Event Coverage The Rambler Adventure-Up The River
Discussion in 'The Hokey Ass Message Board' started by squirrel, Aug 2, 2022.
  1. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    What do you plan for brand and grade of oil when you get it back together, to avoid flat cam lobes?
    1Nimrod and Stogy like this.
  2. squirrel
    10w30 from walmart....the valve springs are small, the cam and lifters are well broken in, and despite the rumors, there's still zddp in modern oil, and it gets used up only as needed, no matter how much is in the oil.
    48fordnut, 1Nimrod, Squablow and 10 others like this.
  3. 51504bat
    51504bat
  4. SS327
    SS327
    That’s it Jim. You could build it like the Nova and call it the back up
    Stogy and VANDENPLAS like this.
  5. blowby
    blowby
    from Nicasio Ca
  6. squirrel
    way too nice :)
    1Nimrod, Stogy and 41 GMC K-18 like this.
  7. DDDenny
    Hmmm
    Wonder if a T-10 out of an AMX will bolt up to that!
  8. squirrel
    No, it's not an easy transmission to replace...and I like the three on the tree, too
  9. nickleone
    nickleone
  10. squirrel
    heh...that's my friend Tom's site. I have his number, I text him directly when I have a question, and he replies to my fb posts about the car.
  11. ClayMart
    ClayMart
    Weren't these early Rambler OHV 6s an engine designed as a sort of "conversion" based on the older Rambler flathead six short block? What a wonderfully, oddly American Motors approach to engineering a new series of engines!
    :p
    Stogy, bchctybob and 41 GMC K-18 like this.
  12. squirrel
    yeah, and they kept making the flat head version for the cheaper American for several years
    1Nimrod, Stogy and bchctybob like this.
  13. bobss396
    bobss396
    Which means it will run on carpet cleaner or lighter fluid. :cool::cool:
    '28phonebooth likes this.
  14. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Perhaps we should call it the "Rustler":D
    1Nimrod, Stogy, bchctybob and 2 others like this.
  15. KandN Kustoms
    KandN Kustoms
    Yep, the last year was 65, which is what I have.
    Wierd little motor....
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Intake manifold? We don't need no Intake manifold!
  17. squirrel
    It's half way to the Ford/Chevy integral manifold heads, but not quite as hard to modify.
    here's a picture that shows the intake manifold pretty clearly. Notice that lots of head bolts go through it!
  18. Budget36
    Budget36
    Is that a “plate” on top…i/e what the carburetor bolts onto? Or all one piece?
    Edit: I zoomed in, I can see clearly now;)
    Stogy likes this.
  19. Crosley
    Crosley
    from Aridzona
    Ok... Yes, a small supercharger may bolt on in place on intake.
  20. squirrel
    A peek under the intake plate. Pretty high tech, eh? or not.
  21. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    Of course, there's also the aluminum block version of this 196 engine, new for 1961.....
  22. squirrel
    I understand they didn't often survive
  23. I know it’s O/T, but the intake manifold plate set up is the same idea as a B model ***mins. It’s intriguing how Nash pioneered this concept.
    1Nimrod, Stogy, 41 GMC K-18 and 2 others like this.
  24. 427 sleeper
    427 sleeper
    It amazes me that they could get even fuel distribution with that wide open box! Atleast with a ***mins, all you have to worry about is airflow.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Maybe those two little kick out are acting as venturies (hope I spelled it correctly)?
    kevinrevin, Stogy, bchctybob and 2 others like this.
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The exhaust manifold looks like they stole one from a 287/327 V8.
  27. squirrel
    kind of similar, but not....the holes on mine are in a line, they aren't on the V8.
  28. sidevalve8ba
    sidevalve8ba
    Boy, I would be real tempted to mill that head some to raise the compression a little. But that's just how my mind works!
    41 GMC K-18, Crosley and pprather like this.
  29. Crosley
    Crosley
    from Aridzona
    Little bit of bowl clean up work under the valves ? Touch the port areas to clean up casting edges too?
    41 GMC K-18 likes this.
  30. sunbeam
    sunbeam
    The oil filter was easy to get to and kept the left side of the engine from rusting and generator lubed.
    1Nimrod, Moedog07, R A Wrench and 6 others like this.
