Ideas That Just Never Took Off
Discussion in 'The Antiquated' started by lothiandon1940, Aug 31, 2019.
  1. moparboy440
    moparboy440
    from Finland
  2. jimmy six
    jimmy six
    Plymouth tried in the 70’s …. Didn’t work then either.
    VANDENPLAS, lothiandon1940 and Deuces like this.
  3. Deuces
    Deuces
    Yep! Plymouth Cudas and Dodge Challengers...
    lothiandon1940 likes this.
  4. ccain
    ccain
    So... does this mean that, in a roundabout way, vinyl wraps are traditional? :rolleyes::eek::p
    I do like the "remove easily with aviation gasoline"part of the ad. :D
    "Aviation gas?!? Oh sure... I've got that around the shop somewhere. Lets see... hmmmm. THERE IT IS! Right next to my halftrack grease, under the big roll of zeppelin tape." :rolleyes::D
    Okie Pete, Rand Man, tommyd and 6 others like this.
  5. Wanderlust
    Wanderlust
    Plaid don’t work on nothin automotive, , like ******* on sheep, only works for a very small portion of the population (I believe/ hope)
    VANDENPLAS likes this.
  6. 51 mercules
    51 mercules
    VANDENPLAS, Deuces and lothiandon1940 like this.
  7. lothiandon1940
    lothiandon1940
  8. Oilguy
    Oilguy
    I used to have a p***enger side airbag. Could have used some of that Nervine stuff.
  9. lothiandon1940
    lothiandon1940
  10. lothiandon1940
    lothiandon1940
  11. jimmy six
    jimmy six
    That idea sort of took off. I saw quite a few in the 50’s.
  12. lothiandon1940
    lothiandon1940
  13. lothiandon1940
    lothiandon1940
  14. Mopar Tony
    Mopar Tony
  15. Bleach
    Bleach
    I once had a special tire pump hose that screwed into one of the spark plug holes. You ran the engine and it would fill a flat tire fairly quickly. It was noisy and would make the engine run rough even on a six cylinder. I imagine the tire could have a real blow out because there was fuel mixed in with the air.
  16. moparboy440
    moparboy440
    from Finland
  17. moparboy440
    moparboy440
    from Finland
  18. Deuces
    Deuces
    That^^^^^came out before the TV remote control...:rolleyes:
    alanp561 and lothiandon1940 like this.
  19. down-the-road
    down-the-road
  20. moparboy440
    moparboy440
    from Finland
    "Not recommended for Children under 6" :confused:
  21. Deuces
    Deuces
    Not recommended for anyone....
    lothiandon1940 and down-the-road like this.
  22. moparboy440
    moparboy440
    from Finland
  23. lothiandon1940
    lothiandon1940
  24. down-the-road
    down-the-road
  25. down-the-road
    down-the-road
  26. moparboy440
    moparboy440
    from Finland
  27. moparboy440
    moparboy440
    from Finland
  28. moparboy440
    moparboy440
    from Finland
  29. cjshaker
    cjshaker
    from Ohio
    Pulled this off my shelf for this thread. This goes way back, like to the later part of the 1800's. You know, when Coca Cola still had cocaine in it. o_O
    10% pure alcohol, and it says at the top of the label "USES - A remedy to be prescribed by physicians in treatment of alcohol addicts. Also as a female tonic in diseases caused by debility of the female genitalia"
    Old lady in a *****y mood? Give her Howe's Black Haw Compound. It'll calm her *** right down...lol
  30. moparboy440
    moparboy440
    from Finland
