Projects The Mild Customline '55
Discussion in 'Traditional Customs' started by redzula, Feb 13, 2021.
  1. guthriesmith
    guthriesmith
    Kool! Hope to see you at the Gathering!
    redzula likes this.
  2. Roothawg
    Roothawg
    200 louvers or none! Looks good!
    Outback and redzula like this.
  3. redzula
    redzula
    Might have to fight my kids for that seat lol. Let's do it.
    Outback and chryslerfan55 like this.
  4. Tim
    Tim
    from KCMO
    Heck yeah :)
  5. redzula
    redzula
    200 in just the hood that layout would be nuts lol
    Outback likes this.
  6. Roothawg
    Roothawg
    I did 175 in a 1953 F100 hood. It was pretty full fo sho.
  7. redzula
    redzula
    Welp. Finished the trans cooler. Filled with coolant primed the fuel. Started it up to do the break in. And 15 second in the radiator fan blades dug their way through the radiator basically destroying both. 5 weeks ist to the Roc and this thing just took a big step backwards.
    Need to get a new radiator
    Tempted to just go with an electric fan because now I'm afraid if I put another stock mechanical fan on it will just do the same thing and cook another radiator.
    I really hate the look of electrics but in the interest of running and driving I figure that's the way I need to go at this point.
    Anybody got any better ideas?
  8. guthriesmith
    guthriesmith
    That’s crazy! What was clearance like before startup? Almost looks like the fan hit something?
  9. Dan Hay
    Dan Hay
    I’m with Jeff, that also happened to me once. My fan hit something which bent the blade then it carved a circle in the radiator.
    I know this is super discouraging! But stick with a stock fan and shroud.
    after I zoomed in it looks like the blades hit the bottom tank, bent then got into the core. Put a shorter fan spacer on it and it’ll be fine.
    Tim and Thor1 like this.
  10. Zax
    Zax
    From the pic looks like the fan blades made contact at the circled area, bent, then contacted the radiator. But that is just judging by the pics posted.
    ****s no matter why it happened. Don't let it get you down too much @redzula we all have days like that.
    Thor1 likes this.
  11. redzula
    redzula
    Y'all were exactly right. Looks like the fan contacted the trains cooler boss. Knew it was close, hence going with a completely separate cooler for the trans, but never even considered the fan flexing while running and pulling air.
    Fan touched the drivers side boss. Bent the tip and then started cutting fins from there. at least that's my theory.
    Ordered a new radiator, electric fans, and also bought a new mechanical fan and a shorter spacer. Going to see how it goes with the mechanical fan on a shorter spacer and if all else fails I have the electric fans as a backup to get me to Oklahoma if I need to.
    In the mean time I put the car on the ground for the first time since the engine was put in.
    Ride height seems pretty OK to me.
  12. guthriesmith
    guthriesmith
    Sounds like you are headed back in the right direction! See you at the Roc!
    Thor1, redzula and Tim like this.
  13. Tim
    Tim
    from KCMO
    I’ll be sure to lean in and say “aaahh geesz some ***hole put an electric fan on this thing?!” Haha see you soon
    brEad, Thor1, redzula and 1 other person like this.
  14. redzula
    redzula
    I better not make that mistake then lol
    Tim likes this.
  15. redzula
    redzula
    That's a good eye. The tips were bent forward a little bit when I got it. Never having seen one before I overlooked that as just how they were supposed to be.
    I don't have a shroud never did... the 223 never had one either... so I'll need to make something or find one.
    brEad likes this.
  16. redzula
    redzula
    Well it's been a week.
    Bought a brand new speedway fan and shorter 1" spacer (stock I had was 2 1/8")
    New radiator and electrician fans as a backup.
    Radiator came in and was an inch taller and slightly wider than the old one. So since this is the hamb and not the restoration page. On Thursday I removed the factory radiator support and got to work building a new one that allows the taller radiator to sit further down and at the same time address the problem of it being marginally wider. Used some angle iron cut and welded to somewhat match the shape of the radiator and frame crossmember.
    after yesterday started with Nebraska embarr***ing themselves yet again, this time to an international audience. I went outside and blew off steam by finishing the radiator support i had the lower section shaped up but needed to build the vertical sections. For that u used some 1 1/4" square tubing so it will effectively space the radiator away from the engine. By the end of the day I had the support tacked together how I wanted it.
