Technical "Gasser" Straight Axel on Coilovers
Discussion in 'The Hokey Ass Message Board' started by FunnyCar65, Sep 3, 2022.
  1. FunnyCar65
    FunnyCar65
    from Colorado
    Wanting to put a straight axle under the 55 Plymouth I bought. Leaning towards a 4 bar with coilovers instead of the standard me to parallel leaf setup. Need photo ideas and the does and don't of a proper setup.
    Not knocking the parallel setup I've installed a few under altered wheelbase cars. With the Mopar frame I'll have to build a front clip. Just want to try something on this one. Yes I know I spelled axle wrong ...
  2. Marty Strode
    Marty Strode
    The Ron Bizio Truck was changed from parallel front springs to 4-bar coilovers in 67. The axle had some drop. Bizio 3.jpg Bizio 4.jpg 2012-08-31 140633.jpg
  3. Mike Colemire
    Mike Colemire
    I never thought they looked as good but if I do another one I think it'll be coil overs.
  4. dearjose
    dearjose
    Check out Shirl Greer's Tension 65 afx dodge
  5. swade41
    swade41
    from Buffalo,NY
  6. swade41
    swade41
    from Buffalo,NY
    I know people with the setup but no clear photos
    Screenshot_20220903-195238_Facebook.jpg Screenshot_20220903-195434_Facebook.jpg Screenshot_20220903-195802_Facebook.jpg
    AHotRod, LOST ANGEL, catdad49 and 2 others like this.
  7. Marty Strode
    Marty Strode
  8. swade41
    swade41
    from Buffalo,NY
    Local truck for many decades
    AHotRod, VANDENPLAS and catdad49 like this.
  9. Hemi Joel
    Hemi Joel
    from Minnesota
    On my 31 Plymouth Coupe I used coil overs, along with a Superbell forged aluminum Ford style axle, with custom made chrome moly hairpins. It is VERY light compared to parallel leafs or a transverse leaf. Where the holes in the axle for the Ford spring perches are, just make up some brackets that mount the hair pins (or the 4 link bars) and the bottom end of the shock, bolted thru the holes.
    Then fab up some type of upper shock mount.
    I can post some close up pics later if requested.
    AHotRod, catdad49, iagsxr and 3 others like this.
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    My '33 Willys coupe has a 4-bar with coil overs.
    Seven degrees of caster is about the max limit for good street manners. I also used a (Fiero) steering damper to eliminate death wobble.
    Keeping the coil overs as close to vertical will reduce the spring rate needed.
    catdad49 and FunnyCar65 like this.
  11. flatheadgary
    flatheadgary
    from boron,ca
    if the attachment on the axle is a stud how do you adjust for caster?
  12. rod1
    rod1
    Please do?
    FunnyCar65 likes this.
  13. iagsxr
    iagsxr
    Heim joints on the four link bars.
  14. TRENDZ
    TRENDZ
    Most coil overs have ball swivels for travel angle changes.
  15. 1971BB427
    1971BB427
    from Oregon
    A coil over setup of course requires a panhard bar to keep it located, but they work well. If you're planning to go with a higher front stance, then I'd skip the coilover setup. They don't work as well as the nose gets higher, and often get a little twitchy at higher speeds. But if kept lower like most of the cars pictured above are, they will perform great.
  16. Hemi Joel
    Hemi Joel
    from Minnesota
    I'm sure there's people smarter than me who can come up with a better way, but this is how mine ended up:
  17. rod1
    rod1
    Great shots. Thank you.
