Hot Rods Essex serial number search
Discussion in 'The Hokey Ass Message Board' started by alchemy, Jun 24, 2022.
  1. alchemy
    alchemy
    I've got a bare frame I bought a decade ago from an older gentleman, and he told me back then it was an Es***. I thought I remembered him saying it was a 1931, but now I'm not so sure. I thought he signed a bill of sale but I can't find it now. His Dad bought the car new, it was a fordor, but only the bare frame was left when I got to it.
    I'd like to do a bonded ***le here in Iowa, but I'd like to at least know the correct year when I file the paperwork. The frame has a br*** tag riveted to the top of the right rear rail. It has the number 96A447**X (X's are really numerals). But that number type and sequence doesn't fit any Es*** serial number lists I can find on the internet.
    Do any HAMBers know about early Es*** serial numbers?
  2. linechaser32
    linechaser32
    from Iowa
    I have a Es*** ***le . It’s an Illinois ***le, I believe it’s a 1929
  3. squirrel
    you know you can't post a thread like this without pictures.....
    I wonder if the frame is from something else? Seeing it might help someone ID it. As you said the serial numbers of Es*** cars from around then don't look like that.
  4. 5window
    5window
  5. twenty8
    twenty8
    Primered Forever likes this.
  6. alchemy
    alchemy
    Yep, I found that do***ent. None of the Es*** numbers there, in the correct era, start with two digits, then a letter, then a number big enough to be 4 hundred thousand.
    I did find a different explanation of the way Hudson created some of their later serial numbers. They used the last number of the year as the first digit in the serial. Then a letter designating production place. So I thought maybe my frame was a 1929 with the first 9 in the serial. Maybe the next 6 means six cylinder? Then the A, and then the actual serial production number? Dunno.
    twenty8 likes this.
  7. alchemy
    alchemy
    I might be able to get a pic this weekend. It's your standard parallel leaf, straight rails, with a slight kick over the rear axle. I can tell it's bigger than a Chevy.
  8. alchemy
    alchemy
    I've looked through that website, but didn't find anything right off the bat. Maybe they have a thread hidden somewhere with serial numbers. If I want to ask a question I'll have to register as a member.
    5window likes this.
  9. twenty8
    twenty8
    Yep, and if you do register, don't mention anything about building a hot rod. It all goes silent very quickly.....
    I have just trawled all the info I have, and I don't think that number is Hudson/Es***. The serial number is stamped into the Hudson built frames. I have never heard of an attached br*** tag.
  10. alchemy
    alchemy
    You don't think they'd like to hear about the '27 Ford touring body, Model A Ford engine, or Whippet grille?
    3 springers rule!
    rod1, Tman, Just Gary and 3 others like this.
  11. twenty8
    twenty8
    From my experience, probably not.......... but I would.:)
    I went there when I was trying to identify my Hudson 1928 Model S frame and bits. Mentioned hot rod build and might have upset the apple cart.:eek: Ended up doing all the research myself to find out exactly what I had.
  12. @alchemy
    A 96A is a Willys-Overland Whippet 4 cylinder model. Your serial number puts it in the 1930 model year. And the frame serial number tag is also the correct location for a Whippet. Unfortunately its not the early model with the cool horse collar grille shell.
  13. Hudson31
    Hudson31
    My 31 Hudson does not have a br*** tag, number is just punched into the steel frame.
  14. twenty8
    twenty8
    Excellent work. Looks like you are correct, except I think 96A447**x serial number lands in the 1929 USA model range. See link below.
    https://www.wokr.org/gallery/wh96ahis.htm
  15. This was from my Willys-Overland knight registry (wokr) roster ?
    I used to be a member, maybe they updated the numbers ?
  16. twenty8
    twenty8
    A lot of this old car stuff is a little bit hit-and-miss from one source to another.
    Interpretation can vary, but at least we can get real close.
    1929 and 1930 Whippets are essentially the same, just some cosmetic changes.
  17. alchemy
    alchemy
    Wow! Now we are getting somewhere! Could you post a pic of the whole page with that info on it, in case the DMV needs some more proof?
    I guess it's even more fitting that I'd use the small Whippet grille on this car.
    Thanks!
    Tman and Just Gary like this.
  18. rusty valley
    rusty valley
    Is Iowa gonna ***le it as a Whippet ?
  19. alchemy
    alchemy
    If I have an actual frame with number, I would think they will. Worth a try.
    vtx1800 and Papas32 like this.
  20. alchemy
    alchemy
    Here’s some pics of my frame. Sorry you’ll have to turn your head on it’s side. Hopefully in a few weeks I can pile together a “car” to take pics for the ***le bonding process.
  21. Fordors
    Fordors
    I took the liberty of rotating them for you-
    F6C4A8F6-5DFC-4A57-A02B-4684CE6C0E4C.jpeg 57C9F76F-1484-4128-AA7D-25421049F50D.jpeg
    5window likes this.
  22. alchemy
    alchemy
    Here we go! Sending in the application for a bonded ***le today.
  23. Love it!
  24. Bandit Billy
    Bandit Billy
    Say what?
    razoo lew and rusty valley like this.
  25. alchemy
    alchemy
    The Iowa Department of ***le Entanglement has told me they are about five months behind on bonded ***le processing. In the mean time I have been stewing the body parts in a tank of mol***es.
    These pics are after we pulled them from the tank but before we power washed the goo off. They are **** and span now.
    SS327 likes this.
  26. Wormy
    Wormy
    Do you still have this ***le??
  27. alchemy
    alchemy
    There has been some body re***embly done on the “1930 Whippet” since last seen, but it slowed a bit after that. Hopefully I’ll get back to it this winter.
    tractorguy likes this.
  28. Roothawg
    Roothawg
    all you lack is finishing up...
