Projects DB/Mopar Roadster Build or... Hodgepodge Dodge
Discussion in 'The Hokey Ass Message Board' started by Rickybop, Aug 17, 2021.
  1. gene-koning
    gene-koning
    So, remove the section of the body between both rear doors.
    Then move the rear of the car to just behind the back end of the front doors.
    Then add your turtle deck behind the back of the body.
    Then cut as much out of the frame and the running boards as needed, to put the rear axle where you think it should be with your roadster body.
    The photo shop guys would need a straight side shot of the car to be able to move the parts where they need to be to give you a picture of what it might look like.
    The next cheap way to get an image is to take a good side shot of the car, and make a lot of copies of that picture. Then take a pair of scissors and start cutting the pictures up and tape them together.
    Its really easy, until you have to actually do it...
  2. Hitchhiker
    Hitchhiker
    Time to get cutting!
    hotrodjack33, Stogy and Rickybop like this.
  3. Rickybop
    Rickybop
    You've got the idea, Gene.
    Coming up...
    Lots of measuring.
    Then I'll start cutting. But only my arts and crafts bit with the scale cardboard cutouts of the major components.
    Then look at it, think about it, live with it, sleep on it, think about it some more.
    THEN cut the metal.
    I'm scared.
  4. Rickybop
    Rickybop
    Ann. Darling.*****er Muffin.
  5. Hitchhiker
    Hitchhiker
    It's only metal. Unlike wood, if you cut it too short, you can weld it back together and make it longer.
  6. twenty8
    twenty8
    And so, the building of the "Miracle" hot rod has begun........:)
    I know of someone that would be very happy to hear you say that.
  7. Rickybop
    Rickybop
    I appreciate that.
    Somebody else here said...
    "I guarantee, the metal isn't smarter than you."
    When I had just started driving a semi truck, a more experienced driver said to me...
    "It's just a truck."
    That kind of talk helps.
  8. Rickybop
    Rickybop
    Wow, Steve.
    You got me. Made the tears flow big time first thing this morning. That's okay LOL. Kind of happy kind of sad. It's all part of it.
    This kind of talk helps, too.
    Thank you. ;)
    All the best to you and your dear Sandy.
    hotrodjack33, twenty8 and Stogy like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Rick, some how I posted the Popeye pun before I finished the photo shop work, the photo just reminded me of Popeye the sailor man, arf,arf,arf!
    Or alter ego Rickybop after eating me spinach! HRP
  10. Rickybop
    Rickybop
    I think I'll add that to the list of possible names for the roadster.
    "Popeye"
    Has a little more zip than
    "Mr Magoo"
    LOL
    oliver westlund and Stogy like this.
  11. HJmaniac
    HJmaniac
    There is a HAMB member in your neck of the woods that you should contact for some pointer. He made his first roadster using ab upside down field find 30s or 40s truck cab. A great metal man and engineer. Ask him how he did it, That might save you alot of work. Maybe a '39 - '47ish Dodge would work.
    The Frenchtown Flyer. I am sure he would like to talk with you; Hereis his profile page.
    THE FRENCHTOWN FLYER | The H.A.M.B. (jalopyjournal.com)
    He has a great 30's Indy Champ car from scratch project
    1930s Era Champ Car - new project | The H.A.M.B. (jalopyjournal.com)
  12. HJmaniac
    HJmaniac
    Make sure you don't forget Olive Oyl
  13. Rickybop
    Rickybop
    Thanks, Mikey. :)
  14. noboD
    noboD
    Jim Sibley would have that running and driving by now. What's the holdup? Get to work.
    Rickybop and oliver westlund like this.
  15. Rickybop
    Rickybop
    Leave me alone.
    Jeopardy is on.
  16. oliver westlund
    oliver westlund
    Maybe you could watch my kids so i can go work on my roadster....
    Lil'Alb, Rickybop and Stogy like this.
  17. HOTRODPRIMER
    HOTRODPRIMER
    Least we forget Rick, the magoo name is already taken, the late***** "Magoo" Megugorac was a well know Southern California roadster builder, know for 28/29 Model A roadsters on 32 frames. HRP
    The early years.
    But this is the type of cars he was well known for building. HRP
  18. twenty8
    twenty8
    My vote is staying with "Miracle"......;)
    For any that don't get it, go back and read the whole thread.........
    brEad and Rickybop like this.
  19. hotrodjack33
    hotrodjack33
    I'll take "Cutting up a Mopar" for $200, Alex:p
    brEad, Rickybop, Stogy and 1 other person like this.
  20. twenty8
    twenty8
    What is..... "The most fun you can have with your clothes on".....?
  21. Rickybop
    Rickybop
    Smart Alex :D
    Busy with chores and stuff.
    But I've been measuring measuring measuring. My mind is filled with mismatching dimensions and how I might make everything match. :confused:
    The splash aprons do a good job of obscuring the fact, but you can still see that the frame is pretty wide relative to the body, especially at the cowl. Same scenario with the 1929 Chrysler cowl. Could very well live with it and just enjoy that aspect of its persona. But it would be almost no more difficult to narrow the frame along with the other modifications likely to be made... lengthening the wheelbase, repositioning the rear rails, some boxing and an X-member.
  22. Rickybop
    Rickybop
    I inherited a vintage Erector Set from my uncle when I was a kid.
    Got the adult-sized version now.
  23. twenty8
    twenty8
    Think of it this way. You have the full scope and opportunity to alter and modify everything as required to piece it together. You are not constrained with the need to conform to a make/model direction. You have the freedom to create a truly unique, one-off hot rod. Using this mindset should actually make things easier........:)
    Stogy, Rickybop and chryslerfan55 like this.
  24. Rickybop
    Rickybop
    My thoughts as well, Steve.
    The beauty is that I have full control and I'm not constrained by a particular formula.
    The challenge and the scary part is that I have full control and I'm not constrained by a particular formula! :eek: :D
    I designed machine tools for most of my life. One important thing I learned was that things basically design themselves. The details will vary, but mostly, the designer is simply illustrating what the thing wants to be and needs to be.
    So even I'm just kind of going along for the ride here. I mean, I have a pretty good idea of what it's going to look like and how I'm going to handle some of the challenges... but not exactly.
    As we get deeper into this, the vision will become clearer! :D
    oliver westlund and twenty8 like this.
  25. bubba55
    bubba55
    Well ya knucklehead - sounds like ya need to pack yer pipe - eat some spinach and go at it once you see the light - take yer time - you’ll figure it out
  26. Rickybop
    Rickybop
    Mr. Mike.
    You get going early.
    Lazy useless old man.
    :D
    Looking forward to seeing your Model A coupe finished!
  27. Hey! , you can’t do this do me! Leaving me hanging like this, when I find the scofflaw what done this I’ll murder ‘em!!
    hotrodjack33 and Rickybop like this.
  28. Rickybop
    Rickybop
    Yes I did, Mikey. :)
    And I appreciate it.
  29. HJmaniac
    HJmaniac
    "Or maybe just small bobbed and cycle style fenders"
  30. hotrodjack33
    hotrodjack33
    Calling Ricky @Rickybop ...you OK buddy? Figured we'd be seeing a "roughed in" roadster by now;)
    oliver westlund likes this.
