Art & Inspiration The History and Art of Engine Turned Material - Lets See Yours
Discussion in 'The Hokey Ass Message Board' started by Speed~On, May 17, 2017.
  1. putz
    putz
    from wisc.
    Speed On , did a amazing job for me , great guy very talented !!! Thank You , Jack
    chryslerfan55 and Speed~On like this.
  2. Speed~On
    Speed~On
    @putz Thank you for your very kind words, Jack. I'm glad I was able to turn some dash panels for you. I hope you and your father are well. Hopefully we can bump into one another at a show before the end of the hot rod season.
    @fleetside66 I was surprised at how well the copper took the Cratex. With that, the Cratex only had to contact the copper for a fraction of a second to create a great swirl. It was far easier to turn than I had anticipated.
  3. Speed~On
    Speed~On
    Sorry to post another photo of this, but I finished the copper dash today. I just had to share. And YES, copper should definitely be engine turned!!!!
    It's a copper kind of sunset......
  4. Martino
    Martino
    All I can say is Wow ! That looks Awesome !!! beautiful work !!
  5. Speed~On
    Speed~On
    Thank you so much @Martino I greatly appreciate your kind words.
    chryslerfan55 and kadillackid like this.
  6. OLLIN
    OLLIN
    Awesome thread! Here's the firewall on my old T, I used cratex and did it in metal shop cl***..
    I also made a gauge panel.
  7. Cgrgrspt10
    Cgrgrspt10
    Neat copper insert! Did you apply varnish or clear coat the copper? Would shark hide work? How to keep it from tarnishing...? Thanks
    kadillackid and Speed~On like this.
  8. Fitnessguy
    Fitnessguy
  9. David Gersic
    David Gersic
    from DeKalb, IL
    Not mine. But I spent a couple hours staring at these tables at the local laundromat the other night, now thinking maybe I want something like this for my garage.
  10. AmishMike
    AmishMike
    Be interesting to talk to store owner, track down shop that made tables ( including legs ) just for conversation & helpful hints to do yours
  11. big duece
    big duece
    from kansas
    Bar counter tops!
  12. FishFry
    FishFry
  13. FishFry
    FishFry
    Bit hard to see on that pic, but I did it - old school - by hand with a coin behind a red scotch pad.
  14. Speed~On
    Speed~On
  15. GordonC
    GordonC
    Nicely done sir!
    Speed~On likes this.
  16. Speed~On
    Speed~On
    Alllright, so I was back at it agian today. I've been meaning to the do this for years as I've always liked the look of vintage hand fuel pumps mounted with 1950's era Stewart Warner gauges. I've spent several years looking for a 2 hole panel that has a hole to fit a 2 5/8" gauge and a hole to fit an 1 1/2" pump. As you can imagine, they pretty much don't exist. so today I made my own!
    This was my afternoon project. The aluminum was not ready to engine-turn once I finished the fabrication so I spent some time buffing it on my buffing wheel. Once I had it shining like crazy it was ready. Note, this aluminum was somewhat soft. I used a Medium Grit stick and only allowed the Cratex to come into contact for about 1 second for each swirl. I'm pretty happy with the results.
  17. IMG_2277.JPG IMG_2274.JPG IMG_2281.JPG IMG_2279.JPG IMG_2280.JPG IMG_2285.JPG I made an engine-turned overhead dash plate for the three gauges on my '29 AA that I wanted front and center: the engine and transmission temperature (2-1/16") and the tachometer (3-3/8"). I started out with a 4-inch wide piece of 18-gauge stainless steel (short piece for illustrative purposes). The dash plate would be 4 inches tall and about 12 inches wide. I used a half-inch Cratex cylinder to carefully engine turn the face, then measured and spaced the pilot holes for the three instrument holes. Next I used carbide-tipped hole saws (bi-metal won't cut it, especially on the larger 3-3/8" hole) to accommodate the gauges I wanted. I needed to ensure the edges of the faceplate were tight to the underlying 18-gauge cold-rolled sheet metal overhead console so I measured and drilled 14 holes for 8-32 x 1/2" Allen head ****on bolts - nice black ones to contrast the engine turned faceplate. Finally, I attached the faceplate to the sheetmetal console, installed a couple of gauges to check fitment, put the whole thing in place above the AA windshield and confirmed the line of sight visibility. I'll add some green jewel-type turn signal indicator lights on each side of the tachometer. Not bad for just using a cutoff wheel, drill press and a couple of hole saws. I still get to keep the stock 28-29 Model AA dash, which will have the fuel gauge, oil pressure gauge, voltmeter and original speedometer/odometer/trip meter.