    Today i finished welding the support and painted that and the radiator. I also added rivnuts to the front end sheet metal to get rid of the captured nuts that were rusty and about half had broken out and spun making removal of the upper radiator shroud difficult. Relocated the horns because they mounted to the old radiator support but now with me spacing the radiator out they hit the backside if the grill. So I moved them out and hung them off the fender shrouds.
    With the shirter fan spacer and soacing out the radiator I now have 2 1/2" between the fan and radiator. Which is probably too much so I'll either need to make a shroud as mentioned above or get another spacer that's a little longer to fine tune Placement.
    The factory spacer will work now but the and that would close the game to about 1 3/8" between fan and radiator. But the snout on that spacer is a lot smaller than the hole in the speedway fan and I wouldn't want to cause a vibration because of that not centering properly.
    Lastly I went with a 16" fan over the factory 17" but with everything else I did I probably didn't need to do that.
    I should be able to put water in it and finally do the break in on the engine.
    Down to exhaust, 1-2 oddball electrical connections I still need to do, and driveshaft which I had made just need to pick it up.
    It's been a busy week because a**** all that I also went to Lubbock Wednesday/Thursday last week for work where we had just opened a new concept Allsup's convenience store with no gas but basic essentials like laundry soap and beer for the college kids at Texas Tech. Our store is right across the street from the main entrance to campus. That had been a whole other fiasco. With a lot of time and effort to get opened on time before school started last week. Alright that's enough rambling for me. It's dinner time.
  17. Tim
    Tim
    from KCMO
    Man your busting ***!
    redzula likes this.
  18. redzula
    redzula
    https://youtube.com/shorts/af3x2OgemOs?feature=share
    Running pretty fast but it's running in the car.
    Got an oil leak I need to seal up.
    Got my driveshaft picked up and installed.
    Just need to get it to an exhaust shop. And start driving it to see what else I need to fix before OK
    Thor1, Dos Cincos, Tim and 1 other person like this.
  19. guthriesmith
    guthriesmith
    redzula and Thor1 like this.
  20. Tim
    Tim
    from KCMO
    Sounds good man, you’re close!
  21. Rand Man
    Rand Man
    I did that radiator/fan trick on my 57 Chevy starting first time. Ouch. Keep up the good work.
  22. cabong
    cabong
    OzMerc39, LOST ANGEL, brEad and 2 others like this.
  23. Tim
    Tim
    from KCMO
    I once pulled a double! Had a Kevlar flex fan get old and flex enough to hit the radiator. Replaced the fan and fixed the radiator.
    got to the end of my driveway and the new fan flexed enough to hit the bottom tank. Talk about frustrating.
    new spacers and a very loud metal 6 blade fan from the race car catalog and we were good to go
    Thor1 and guthriesmith like this.
  24. redzula
    redzula
    Got both a 2.5" fan spacer and a 2"
    With the bigger one the fan sits about 7/8" from the fan. Thoughts?
    Thor1, guthriesmith and Tim like this.
  25. guthriesmith
    guthriesmith
    Not sure what is best. I can measure mine since it is stock as a reference point.
  26. jimmy six
    jimmy six
    No 55-56 p***enger car had any shroud. Today many have added one for better air flow thru the entire core. The factory in some areas of the country had a metal shield above the radiator and support sealed with rubber to force all the air thru the radiator while moving.
    redzula likes this.
  27. guthriesmith
    guthriesmith
    Interesting. Mine has that shield that seals to the bottom of the hood and was bought new in Colorado.
  28. guthriesmith
    guthriesmith
    Mine is about an inch from the cooler.
    redzula likes this.
  29. 57JoeFoMoPar
    57JoeFoMoPar
    There's nothing wrong with having the fan that close per se, but I think optimally, it would be about an inch further away and have a shroud. I don't even mess with those 4 blade steel fans anymore. I just figure what the biggest fan I can run is, and just order a steel 6 blade from speedway.
    jimmy six likes this.
  30. redzula
    redzula
    Any chance of a picture of this. Not picturing in my head what you guys are talking about and I'm curious lol.
