Folks Of Interest Early Stewart Warner gauge thread
Discussion in 'The Hokey Ass Message Board' started by Pat Pryor, May 13, 2016.
  1. Scramboleer
    Scramboleer
    Yes, please.
    Speed~On likes this.
  2. kadillackid
    kadillackid
  3. Beanscoot
    Beanscoot
    Funny enough, a couple months ago I took out my instrument panel to change a couple burnt out lamps, and forgot to reconnect the speedo. I haven't reconnected it yet, since I'm too lazy to take the panel out again. So I guess I'm not an amateur, for now!
    rod1 likes this.
  4. fleetside66
    fleetside66
    Can you just take the cable & reconnect it while everything is in place? If you don't know how fast you're going, the "man" is gonna get ya!
    big duece likes this.
  5. Speed~On
    Speed~On
  6. fleetside66
    fleetside66
  7. alchemy
    alchemy
    A dozen years ago I bought about eight NOS rear mount water temps like above, but mine had black bezels and ten foot senders. Probably from a wartime boat. They were wrapped in cosmoline soaked fabric.
  8. big duece
    big duece
    from kansas
  9. Speed~On
    Speed~On
    Came across a few more antique Stewart Warner parts desk display signs.
  10. kadillackid
    kadillackid
    Wow, nice display!
  11. n.w. suede
    n.w. suede
    from Arkansas
    I have this early Stewart Warner speedo that I know nothing about I have been told that it might be foreign or possible early motorcycle i am just not sure. mounting hole looks to be 3 1/2" and the speedo cable is pictured with the it and is heavy duty
  12. alchemy
    alchemy
    Valette is a French word. The sender end of the cable is weird, not like any I've seen before. And that cable is rather short. I bet it's for a motorcycle, in kilometers not MPH.
    stillrunners and kadillackid like this.
  13. n.w. suede
    n.w. suede
    from Arkansas
  14. big duece
    big duece
    from kansas
    Anyone know what thread size the prewar SW oil pressure gauge uses? an4?? thumbnail - 2023-02-07T211701.044.jpg
    stillrunners likes this.
  15. dumprat
    dumprat
    from b.c.
    Looks 45 degree taper, not 37. Will be standard br*** compression fitting .
    Okie Pete and big duece like this.
  16. Beanscoot
    Beanscoot
    I think you mean standard br*** flare fitting.
    Okie Pete and pprather like this.
  17. big duece
    big duece
    from kansas
  18. pprather
    pprather
  19. RICH B
    RICH B
    Or stack a female 1/8" NPT to 3 AN adapter on that Parker fitting you linked. Could also hack off the male NPT on the Parker fitting and cut back a male 1/8 NPT to 3 AN fitting and braze the two parts together to make one fitting. Used to make metric to JIC hydraulic fittings that way years back.
  20. big duece
    big duece
    from kansas
    No, the fitting can not be removed from the gauge. It's one with the gauge. The link for Amazon is incorrect too, the fitting I need is female flare to male npt.
    Rich... yes once I got the gauge adapted to male NPT, I planned to find a fitting to AN fitting. I have 3AN here and its too small, most likely a 4AN. I like your suggestion regarding combining fitting to make one. Man, I love this place... I don't care what my neighbors think.
  21. big duece
    big duece
    from kansas
    Prather, thank you for the link of the flare nut. Once in hand, a simpler idea might become clear.
    pprather likes this.
  22. 41woodie
    41woodie
    Just saw these on everyone's favorite auction site. They are marked Stewart Warner and made in USA. Anyone know if they were aftermarket or an OEM item on some car? Not my auction btw
    rod1, elgringo71, Okie Pete and 2 others like this.
  23. big duece
    big duece
    from kansas
    Those are cool...never seen before.
  24. Joe Blow
    Joe Blow
    Okie Pete and Carter like this.
  25. alchemy
    alchemy
    Woodie, those are boat gauges.
  26. big duece
    big duece
    from kansas
    I did confirm the early SW oil pressure gauge is 1/4" flare fitting... but had to build one from scratch. I can elaborate more in PM if anyone wants to know without cluttering up this thread. thumbnail - 2023-02-07T211705.903.jpg thumbnail - 2023-02-10T175812.616.jpg thumbnail - 2023-02-10T175817.863.jpg thumbnail - 2023-02-10T175832.189.jpg thumbnail - 2023-02-10T175837.926.jpg
    e1956v, rod1, Okie Pete and 2 others like this.
  27. pprather
    pprather
    That looks like it will work!
  28. Speed~On
    Speed~On
  29. Artful_Dodger
    Artful_Dodger
    from new jersey
    Just got them all working again.
    Okie Pete, enloe, AldridgeDW and 5 others like this.
