Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Six Ball
    Six Ball
    from Nevada
    The older you get the more OK they are. :rolleyes:
    Stogy and JNKYARDDOG_1 like this.
  2. dumprat
    dumprat
    from b.c.
    Took the truck blackberry picking.
    Using an old truck to do truck stuff.
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
    That's one pretty little hotrod!
    nunattax, dumprat and Stogy like this.
  4. Six Ball
    Six Ball
    from Nevada
    It is so cool to see it on the road, study it, and know it's story. Thanks for sharing it with us.
    Stogy and dumprat like this.
  5. dumprat
    dumprat
    from b.c.
    Well ladies and gentlemen I think we can call this one done. The truck still needs side windows and a bunch of tinkering but I'm on to other projects.
    Should be fun! I will start a thread once I make some actual progress.
    Tim_with_a_T, Outback, Tim and 4 others like this.
  6. Six Ball
    Six Ball
    from Nevada
    Thanks for taking us along. It has been a great build with great results. Are you ready to start on my roadster now? I'm not getting anywhere. :D
    Stogy likes this.
  7. Stogy
    Stogy
    No....His roadster...I think we're jumping to the early 60s...but that may have changed...we shall see...:)
    Good on you for doing the walk in Hotrod Pickup @dumprat and having us all along for the ride...Quite a Milestone...
    dumprat likes this.
  8. Stogy
    Stogy
    I'm enjoying your adventure too...and you are moving ahead...no pressure...
    You have snakes you see...so the dynamics are somewhat different...you have to work a bit, then peak over the shoulder...oh!!!...and then there's wood...:)...LOTS of wood...but its worth it...to the audience...I do understand a wish to be closer to others for a chat in the shop or help out...meeting some distant Hambers recently at a Show was a pretty neat experience...but virtual is the status quo here for the most part and that's a close second to a local connection...;)
    brady1929 likes this.
  9. Six Ball
    Six Ball
    from Nevada
    I am chipping away and will do an update there soon, I hope. Not wood chips though. o_O
    Woogeroo and Stogy like this.
  10. Tim
    Tim
    from KCMO
    Man I was way behind. Caught up now!
  11. Atwater Mike
    Atwater Mike
    Love the 'finish'... Was thinking about brush painting my '27 Hiboy touring, '32 rails, DeSoto hemi. Pretty sure now. Gonna do it.
    Also very much like your steering wheel. (I have a close resemblance, a 15-1/2" 4 spoke plastic/rubber rim from Limeworks. Was after a 3 spoke, but everybody's out of stock. That 4 spoke sure looks good!)
  12. dumprat
    dumprat
    from b.c.
    Thanks @A****er Mike
    The finish needs a really good wetsand and repainted. I did this coat in November in an unheated garage, not ideal but good enough from 50'. I haven't done anything with the truck this winter as I have been busy with other projects. I want to put in a new oil pump and have to pull the heads and clearance the push rod holes. I'm not looking forward to that. Might change the front shocks to shorter ones. They bottom out.
    Poor truck needs a bunch of maintenance (which I'm horrible at keeping up on).
    On the way to a car show in august I had to see how far I could push it. With the speedo which is just a shade slow(about 5%) I had it up to 105mph. That's a rush! Everything gets quiet at about 95.
    Truck still had LOTS of balls at that point, I ran out.
    Not really sure how fast it will go. I was at about 1/2 throttle at 100.
    Happy new year everyone!
  13. dumprat
    dumprat
    from b.c.
    IMG_1423.JPG Pulled the front wheels and bearings today. These went over 108 mph. They have very bad rust lines and are in failure. Scary actually.
  14. OahuEli
    OahuEli
    from Hawaii
    By the marks on the races I'm guessing these bearings sat for quite a while. Definitely a "skid marks in the skivvies" moment!:eek::D
  15. dumprat
    dumprat
    from b.c.
    Good thing they had lots of grease in them.
    Stogy, OahuEli and Woogeroo like this.
  16. Toms Dogs
    Toms Dogs
    from NJ
