Hot Rods T-5 flathead bell and acc.
Discussion in 'The Hokey Ass Message Board' started by 750four, Aug 28, 2022.
  1. 750four
    750four
    from 47712
    Trying to piece together a 59a to t-5 ******. Speedway offers a few kits, but I wonder if anyone has fabbed a throw out fork and just bought the bearing.
    Also curious to know if I’m right thinking this T-5 is a gmc non world cl***. Any help is appreciated and respected
  2. 750four
    750four
    from 47712
    52B50044-E689-4FE1-BFC5-59E7B6B74979.jpeg 26654404-482F-4E76-BFE9-855FB816AF76.jpeg 1BE6DCDE-7A9E-4F7E-847E-28AEA4EAA0F2.jpeg DC102F0D-D891-4FEE-B2D5-6D29F8482CE9.jpeg 276C051D-3F9A-4D12-8F10-C456C625578E.jpeg DC102F0D-D891-4FEE-B2D5-6D29F8482CE9.jpeg 276C051D-3F9A-4D12-8F10-C456C625578E.jpeg 401496C4-D941-474C-9558-DE907D421E27.jpeg C90663A3-E454-4674-8882-2941FE2443F1.jpeg C90663A3-E454-4674-8882-2941FE2443F1.jpeg
  3. 750four
    750four
    from 47712
  4. gimpyshotrods
    gimpyshotrods
    We cannot tell if it is World Cl***, or Non-World Cl*** without a picture.
    Most, but not all of these kits use a T5 from an S10/S15 truck. Those were mostly Non-World Cl***, but transitioned to World Cl*** at the end of the product line.
    As for a throwout fork, not only does it need to be fairly precise, it also has to withstand a fair amount of force.
    If I had to rely on my engineering, or the engineering of a company that makes the product repeatedly, I would buy one.
    Truckdoctor Andy likes this.
  5. gimpyshotrods
    gimpyshotrods
  6. gimpyshotrods
    gimpyshotrods
    There was a tag on one of the bolts that holds the tail housing when it was made.
    In it there are a bunch of stamped numbers. One is 1352-**X, with the **X being the three-digit build code. That will indicate what gears are in it.
    That number is (was) also on the white sticker on the top cover, in one of the corners. Clean it very gently. You might be able to still read it.
    Truckdoctor Andy and 750four like this.
  7. 750four
    750four
    from 47712
    The sticker is faded and ripped beyond use. I didn’t see the tag either. I’ll double check just to be certain. If I can determine this to be a certain make chevy or gmc. Can I piece a kit together or has anyone made a throw out fork?
  8. gimpyshotrods
    gimpyshotrods
    Chevy and GMC are exactly the same. There is no distinction.
    Your transmission has the GM bell housing pattern. That, and the length of the input shaft, are all that really matter.
    You do not need to make a fork. The Speedway adapter is designed to use a GM one. Those are easy to find.
    It would take a fair amount of engineering and fabrication to save $25.
    https://www.ebay.com/itm/1253180892...QEE/9sL/hs7eQ9PrCvWil21Yw=|tkp:Bk9SR7iaiOzcYA
  9. joel
    joel
    What @gimpyshotrods said. The most important thing is the internal gear ratios; you don't want a 4 cyl. application.
  10. gimpyshotrods
    gimpyshotrods
    Put the shifter in first gear. All the way to the left and forward.
    Put a piece of tape on the top of the input shaft. Make a mark with a pen at the 12 o'clock position.
    Put a piece of tape on the back side of the output shaft. Make a mark with a pen at the 12 o'clock position.
    Turn the input shaft as many times as it takes to turn the output shaft once.
    If it is about 3-3/4 turns, then the transmission came from behind a 60-degree V6.
    If it is right at, if just a little past 4-turns, then the transmission came from behind a 4-cylinder.
