Technical Help with 256 yblock fuel pump
Discussion in 'The Hokey Ass Message Board' started by tombomb, Aug 7, 2016.
  1. tombomb
    tombomb
    The fuel pump on my 1954 Mercury 256 y block needs to be rebuilt or replaced. I am having difficulty confirming a replacement part number. Pump pictured is AC 4052. The 4070 pump works for. 239ci Fords but has Incorrect armature for 256ci. Can anyone help?[​IMG]
  2. d2_willys
    d2_willys
    from Kansas
    I would think a 239 (ohv) 272,292,312 fuel pump would work. Check the fuel pumps for any of those.
  3. tombomb
    tombomb
    The 4052 mounts upside down and has dual vacuum for the WW and the armature is different on all others I have seen. Found this pump without vacuum. However the armature is clearly different [​IMG]
  4. Merc-o-lee1951
    Merc-o-lee1951
    Hi
    Did you find another fuel pump model to fit on your Merc 256?
  5. KULTULZ
    KULTULZ
    If you are still looking, GOOGLE - B4A-9350-E -
    DBL ACTION, correct?
  6. jaracer
    jaracer
    My 54 Mercury had the same fuel pump as my 57 T-Bird with the upper vacuum section to help the wipers. They are available through the T-Bird suppliers such as CASCO in Ohio, and Larry's T-Birds in So Cal. They are not inexpensive.
    Okie Pete likes this.
