Technical multi carbs why so popular?
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Aug 14, 2022.
  1. set me on fire
    set me on fire
    the dual carbs on my straight 6 are awsome! may try it on my 4 banger
    mad mikey, WC145 and Jalopy Joker like this.
  2. Gofannon
    Gofannon
  3. carbking
    carbking
    Properly selected, and properly tuned multiple carb sets can actually boost fuel economy, depending on one's driving habits; although not by a lot, maybe 8~10 percent. And yes, I do believe it, and have proved it time and again.
    Jon
  4. 210superair
    210superair
    from Michigan
    Man I don't think I've seen it said here, but they why? ******** horsepower made the trad way man... Now don't get me wrong, my flathead has a 4bbl on it, but back in the day that wasn't an option. Anything to get more gas into the engine back then, right? So guys that build um that way now are following traditional building.
    Mark's 40 gives me a semi..... That's a real beauty.
    KKrod likes this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    T M I
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    As I said earlier, dual carburetors on an inline six will definitely deliver both more power and better mileage when in tune. I proved that one on my '53 Chevy.
    Adriatic Machine and Gofannon like this.
  7. jimmy six
    jimmy six
  8. This is hard to tune gets bad gas milage and makes the car slower than a big 4 barrel but look at it . IMG_0223.JPG
  9. 57 Fargo
    57 Fargo
    YES!!!!
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    Did someone say duals on a 4 banger...? Why...? Why not?!?!:D
    mad mikey, WC145, Deuces and 6 others like this.
  11. jetnow1
    jetnow1
    from CT
    Face it we build/drive these cars for reasons that have nothing to do with being practical. I tell my better half it makes sense to spend 10k rebuilding a 50 chevy rather than 50k on a new truck that will depreciate, she says add in the cost
    of the garage I built to do it.
    WC145 and 51 mercules like this.
  12. ekimneirbo
    ekimneirbo
    The question with any set up is whether its sized properly for the engine and then tuned properly. Getting to that point is not always easy, and often frustrating and expensive......no matter what set up someone uses.:)
    mad mikey, FishFry and carbking like this.
  13. seb fontana
    seb fontana
    from ct
    Tell the better half not to cloud the issue with facts!
    clem, mad mikey, WC145 and 3 others like this.
  14. jetnow1
    jetnow1
    from CT
    I just point to the cost of the 10 trips to Poland she has gone on for her geneology hobby.
  15. ^^ Last Man Stand comes to mind.
  16. PackardV8
    PackardV8
    When I was building the Packard V8 to go into my '55 Studebaker pickup, I said, "It's a truck and one 4-bbl is plenty." But the Caribbean 2x4 setup was on the shelf and just jumped in there when I wasn't looking.
    Why have them on the shelf; put them on the street.
    jack vines
    mad mikey, egads, 1952henry and 17 others like this.
  17. tim troutman
    tim troutman
    the guy that owned this car who is full of wisdom told me a flat head with 1 carb is an insult to your manhood top off.JPG
    mad mikey, WC145, Deuces and 4 others like this.
  18. Davesblue50
    Davesblue50
    Cause no one ever had Mr. Happy tingle at the sight of one carb?
    Ned Ludd likes this.
  19. MeanGene427
    MeanGene427
    from Napa
  20. ekimneirbo
    ekimneirbo
    If you think about it, because the intake manifolds have twists and turns and are different lengths, the idea that you can insiminate gasoline droplets into the flowing air at one central location and get exactly the same amount of fuel and air to every cylinder is rediculous.
    That said, the engine must then be tuned to get sufficient fuel to the leanest cylinder. That causes the other cylinders to receive more gas than they actually need.........thereby wasting gas and possibly reducing power.
    Having additional carbs and an intake that allow a straighter path to each cylinder allows each cylinder to be tuned individually. That may take some additional modern technology to verify, but it is doable.
    Modern engines (with fuel injection) are designed with "replicated ports" which means that each port is sized and shaped nearly identically to all the other intake ports. Older designs often had intake ports that were not spaced evenly and could not be made identical.
    So, if additional carbs are used and spaced properly, there is a better chance that you can tune them so that all cylinders receive the best/similar mixture rather than having to tune for the leanest cylinder. That COULD provide better mileage as well as more power if tuned properly. Some of the newer (98+) Chevy engines produce outstanding power while also getting very good gas mileage. If memory serves me, I think the LS7 (427) Corvettes were capable of 500 HP and well over 20 mpg.
    The problem with carbs is that the owner needs to understand how to tune them and put some effort into getting them right........and that isn't always easy to do.:)
  21. fastcar1953
    fastcar1953
    A lot of fast cars run one carb. Hardly ever see a fast 3 duece setup.
    I like the looks.
    I know early cars may have helped performance.
    Today it's about the look Imo.
    49ratfink and carbking like this.
  22. jimmy six
    jimmy six
    Way cool. There is no way having that set that I would not use it. A stock air cleaner would “top if off”.
    Center of the Galaxie likes this.
  23. Bandit Billy
    Bandit Billy
    My OT Dune buggy has twin 48’s. They look cool, they don’t run all that good. They were on it when I bought it. I would rather run a single 4 bbl and a little super charger. Sure looks good tho and I’ve spent enough on it. Or….
    It's definitely the cool factor!
  25. 2 or 3 Performance, 6 looks
  26. fastcar1953
    fastcar1953
  27. Boneyard51
    Boneyard51
    You mean this one?
  28. finn
    finn
    You have to look back to the era where the 3x2s were produced. I think Ford, for example, released 3x2 systems in 1961, over the counter. The largest available Holley was probably in the 585/600 cam at the time, so a 3x2 setup likely outperformed it.
    The last 3x2 factory setups I am aware of were the off topic 440 Mopars of 69/71. By that time, there were higher flowing single 4 barrels around. Probably a little marketing going on there, or maybe it was easier to calibrate a smallish center two barrel for emissions than one Dominator!
    Back in the flathead era I understand the desire to use a common 97 or equivalent to increase flow. Even at the end of the flathead era, there were a few small four barrels around, but the junkyards weren’t exactly overflowing with them, and the 97s and 94s were ubiquitous.
    Boneyard51 likes this.
  29. Boneyard51
    Boneyard51
    I agree with you, back it their day, the 3X2s probably did add a few ponies over the stock four barrel. But , today, with better intakes and carbs, the four barrel produces more horsepower on the FE. Check out Jay Browns intake comparing book.
    If I was going for max horsepower I would not be using the 3x2. What I AM going for is torque with 462 cubic inches. Stock heads, 3x2 carbs and factory long tube headers. The last two items, mainly for appearance! It’s a work in progress! With little progress! Lol :rolleyes:
    Bones
    mad mikey and WC145 like this.
  30. X-cpe
    X-cpe
    Whole lot of IF's and COULD's. It all comes down to an engine package of complimentary components. Vehicle too.
    rbrewer and jimmy six like this.
