Event Coverage The Rambler Adventure-Up The River
Discussion in 'The Hokey Ass Message Board' started by squirrel, Aug 2, 2022.
  1. squirrel
    They had an optional 2bbl carb, might look into that. I could make a header for it, also....hmmmmm.....
  2. sidevalve8ba
    sidevalve8ba
    Or maybe a small turbo and a World-cl*** T-5?
  3. squirrel
    no turbo, no T5....I'm old fashioned.
  4. spanners
    spanners
  5. 427 sleeper
    427 sleeper
    It IS traditional... ;):cool::p
  6. KandN Kustoms
    KandN Kustoms
    Hey man, love reading about your adventures, and this thread!
    Don't remember if you mentioned or not but, does the rambler have the old flathead 6 in it?
    Just wondering cause I got one in a 65 rambler and having some issues with it.
  7. sidevalve8ba
    sidevalve8ba
    Jim, I hope you know I am pulling your leg! :D :rolleyes:
    squirrel likes this.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Is that the engine that has an intake manifold that is basically a flat plate that bolts straight down onto the cylinder head?
  9. KandN Kustoms
    KandN Kustoms
    Yep that's the one!
    Having trouble with it, just quit on me, has spark and fuel. So I'm thinking timing??? But can't figure out how to get TDC on a flathead.
    Sorry squirrel , Don't mean to hijack your thread....
  10. squirrel
    This car has the OHV six, in 1959 the American had the flathead six. They're similar engines, but different. here's mine. Yes, the intake has a flat plate on top that you can change to put a different carb on it.
  11. squirrel
  12. 427 sleeper
    427 sleeper
  13. KandN Kustoms
    KandN Kustoms
    Looks like a can of worms to me!
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    What are those two cut off hoses in the upper right corner of the picture, the rare heater delete?
    Stogy likes this.
  15. squirrel
    heater water valve.
    1Nimrod and Stogy like this.
  16. Mr48chev
    Cool, another Squirrel road trip story in the books.
    VANDENPLAS and 41 GMC K-18 like this.
  17. Ya couldn't leave 'well enough' alone, now, could ya?
  18. blowby
    blowby
    from Nicasio Ca
  19. That old 6 is pretty clean inside! I always thought the upside down oil filter was cool.
    hotrodjack33 and 41 GMC K-18 like this.
  20. squirrel
    It's almost ready to pull, need to disconnect the clutch linkage still. And see what the torque tube does, I put a jack stand under it in case it wants to go down, if I can get the transmission off the end of it. There are two big studs with rubber isolators that hold the end of the TT to the back of the transmission, and it has a U joint and slip yoke in the transmission also. Open U joint, closed drive line. Weird setup.
    I dont have any more 396s but there are two 454s on dollys right next to the back of the car. Just in case things go sideways.
    1Nimrod, Moondog13, Squablow and 19 others like this.
  21. DDDenny
    Ruh Roh!
    Algoma56 likes this.
  22. rusty valley
    rusty valley
    Great story squirrel, thanks for that. You are livin the good life...keep it up
  23. 427 sleeper
    427 sleeper
    Welp... atleast you have a backup plan... LOL!!! :D
    Stogy and hotrodjack33 like this.
  24. Stogy likes this.
  25. Bit messy to change.
    Ben
    Stogy likes this.
  26. squirrel
    I got it out...head off....looks like it's still standard bore, not a lot of wear in the bores either, just a couple thou at the top.
    I'll pull the pan and see how the bearings look, I'm pretty tempted to just put rings and gaskets and freeze plugs and a clutch in it. But that depends on how the rest of it looks. It might have had a valve job, I'll pull the head apart and see how things look in there, hopefully just lap the valves and be done with it.
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Offenhauser actually made a dual carburetor top plate for these engines.
    Stogy likes this.
  28. Crosley
    Crosley
    from Aridzona
    Pop up pistons ! It may be 8-1 compression ? #sarcasm
    Stogy, bobss396 and squirrel like this.
  29. squirrel
    yeah there's a new one on ebay for four bills or something...then you have to figure out the linkage, find two working carbs, etc. As long as I don't do any more mountain rallys, the single 1bbl will work ok. 20 mpg is nice, too!
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I had one earlier this year; it was one of those deals where I had to buy everything in order to get the pieces I really wanted. It went to a guy in Australia.
    Stogy likes this.
