Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. HelminenHotrods
    HelminenHotrods
    from Finland
    Frame front notch was still only tack welded, so next thing was welding. Also made support plates from 3mm sheet, just for safety's sake
    -Markus
  2. Finnrodder
    Finnrodder
    from Finland
    Hey, i know that shovelhead of yours. You traded it with a friend of mine from our club.
    I did a small fixjob for that bikes frame around 2 yrs ago. The castpiece right behind the clutch was broken and i replaced it with a solid one from a donor section. I've been messing with shovels over 20 yrs and i have never seen any problems like that, but i guess everything is possible.
    Well, the bike looks good and so does your work with the model A. Keep it up!
  3. Mo rust
    Mo rust
    Very nice work. I have enough work just making roadsters out of roadsters. It seems that some of you guys can make them out of tomato soup cans.
  4. HelminenHotrods
    HelminenHotrods
    from Finland
    Hello ! Ville did tell me it had cracked and replaced. You did good job, holding on nice.
    Good reason for hardtail if it would crack again
    And thank you for compliments !
    Ja sama suomeksi
    -Markus
    Stogy and chryslerfan55 like this.
  5. Atwater Mike
    Atwater Mike
    Amazing design and fabrication work throughout, especially...Well, no 'especial'!
    The form at the cowl, the complete redesign of the flush doors, and the theme of the trunk handle matching doorhandles...and more...
    You Finnish excel at 'Finish Work!'
    chryslerfan55 and Chevy28 like this.
  6. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! To be fare, the amount of work is quite overwhelming, but i feel like this way i can do more custom features. For example doors are ~2 inchis longer, so body lines meet 32 frame lines better.
    One piece at a time !
    Thank you ! The cowl parts and trunkhandle are my favourite parts on this build. At least so far The idea is that everything flows with V-shape windshield
    -Markus
  7. HelminenHotrods
    HelminenHotrods
    from Finland
    I was not happy with original inner wheel wells. Needs something more flow'y that matches cowl shape
    After cardboard mockup shape was found:
    IMG_20220718_204315.jpg IMG_20220802_222944.jpg IMG_20220802_222932.jpg IMG_20220803_211722.jpg IMG_20220803_211614.jpg IMG_20220803_211555.jpg IMG_20220803_211503.jpg
    -Markus
  8. HelminenHotrods
    HelminenHotrods
    from Finland
    Continuing to p***enger side.
    Frames rear "horns" also needed small pinch to prevent wheel wells hitting frame.
    These new wheel wells are also ~1 inch less deeper than originals, because of the channeled body
    IMG_20220726_224651.jpg IMG_20220729_215347.jpg IMG_20220729_214332.jpg IMG_20220730_140303.jpg
    -Markus
  9. brEad
    brEad
    Very graceful shapes. Something not usually said about the model A.
  10. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! Inspiration is from later models, but trying not to over do or replice any certain model. Maybe i should name it 1931,5
    -Markus
    Deutscher, flynbrian48 and brEad like this.
  11. Sakke
    Sakke
    from Finland
    Great looking project on !!! Please post more info of progress !!! Hopefully I can see Your Hot Rod someday.
    Spooky and HelminenHotrods like this.
  12. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you sakke ! New stuff coming soon !
    If everything goes well, maybe next summer the roadster is on the move !
    -Markus
  13. HelminenHotrods
    HelminenHotrods
    from Finland
    The small boring stuff. Been making corners and getting rid of gaps, kind of "cleaning" everything so it will be easy to make floorpans once i get to it.
    These were done before inner wheel wells, just forgot to post:
    IMG_20220619_201229.jpg tight fit:
    Nothing fancy here. But a lot of unnoticeable work.
    Gaps filled :
    IMG_20220820_224146__01.jpg IMG_20220821_165823.jpg gaps filled : IMG_20220821_171928.jpg
    And gaps done:
    -Markus
    Deutscher, dwollam, itsmee and 7 others like this.
  14. HelminenHotrods
    HelminenHotrods
    from Finland
    The fun stuff again. Started building kustom rocker panels. I went little overboard with these.
    Got the p***enger side done :
    Rocker panel :
    Trim :
    Welded and cleaned up:
    With the trim:
    -Markus
  15. dmar836
    dmar836
    Wow. Great details. Nicely done!
    Chevy28 likes this.
  16. hfh
    hfh
    from Western MA
    Beautiful metal work!!
    continentaljohn and Chevy28 like this.
  17. Rickybop
    Rickybop
  18. a bloke
    a bloke
    Great workmanship, it's looking good.
    Chevy28 likes this.
  19. Sakke
    Sakke
    from Finland
    Man, That`s some awesome detailing !
    Chevy28 likes this.
  20. brEad
    brEad
    Nice detail in and on that rocker panel!
    Chevy28 likes this.
  21. dixiestillalive
    dixiestillalive
    from Georgia
    Very nice…. You should name the project “A Fin’s Fine Ford.”
    Chevy28 likes this.
  22. Atwater Mike
    Atwater Mike
    The lower rockers AND the shapely inner fender: Now, that's a flare with FLAIR!
    BUT, the rocker panel finish panels? Just 'ducky', as my daughter sued to say.
    (they say those things in California, or they 'did'...)
    Beauty is in the profile of this beautiful roadster. Went one up on the '32 Highboys!
    Chevy28 likes this.
  23. HelminenHotrods
    HelminenHotrods
    from Finland
    I appreciate all your compliments and comments, thank you !
    Got the drivers side rocker done also : IMG_20220902_231355.jpg IMG_20220902_231409.jpg IMG_20220902_231440.jpg
    -Markus
    Deutscher, dwollam, itsmee and 11 others like this.
  24. brEad
    brEad
    Beautiful!
    Chevy28 likes this.
  25. Royalshifter
    Royalshifter
    Moderator
    outstanding
    Chevy28 likes this.
  26. nochop
    nochop
    from norcal
    Pure Art.
    Chevy28 likes this.
  27. nrgwizard
    nrgwizard
    from Minn. uSA
    Very nice trim piece. What was it from? Or did you fabricate it?
    TIA.
    Marcus...
    Chevy28 likes this.
  28. Wingnut2
    Wingnut2
    Chevy28 likes this.
  29. 2Blue2
    2Blue2
    Dang... Look at that... Very Sweet
    Now I’m going outside to throw my tools away...
    05snopro440 and Spooky like this.
  30. HelminenHotrods
    HelminenHotrods
    from Finland
    I made these trim pieces from stainless steel with a bead roller. It took a while to figure out how to get the right look, but fearly simple to make once i knew what to do
    -Markus
    Deutscher, dwollam, Parnell and 2 others like this.
