Technical Buick drums on Ford backing plates
Discussion in 'Traditional Hot Rods' started by gearhead695456, Aug 31, 2022.
  1. gearhead695456
    gearhead695456
    Im trying on my buick finned drums, I ***ume I need to trim the backing plates some? It rubs if you tighten down the hub nut. (Ignore the wheels/tires, theyre just on do to a test fit.) Thanks
  2. flynbrian48
    flynbrian48
    The "lip" on the inside of the drum has to be machined off. It's about 1/4" deep. I have 4 of 'em on Wilson Welding backing plates, two are new reproductions. I have one that still kisses a spot on the backing plate, and had a little lip left from machining that looked like the culprit. That drum has a tiny bit of run-out, and cornering hard it still hits. I'm gonna have to put in a lathe and take a little more... B993B389-B7F8-4FCC-A26E-421D493ECB21.jpeg 3B235103-6974-462F-8674-7E77D250A4AB.jpeg
    ratrodrodder likes this.
  3. deucemac
    deucemac
    Just like flyinbrian48 said. I had to do the same thing. I used a small end mill in my drill press, mounted my drum and hub on a spare spindle, squeezed the spindle nut into a drill press vice and cut the relief back on the Buick drum until I had a small amount of clearance. Bingo! 40K miles later it's still good even around corners when things flex.
    ratrodrodder and gearhead695456 like this.
  4. gearhead695456
    gearhead695456
    Awesome!!!! Thanks guys so if I understand is this the lip you refer to?
    flynbrian48 likes this.
  5. gearhead695456
    gearhead695456
    And this is the lip marked in red on mine?
  6. Roothawg
    Roothawg
  7. RICH B
    RICH B
    Cut the aluminum to clear the lip; but leave the iron liner for the shoes to act on.
  8. RICH B
    RICH B
  9. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Have done dozens of this conversion using the Buick drums with 46-48 hubs. The machine work is relatively easy for a savvy machine shop. I've done it with early Ford backing plates, F250 backing plates, Wilson Welding and MT Lincoln backing plates. All have worked out good.
    gearhead695456 likes this.
  10. Joliet Jake
    Joliet Jake
    from Jax, FL
    Drop by some day and I'll show you mine. I'm using 46 backing plates and spindles.
  11. gearhead695456
    gearhead695456
    @Joliet Jake I'd like to come by one day see your project too. Thanks man! Nick
  12. deucemac
    deucemac
    The lip I was referring to was the groove between the braking surface and the fins. You may have to narrow the braking surface if it contacts the backing plate. This operation is easily accomplished on a brake lathe .
  13. deathrowdave
    deathrowdave
    from NKy
    Does anyone make an after market Buick style drum to work with the F2 backing plate . Thanks for the help , I have read this somewhere but it’s long gone again , from my overloaded brain .
  14. Splitbudaba
    Splitbudaba
    They do look very cool when completed! FCAB038A-7BDC-4F68-A1EE-6459227FE931.jpeg
  15. BJR
    BJR
    If you are using Lincoln backing plates I have machined off the inner ring to give the Buick drum room without rubbing.
  16. RICH B
    RICH B
    The cast iron replacement front drums that Kanter marketed were the only thing I've heard of that matched the aluminum drums in size; but not appearance
  17. neilswheels
    neilswheels
    from England
  18. RICH B
    RICH B
    Boling Bros regular and fin trimmed drums will fit Ford hubs; just have to add press in studs.
  19. deathrowdave
    deathrowdave
    from NKy
    So help me Bowling Bros will fit F2 backing plate and F1 hub ? I hate to be a pest , just need help before dropping the lunch money . Thanks again
  20. RICH B
    RICH B
    No; Boling Bros drums are designed to work with Ford Lockheed or repop Lincoln style brakes.
    F-2 plates have lesser dish than the above plates; the plates are also a little larger in diameter and will not line up with the groove in the drum.
    The drums can be adapted with some work to the edge and along with a machined spacer. Maybe not the coolest deal; but less change to the scrub than all the disc brake kits that bump the wheel out an inch per side or worse yet those thick spacers people like to put '35 wires on flat face drums.
    rusty valley likes this.
  21. deucemac
    deucemac
    You don't need an aftermarket Buick the drum to run F2 backing plates. I used regular 59 Buick drums, Wilson welding hubs, 1950 F2 backing plates , #33 brake shoes, and mid 60s F250 wheel cylinders. It took some very minor main work to have the drums and backing plates not rub on each other, but I accomplished everything using my drill press an end mill, and a brake lathe . Less than an hour total. 15 years and 40k miles later, it still stops straight and true.
    deathrowdave likes this.
  22. deathrowdave
    deathrowdave
    from NKy
    Thank you , for the needed info .
    deucemac likes this.
