should..
    that’s a photo I used for reference! Hence the similarity! Hahah
    Stogy likes this.
  6. Got it outside over the weekend for a better look, finished off the steering, detailed the motor and began mounting the rear fuel tank.
    Picked up some market place lockers for tools and came home with some early cycle parts and some SW gauges 2E2E8DD3-7200-47F7-9574-363ABFBD8A61.jpeg D2CF9E95-046E-490A-AAF8-D059E7166F2A.jpeg B0568BD4-0B37-4020-A78A-97651B6F3D9C.jpeg BA9492C4-57F8-4986-B17D-EC8729721F4A.jpeg 26C58B7B-BD74-4CCE-8D2D-B83B640B5A6B.jpeg 4421292B-E835-4DB1-8F0D-CEA77F4680FB.jpeg EC2AD826-C92C-4D9A-9D49-4AF83F45126A.jpeg 0D10D79E-C7B4-4E6A-ACCC-7185C98B60E1.jpeg
    brEad, ratrodrodder, Stogy and 12 others like this.
  7. ratreo
    ratreo
    2B2425E7-02FA-47AE-8D4B-1BF533FD3BED.jpeg How did you find the image of my ex-wife on a broom?
    1-SHOT, Stogy, Okie Pete and 2 others like this.
  8. Hahahahhaahah
    Stogy likes this.
  9. 282doorUK
    282doorUK
    Those bends look very vintage and appear to match perfectly, if you bent them sand filled with heat, then you're a very clever boy!
    brEad, caprockfabshop and The 39 guy like this.
  10. Dave G in Gansevoort
    from Upstate NY
    You're going to have one unique ride. And it ought to sound great with those pipes!
    Stogy likes this.
  11. Well my man Wayne nailed it sand bending the exhaust, seriously outstanding work and was great to work along side him and learn a few tricks. I picked up the car and got it back to the shop, I managed to get them all square and parallel, (what a mission) then I used some fender mounts. Cut them and bent them up to make mounts each side, after that a cut them all the 45 and flared the ends. Tomorrow I will finished off welding and blending the flanges and get them off to get nickel plated! 698417D8-004F-4B57-9886-1091995CF3B5.jpeg 23290DD0-673E-40D7-B59D-6A710CF3AECE.jpeg ECD87010-4D9A-4700-88C6-F46AF6E2F353.jpeg D4F72FF8-A602-4B41-9EF0-3EEB62DEE1D1.jpeg E28F19BF-2733-4A75-A76F-90DD12E06A24.jpeg 90A647AB-DC92-40AF-846F-1EB81A6D00A9.jpeg D4BD0FEC-F5AA-40B7-9C5A-375AE28CE29E.jpeg 8D36F171-372F-46F1-B3BE-B995AAC39EB7.jpeg C143D169-053A-49D6-B460-554DDC448468.jpeg 891208CF-49BE-4C35-A1F0-7B5DBB074821.jpeg F629FB32-A7E5-4E44-B4DE-24F2E7D3427D.jpeg EDD5FC28-1B39-4A33-A4D8-E2A76A4E5F0A.jpeg
    cactus1, brEad, ClarkH and 26 others like this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Would love to see a full left side shot with the exhaust and drag link installed.
    You've really got an eye for making everything flow.
    Stogy, The 39 guy and jordabennett like this.
  13. 282doorUK
    282doorUK
    Outstanding!
    Stogy and jordabennett like this.
  14. Ill
    I’ll snap one tomorrow!
    Stogy likes this.
  15. The 39 guy
    The 39 guy
  16. rod1
    rod1
    Jeez Dude ,you are rockin it ..
    jordabennett and Stogy like this.
  17. Stogy
    Stogy
    The Art of Hotrod...Board Track...imagine this on a Velodrome...feeling a throwback...I guess a paved raceway would suffice...sand'l do.......towed with an inspiration to the Plating Shop Carson Topped Phaeton...
  18. Amazing!
    Stogy likes this.
  19. Stogy
    Stogy
    Atwater Mike and jordabennett like this.
  20. Mark Grabo
    Mark Grabo
    from Upstate NY
    just that bracket for the exhaust is an amazing piece of art
  21. Stogy
    Stogy
    Pitman Arm?...yes that is but one of many details that pull it all together...
  22. caprockfabshop
    caprockfabshop
    Hey! **** isn't allowed on this site! o_O
  23. MMM1693
    MMM1693
    Outf---ing standing!
    Stogy likes this.
  24. 282doorUK
    282doorUK
    That looks like a LandRover steering box to me, it should work well. I used one for my cowl steering, the low ratio allows for a much longer pitman arm (mine is 12") for really quick steering but with almost no effort.
    Out on the track you won't be worrying about bump steer. But if you do, that box will allow a much longer pitman arm to help lessen the kink in the drag link and lower the actual slope between the ball joints.
    After all that I do hope it is an LR box! o_O
    Jet96 and Stogy like this.
  25. Happy I found those fender brackets while looking for other things
    Stogy likes this.
  26. Yup you’re correct, had it laying here for ages- works well, luckily I have no bump steer at all which is a bonus! Just gotta dial in the Ackerman and we’re off!
    282doorUK and Stogy like this.
  27. Atwater Mike
    Atwater Mike
    Great tribute to yesteryear! (I have a 21 stud complete engine with firing order on the head, just like this.)
    The body profile has just enough 'shoe horn' in rear, really like the fit of the tank below!
    The front fender irons just finished the lovely 'trout mouthed' pipes... I'm using the same forged brackets for headlight mounts on my street roadster...
    Truly inspiring work!
  28. R2D2 arrived.. 637BD55F-2C22-4720-8343-55B4FC427CA8.jpeg 047C13DB-82FB-45DE-A2A1-92F5D3A4902C.jpeg 9AD403EF-570F-4468-A467-DBBBCE105FD4.jpeg D6A2E780-4991-4A1D-8612-FEAC768DAB13.jpeg 70CA6851-3C9D-496C-9FCF-5DD5E911B415.jpeg 95403D13-2433-4906-9DC6-9FEDC7D7D181.jpeg 8F5B3A7F-57F1-432F-954E-8E89FAC8D40B.jpeg 610037FF-B4FE-4466-9DF9-FC360F387BC4.jpeg 43802769-C069-4BAF-84B1-FC58F4DC978B.jpeg EF54C21D-3D86-421D-BE3C-A11497512137.jpeg E5578B25-60FD-40B2-A79B-99411C48BC88.jpeg E8B852FC-8DD6-46FA-9190-E8AC58D69050.jpeg D88475DA-581A-4D21-A637-B599245D6BBC.jpeg
    brEad, ClarkH, Jet96 and 11 others like this.