    Sorry about not getting the photos in order. Still trying to figure out how to post stuff.
  18. Very cool. Nice work, looks sharp
    osage orange likes this.
  19. Speed~On
    Speed~On
    So today I took the time to create a short video as I engine turned another panel. As you can see, the time that the Cratex stick is in contact with the piece you're engine turning is brief. If you allow the sanding stick to remain in contact too long you'll have swirls that take on a dark "burnt" look, which you do not want.
    https://www.instagram.com/reel/C5JqIMdP_vV/?igsh=djJvZzBmZXptNTN2
  20. gnichols
    gnichols
    from Tampa, FL
    Dumb questions of the year?
    Can you chrome engine turned panels? Or use some other sort of treatment to harden the finish?
    I’m asking because I never realized how little pressure is required to make the pattern and it would seem that after awhile the pattern might be diminished with repeated cleaning / hand polishing. Or not?
  21. Bandit Billy
    Bandit Billy
    I messed up a piece and had to sand out and re-polish the aluminum part I was playing with. It is harder than you think.
    chryslerfan55, loudbang and gnichols like this.
  22. redo32
    redo32
    1940 Buicks had dash panels that were steel engine turned and clear coated. You can engine turn br*** and flash chrome over it. If it is a steel part have it copper plated before engine turning and flash the chrome.
    chryslerfan55 and gnichols like this.
  23. David Gersic
    David Gersic
    from DeKalb, IL
    I’m pretty sure you’d lose a lot of the swirl if you tried to chrome it.
    The pattern is pretty durable. It’s scratched in to the surface by abrasive and really visible because you start with a shiny polished surface. Cleaning it won’t damage it.
    The light pressure on the Cratex is important. You don’t want to generate any heat. Heat melts the Cratex and you get burnt end of Cratex stuck in your scratches.
    Somewhere up-thread I posted pictures of a table in a local laundromat. The aluminum surface is turned, and you can imagine the abuse it takes from baskets and stuff being slid over it all day every day.
    Also, I’ve “cleaned off” some failed turning to try again. It takes a while to do, even with an angle grinder.
  24. Bandit Billy
    Bandit Billy
    I turned the shifter plate to match the dash in my roadster a couple of weeks ago.
    It is easier to take care of as it doesn't show fingerprints and light scratches.
  25. Bandit Billy
    Bandit Billy
    This panel on my truck was a pain to keep clean and scratched every time I used polish on it. So...
  26. redo32
    redo32
    Chrome is approximately 5 millionths of an inch thick. Everything shows thru it. Not nickel, not copper, just chrome.
  28. Kiwi 4d
    Kiwi 4d
    IMG_2587.jpeg A bit of crc , sand blasting sand , rubber grommet in some tube and some planning and time. I found that less sand worked better. Turned a boring wood English $15 dash into a 32 ford dash. Total cost $23 including dash. The only problem was I couldn’t see another way to attach the dash to the surround without using two small visible SS ****on head cap screws. IMG_2588.jpeg
  29. Speed~On
    Speed~On
    It's crazy to think it's been 8 years since I started this thread. Looking back I must say my engine turning skills have come a long way since then; and I couldn't tell you how many panels, guitar pick guards, and odds and ends I've engine turned over the past 8 years. Most importantly it's great seeing all of your engine turned projects, clearly I'm not the only game in town.
    I've been meaning to make an updated video on engine turning. This past weekend I made another dash panel so I thought I'd make a video do***enting the enormous amount of work I put into each panel I make. I often sell these when I'm finished and as you'll see I have a lot more time and effort into these than I'll ever recoup. I guess it's more of a labor of love.
    Please forgive my awful video editing skills....I've learned I will never be a "content creator" :D I spent about 6 hours editing this video and was up until 2:30 AM trying to get it to load to youtube....yeaahh...great.
    I included some good tips and tricks for those looking to try engine turning.
    Here is the finished dash....below is the journey I took to get it there.
  30. Bandit Billy
    Bandit Billy
    This thread taught me a new trick, thank you. Here's a project I did for one of the guys on here. I taped off the edges to leave a border around the blade. Sometimes it works better than running the pattern off the side and this allows for the edge to be sharpened without losing the pattern. Great thread!
