Technical Hard line bending tools
Discussion in 'The Hokey Ass Message Board' started by chiro, Aug 26, 2022.
  1. Kevin Pharis
    Kevin Pharis
    from Califunny
    Good call Gimpy! And if one does remember to put the tube nut on, double check the direction the threads are pointing before you flare!
    TrailerTrashToo and X-cpe like this.
  2. bathcollector
    bathcollector
    I would put money on it being the same tool. The guy I gave it to has never come back to the shop to know if he used it or not.
  3. Budget36
    Budget36
    I know I used it on a few trucks and some tractor stuff, I don’t recall it being difficult to use or making poor bends. I’ll look around for some old line and make a few bends. I just didn’t have anything close by when I grabbed it for a pic.
    Guess it’s been awhile since I used it, the top two rollers don’t roll anymore;)
    bathcollector likes this.
  4. TRENDZ
    TRENDZ
    Another trick some of you may want to do…
    I modified my bluepoint bender to bend at the nut also. A little cutting/clearancing, and an internal mandrel to rest against the tube stop. 6ED51159-827A-4212-927B-14B7A9A65ABF.jpeg 2F591477-C242-46B5-BE3D-B140CE2DCDB1.jpeg 30976669-D8A9-47DF-BF90-26548F009CCF.jpeg E0E4AEB7-9A32-444D-A294-CB5000FD1E73.jpeg
  5. TRENDZ likes this.
  6. RICH B
    RICH B
    I have Imperial tubing benders for 3/16", 1/4", 5/16", and 3/8". All bought used on the auction sight for cheap. Just watched and waited for a non-crazy or poorly listed auction.
    Seem much better than the one size fits all benders.
    Now they have that limp ni-cop stuff you can bend any which way. But it doesn't have the dead straight look on the long sections.
  7. Blue One
    Blue One
    from Alberta
    I buy the Nicop tubing in pre made lengths straight sections up to 72” long. I did have some in rolled form that was really easy to get just as straight as any other tubing with my tubing straightener.
    My entire RPU is plumbed with it. Really great stuff.
    egads likes this.
  8. Blue One
    Blue One
    from Alberta
    Somehow the thread drifted over to flaring tools.
    I had one of those Mastercool kits, bought it brand new and I hated it.
    I found it difficult to impossible to determine how much hydraulic pressure to apply each time to get a perfect flare.
    There seemed to be no way to get it figured out and then repeat it with the next flare.
    I sold it and bought the flaring tool from Eastwood and it’s really good.
    Easy to make perfect double flares every time. :cool:
    TrailerTrashToo likes this.
  9. milwscruffy
    milwscruffy
    Imperial for me, 3/16" , 1/4" and 3/8". Never had much call for 5/16" except for transmission lines, so never got that size. Also have a Mastercool kit for flares and love it for 10 years now.
    egads likes this.
  10. Harv
    Harv
    from Sydney
    Damn that's clever. :cool:
    Cheers,
    Harv
    TRENDZ likes this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’m sorry to hear that you had a poor experience with what I feel is a fantastic tool. As I stated before, it’s not perfect as the dies can take 3 hands to load.
    Almost all the dies are set up to close up as a hard stop, and have built in length setting by aligning the tube flush with the end of the die set. The only dies that are not setup as a hard stop are the flaring cones. These cones do require a “feel”, but no different than any other flaring tool. The goal is to form the tube , not crush it. The hydraulic advantage does make it easy to crush the tube tho
    Makes me curious about the Eastwood tool... which one are you using..?
    egads likes this.
  12. Blue One
    Blue One
    from Alberta
    This one. Works really great.
    https://www.eastwood.com/professional-brake-tubing-flaring-tool.html
    jimmy six likes this.
  13. Kevin Pharis
    Kevin Pharis
    from Califunny
    Check that thing out!!!:cool:
    Chavezk21 and Blue One like this.
  14. TRENDZ
    TRENDZ
    I sawed off a large chunk which worked for the smaller sizes, but I did need to use an end mill to make clearance for the 3/8 nuts.
