Technical multi carbs why so popular?
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Aug 14, 2022.
  1. fastcar1953
    fastcar1953
    Why are 3 duece setups so popular ? 6 carbs ? Looks or performance?
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    At the time of their inception, performance. Today, mainly for looks. When people were hopping up the new OHV V8 engines in the 1950s, there was no such thing as a four barrel carburetor that flowed enough to feed a modified engine singularly. The first four barrel carbs all flowed in the 300-400 cfm range.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Of course, dual or triple setups on inline sixes and eights are beneficial from a fuel distribution point of view.
  4. G-son
    G-son
    from Sweden
    Looks. I'm sure they perform fairly well too, but any time when you have the possibility of each cylinder being fed from unpredictable places (such as when 6 carb throats feed 8 cylinders) it won't be easy to tune it perfectly. Cylinder 3 is running lean and 4 is rich, which carb throat needs bigger jets and which needs smaller ones?
    Back in the day it was cheap and easy to grab several small stock carbs instead of finding & buying one larger that could give the same power, so that's probably a large part of what made it popular. But for actual performance and ease of tuning there's probably lots of better options now.
    KKrod, ekimneirbo and Okie Pete like this.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Three Stromberg 97s wide open still don't equal a 600 cfm four barrel carburetor.
  6. Rickybop
    Rickybop
    Technical answer...
    Cuz it's just the coolest ****.
  7. nochop
    nochop
    from norcal
    867C28B4-E906-409C-AAD9-87F713576FCA.jpeg Because they look like performance
  8. miker98038
    miker98038
    Can’t beat cool, especially when they were cheap. But by 57 the E code fords were using Holley’s , and the Merc’s Carter’s (you got what you paid for, Merc’s cost more). Later factory tri power’s used more modern 2 barrel’s. By the end of the “six pack” era they were all more modern carbs, and probably more marketing than performance. Right on the edge of OT here by year. Big 4 barrels and modern manifolds owned performance by then.
    The_Cat_Of_Ages and Okie Pete like this.
  9. HOTRODNORSKIE
    HOTRODNORSKIE
    Because two is better than one three is better than two four is better than three and so on .
    mad mikey, 2OLD2FAST, WC145 and 6 others like this.
  10. stanlow69
    stanlow69
  11. Torana68
    Torana68
    from Australia
  12. Multiple carbs that are set up properly, all working and running well are cool. :cool: Way cool. :cool::cool:
    Multiple carbs that only have one or two hooked up and working, not as cool. :( I do understand that not everyone has the time or the ability to set up and maintain a multi-carb setup. That's what 4 barrels are for. :rolleyes:
    clem, WC145, Hemi Joel and 5 others like this.
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    Some think it's cool. Some think it provides better flow. I think it's a waste of money.
  14. cabong
    cabong
    Multiple carbs are cool today. Yesteryear they were a necessity. Wayne.jpg dodge 230.jpg 371olds (2).jpg
  15. hemihotrod66
    hemihotrod66
    The car companies used multi carb setups on factory cars like J2 Olds and Tripower Pontiacs.... Duel quads were used on Cadillacs and Chryslers to back in the 50's...
    mad mikey likes this.
  16. Boneyard51
    Boneyard51
    P 59396CC3-5980-4379-8AE5-3F056D26E6BD.jpeg C6E4AB2E-FCB5-4571-B0FC-3F170CE30A41.jpeg It is a proven fact that one four barrel on an FE engine makes more horsepower that 3X2s! I am planning on three duces for my ride! Why? Because I like them!
    Bones
    1biggeorge, mad mikey, WC145 and 7 others like this.
  17. I'd like your post more than once if I could Boneyard. I have that same basic setup on my 63, have had for more years than I can count. Gas mileage ****s (what else would I expect) but it goes pretty good, runs well and looks great. :):)
  18. Boneyard51
    Boneyard51
    That’s exactly why I have been collecting for several years , trying to put together a 3x2 set up! I am slow , but I am planning a 462 with 3X2s and the long tube iron manifolds. Mostly to look like a hot rod! But I do hope it will run a little…. Also! :rolleyes:
    Bones
    mad mikey, Flyineatride, winr and 6 others like this.
  19. DDDenny
    Because the hotrodder mantra has always been "if a little is good, too much is just right".
    mad mikey, WC145, Davesblue50 and 7 others like this.
  20. carbking
    carbking
  21. Ned Ludd
    Ned Ludd
  22. carbking
    carbking
    I really need to add to that article.
    Occasionally I read where multi-carb set-ups were necessary because there were no single carburetors that would flow sufficient air. This is totally wrong!
    By 1921, Stromberg had a single barrel carb that flowed 450 CFM.
    By 1929, both Holley and Stromberg had two barrel carburetors that flowed 900 CFM!
    So how much CFM did the hopped-up Ford flathead require???
    The real reason behind the hot rod multiple carb set-ups was cost. The larger carbs were expensive, and by the late 1930's, every junkyard had Stromberg EE-1's (the 97) in quan***y, and dirt cheap.
    During WWII, Stromberg tested a two-barrel that flowed more than 1200 CFM.
    The carburetor companies would have been happy to supply the larger carburetors to anyone with money!
    Jon
  23. hepme
    hepme
    Because its the American way---big is good, bigger is better, too big is best. Would you rather look at a single 4 or 6/8 2's stacked on a log manifold sticking out of the hood?
    mad mikey, WC145 and clem like this.
  24. carbking
    carbking
    Bones - if you like 3x2 on the FE, you would love 2x4 ;)
    Jon
    mad mikey, deadbeat and Boneyard51 like this.
  25. banjorear
    banjorear
    Exactly.
  26. fuzzface
    fuzzface
    One carb isn't problematic enough for them so they need to add more.
    rusty valley, brEad, clem and 2 others like this.
  27. jimmy six
    jimmy six
    8 holes coming in, 8 holes going up and down, 8 holes going out: what’s not to like. DB177B9A-4C25-4977-A5DD-E54F9377DA6F.jpeg
  28. Taboo56Chevy
    Taboo56Chevy
    Because multi carbs look cool!
    winr, kadillackid, williebill and 5 others like this.
  29. If you have to ask, you won't get it.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Somebody needs to cancel your hot rod card ! :rolleyes:
    clem, desotot, mad mikey and 13 others like this.