  11. Mr48chev
    It looks like someone has been playing with that one a bit changing the shifter and maybe putting a Jeep input shaft in it. The teeth look more like Regular Chevy than S-10.
    This is one of the best T 5 ID charts I have found if you can carefully clean the tag enough to read it or most of it. Identification Key to Borg-Warner T5 transmission ID Tags (britishv8.org)
  12. gimpyshotrods
    gimpyshotrods
    That's a GM S10 NWC T4/T5 input shaft
    21 tooth/14 spline
    It fits in the 1984-1992 T4/T5 S10 S15 Sonoma transmission.
    Part# 1352-085-003
    The input bearing collar is S-truck specific, and is the only one with that length.
    Part# 1352-027-003
  13. 750four
    750four
    from 47712
  14. dirt car
    dirt car
    from nebraska
    Not familiar with them & could be otherwise but looks as if it got a bit toasty.......
  15. patterg2003
    patterg2003
    gimpyshotrods likes this.
  16. nickleone
    nickleone
  17. gimpyshotrods
    gimpyshotrods
    No other differences.
    750four likes this.
  18. gimpyshotrods
    gimpyshotrods
    Standard top engine oil leak.
  19. 750four
    750four
    from 47712
    Ya, it’s covered in dirt and grime. No shifter top on it when I bought it, so I threw that cheap short shifter on it. If this has the correct ratio I’ll be excited. I have about $100 in the thing now. Internals appear clean and not worn.
  20. Budget36
    Budget36
    @krylon32 (which I think is cornhuskers) has the kits listed in the cl***ifieds right now.
  21. gimpyshotrods
    gimpyshotrods
    Even if it is not the "right ratio" it will still work.
    Since you mentioned a quick change, you can adjust there for best performance, based on how and where you drive the car.
    firstinsteele likes this.
  22. Kevin Lee
    Kevin Lee
    Super Moderator
  23. Kevin Lee
    Kevin Lee
    Super Moderator
  24. Mr48chev
    Speedway's kit is pretty well a knockoff of Cornhuskers kit. His kit looks spendy until you start adding up all the pieces that are in it and figure that you don't have to go hunting for a lot of extra parts.
    Still one has to decide if they are going to run a Flathead Ford style clutch release arm that the pedall turns the shaft that pushes the throwout bearing or a later style that runs fork and pushrod setup.
    Nailhead Jason and gimpyshotrods like this.
  25. 750four
    750four
    from 47712
  26. Budget36
    Budget36
  27. 750four
    750four
    from 47712
    Sorry! I don’t mean that comment to read like I think anyone is shady. I have messaged the guy, I wanted to know if it’s a good complete kit. That’s all
    Thanks
  28. 38bill
    38bill
    from Minnesota
    Bought my kit years ago from Gary at Cornhuskers. I'm using the stock Ford throw-out system with a adaptor bushing that came with the kit. The hard part was sourcing the proper diaphragm pressure plate for the stock, large TO bearing. I believe Gary may have a source now. Your ****** appears to have the electronic speedometer sending unit. If you want to use a std mechanical speedometer you will need to make some modifications or purchase a special converter.
  29. krylon32
    krylon32
    from Nebraska
    My early bell housings were not notched out for the starter and the customer had to do it, no big deal just a little grinding with a 4 inch grinder. On the pressure plate the fingers need to be shortened so they work with the large Ford TO bearing and don't grind down the hub. Originally the diaphragm PP that works as is was a CA30.
    750four likes this.
  30. 750four
    750four
    from 47712
    Sooo, as far as that flywheel set up is concerned. I guess I figured that people were using more of an s10 clutch set up to a ford flywheel. On a different note, is a 10” flywheel optimal for a flathead. I’m building my flathead naturally aspirated. 3 duece, 97’s. edelbrock heads and a 3/4 cam. I’d love to have that idle that’s probably way to low rpm and a with good throttle response. Thanks again y’all and have a great and semi safe long weekend.