    '28phonebooth likes this.
  15. Dedsoto
    Dedsoto
    from Australia
    how are you guys putting coils in your lines? This was the easiest means I had available
    seb fontana, vtx1800, Bleach and 13 others like this.
  16. I looked at this before buying the Mastercool and there is a lot to like. The major flaw IMO is there's no way to do a flare 'in place', the tool has to be clamped into a vice. The Mastercool, while a bit clumsier, can do flares on the vehicle if there's room to get it in there.
    I've had zero issues with mine, and my new friends love it... LOL
    jvo, Blue One and milwscruffy like this.
  17. milwscruffy
    milwscruffy
    Eastwood must have thought the same thing seeing they now offer this one also,
    Item # 31562 BRAND: Eastwood upload_2022-8-30_10-45-3.png
    Chavezk21 likes this.
  18. Blue One
    Blue One
    from Alberta
    Valid point however for me I was building my RPU and didn’t need anything to flare in place.
    It’s the best flaring tool I’ve ever used for making new lines.
  19. Thanks for the reply!
  20. X-cpe
    X-cpe
    What i have collected over the years. The black is a replacement for the red one because plastic ones don't like having chunks removed to get bends close to the nut. The center one has an aluminum mandrel that didn't mind having a quarter removed.
    Idea is not original to me. Don't remember the source. But, they are handy when it comes to figuring out where to position the bender to get the out leg to lay tight where you want it. Need one for whatever diameter tubing you are bending. Take a s**** of tubing, mark it and place it in your bender with the mark on "0", then pull the desired
    bend. Run your tube, lay the jig where the bend needs to be and mark the tube. Put the marked tube on zero in your bender and and bend away.
    Donut Dave, vtx1800 and saltflats like this.
  21. Jmountainjr
    Jmountainjr
    Since this has gotten on a flaring discussion, all that I will add is be aware of the tubing you are buying. I have a number of flare tools from the old double clamp bar to the newer Eastwood like tool that use a split clamp block. The newer tool works like a charm as long as the tubing OD is on spec. I have found tubing from several sources that 3/16" tube is undersized. It's in the 0.184" to 0.185" range and not 0.187". The clamp blocks on the newer tool doesn't clamp the undersized tubing enough to prevent it being pushed out of position when forming the flare. The old double bar tool still works OK. So I now take calipers with me when shopping for tubing or by online from the one or two places that sell spec tubing.
  22. Atwater Mike
    Atwater Mike
    A friend had this problem, so wrapped some black electrical tape around the clamp area.
    I winced, but it did work...
    RICH B likes this.
  23. 57JoeFoMoPar
    57JoeFoMoPar
    I have a set of Ridgid benders that are very similar to the Imperial Eastman. I have used both over the years and they are both excellent.
  24. jimmy six
    jimmy six
    Blue One likes this.
  25. nochop
    nochop
    from norcal
    From this mess on the bench, to this. 763D9FE6-CA30-44BA-9EAE-CBF28B518C4C.jpeg EFE5E70F-2B56-4013-A7C3-74459D965D7A.jpeg
    Budget36 and Butler 32 like this.
  26. sidevalve8ba
    sidevalve8ba
    My friend Tom T turned me on to the wonders of this little Lisle tubing bender. The only drawback I have found on this one is that the largest size tubing it will bend is 3/16".
  27. Mr48chev
    stanlow69 and 31 B'ville like this.
  28. theHIGHLANDER
    theHIGHLANDER
    Cheats, always grease it for stainless. Sometimes bend in very short steps for less crush in the center. Go up 1 size for a bigger but consistent radius on smaller stuff, and again, grease the shoes. I bent ½" ½ round solid stainless with my bender. Taped it together with nylon packing tape, greased it, needed a cheater extension pipe, took my time, got 2 exact trim pieces for this:
    Wanted to emulate the outer side trim inside. Worked like a charm. Solid ½ round...:eek:
