Hot Rods Model a gasser
Discussion in 'The Hokey Ass Message Board' started by BRENT MAGGI, Jul 18, 2022.
  1. BRENT MAGGI
    BRENT MAGGI
    Picking away at it. I’m having trouble finding a fitting that will work from the old gl*** reservoir to the new master- but will figure something out eventually. The hard lines are next. I’m waiting on a buddy to make them up then onto the rear end.
    brEad, catdad49, Deuces and 11 others like this.
  2. mad mikey
    mad mikey
    Lookin good Brent. This is a historic thread! :)
  3. Stogy
    Stogy
    Mmmmmm...bias plys....;)
  4. SS327
    SS327
    Got to be cool working on that thing in your living room. And a cool old rod to boot!
    Deuces, BRENT MAGGI and mad mikey like this.
  5. Stogy
    Stogy
    The Fever of @Moriarity...or a good deal on click flooring for the mancave...:D
    mad mikey and SS327 like this.
  6. sdluck
    sdluck
    Did you try Royal Br*** in San Jose?
    BRENT MAGGI likes this.
  7. BRENT MAGGI
    BRENT MAGGI
    Yeah I’ve been down there three times. They were going to have to stack a bunch of adapters to run a solid hardline- so I ended up having them make up 4”of soft-into a hard line where you will see it on the firewall. it should look- work good. What a pain in the *** though!
    alanp561, Deuces, Thor1 and 1 other person like this.
  8. BRENT MAGGI
    BRENT MAGGI
  9. phat rat
    phat rat
    Those traction bars are the trailing arms from a 50 Olds. I'm not sure but maybe 49-51
    bchctybob, Deuces, Thor1 and 3 others like this.
  10. benchseat4speed
    benchseat4speed
    from Golden, CO
    Cool that you found it and sealed a deal that quick! Even better that you're gonna clean it up and use what's there. That car is fantastic. So many great parts.
    Deuces, Thor1, mad mikey and 2 others like this.
  11. Stogy
    Stogy
    Two Brents with Hangin' tire, Nasty similar era A-Bones...how cool is that...it'd be epic to see ya both at the nostalgia drags...priceless...
    bchctybob, Deuces, Just Gary and 3 others like this.
  12. BRENT MAGGI
    BRENT MAGGI
    I would have liked to have found a old master cylinder but couldn’t figure out what was in the car. Hopefully not to many new parts will have to be used but I can’t save everything.
    catdad49, Deuces, Thor1 and 4 others like this.
  13. Dago 88
    Dago 88
    That coupe is killer, brings back memories of my buddy's coupe we raced about 15 years ago, 8.60 @ 160 MPH Nostalgia Drags - Ballarat 149.jpg
  14. saltflats
    saltflats
    from Missouri
    Do the front spring mounts ever want to bend being that tall?
  15. BRENT MAGGI
    BRENT MAGGI
    The car hasn’t ran since 1968 possibly longer. I guess we will find out one of these days.
  16. saltflats
    saltflats
    from Missouri
    Sounds good to me, test it first then adjust if needed.
  17. rusty1
    rusty1
    yes, this was at 2017 Meltdown Drags,...awesome car!
  18. mad mikey
    mad mikey
    Test first and see what works and what does not work so well. That is what a I had to do with my old Model A drag coupe. It was a long proses and some changes had to be made, any way, have fun with that bad *** old girl!;):)
    bchctybob, rod1, alanp561 and 6 others like this.
  19. slayer
    slayer
    I saw that coupe at the Meltdown drags. I aske the then owner if he planned to restore it back to it's original race condition or just get it running. His reply was it was to far gone to do either. Im sure i was shaking my head as i walked away.
    It realy is great to see this coupe will live again.
    alanp561, catdad49, Deuces and 7 others like this.
  20. BRENT MAGGI
    BRENT MAGGI
    He actually called me when I first got the car and said he would like to buy it back! Got the axles out today.. one came up easily- the other I ended up having to rent a slide hammer. The bearings and seals will get replaced. I haven’t decided if I’m going to do it or just drop it off and be done with it.
    9A219A3F-F0A4-44CC-8792-B2D44A1B6626.jpeg 0AD41D63-75B1-4E72-9CC7-81D0C51C0382.jpeg
  21. sdluck
    sdluck
    Axel tube may be bent,you couldn't reverse the brake drum with the lug nuts loose and use that?
    SS327 likes this.
  22. BRENT MAGGI
    BRENT MAGGI
    It came out just took a few hits
    Deuces likes this.
  23. Dyce
    Dyce
    They look like the lights on my H Farmall tractor.
  24. BRENT MAGGI
    BRENT MAGGI
    It rolls, stops and steers now. The rear end is rebuilt, the axle bearings were a pain in the ***! The rear brakes seem like they should work good. I didn’t want to put new shocks on but the old ones were blown out. The blower got completely rebuilt. The injection just needed new lines, I haven’t heard anything else on the motor yet. I want to mount the radiator and grill shell next. Has anyone came up with a way to mount them without the struts? 6AEB3C60-EFD5-43DC-97C3-7F68718466DB.jpeg
  25. SS327
    SS327
    So cool it needs to move again! And shine up those wheels!
  26. spanners
    spanners
    Burgo was lucky to step away from that end over end at Ballarat drags.
    Dago 88 likes this.
  27. mad mikey
    mad mikey
  28. BRENT MAGGI
    BRENT MAGGI
    I like that way better then running them to the firewall.
    Just Gary, 550Coupe and mad mikey like this.
  29. Dago 88
    Dago 88
    He certainly was very lucky.
    bchctybob, Thor1, mad mikey and 2 others like this.
  30. panhead_pete
    panhead_pete
    What a great car and thanks for sharing such a comp***ionate to the car build. Got to say that is the nicest garage floor I have seen! :)
    Just Gary and BRENT MAGGI like this.
