Projects New Project - The 3B Speed Shop 34 Coupe
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Feb 12, 2021.
  1. primed34
    primed34
    Will motorcycle tire hold up to the side loads of a heavier car?
    Stogy likes this.
  2. DaveyJonez
    DaveyJonez
    from Houston
    Looks incredible! Quick question- did the roof insert change at all dimensionally around the perimeter after it was louvered??
    Stogy likes this.
  3. Jack Rice
    Jack Rice
    WOWZA!!!
    Stogy likes this.
  4. the-rodster
    the-rodster
    I guess we will see.
    I've seen these tires on some VERY expensive cars.
    Rich
    Stogy and Tim like this.
  5. the-rodster
    the-rodster
    Not that I noticed.
    It did add a lot of strength.
    Rich
    Stogy and DaveyJonez like this.
  6. I ran them on my old T and drove them HARD up in the twisties. Never had an issue.
  7. 2deuces64
    2deuces64
    Stogy likes this.
  8. NoSurf
    NoSurf
    Great work as always.
    Inspirational.
    Stogy likes this.
  9. B.A.KING
    B.A.KING
    DAmn, I don't know how i've missed all this. GREAT job Rich. you punch the louvers?
    Stogy likes this.
  10. Motorwrxs
    Motorwrxs
    So nasty looking…looks like it’s doing a hundred miles an hour right there in your garage!
    Stogy likes this.
  11. the-rodster
    the-rodster
    Yep, with a big hammer.
  12. just stumbled on this thread, super impressive work!!
  13. 2deuces64
    2deuces64
    Any updates???
    Jacksmith likes this.
  14. the-rodster
    the-rodster
    Bunches!
    Been too busy to post.
    Rich
  15. the-rodster
    the-rodster
  16. the-rodster
    the-rodster
  17. the-rodster
    the-rodster
    When I put the stock spring under the car, it was WAY too high. IMG_0322.JPG
    Stogy likes this.
  18. the-rodster
    the-rodster
    I made a jig and started de-arching each leaf in the pack.
    Rustridden31, brEad, Stogy and 2 others like this.
  19. the-rodster
    the-rodster
  20. the-rodster
    the-rodster
    I fabbed up the gas tank and battery brackets.
  21. the-rodster
    the-rodster
  22. the-rodster
    the-rodster
    I used three flatheads and three transmissions to get the parts that I needed.
  23. the-rodster
    the-rodster
    I'm using a 41 truck transmission, but it needed 34 type rear mount, and 34 type cross shaft and lever.
    Stogy and Thor1 like this.
  24. the-rodster
    the-rodster
    New flywheel, clutch, pressure plate, throwout bearing....
    brEad, Stogy, NoSurf and 1 other person like this.
  25. the-rodster
    the-rodster
    ****** fastened to the motor, new truck pumps, ready to go in..
  26. the-rodster
    the-rodster
    Time for the stock crossmember and frame horns to go.
    Kiwi 4d, Stogy and Thor1 like this.
  27. the-rodster
    the-rodster
    Starting the sweep and pinch.
  28. the-rodster
    the-rodster
    Trim and fit the new crossmember.
    Tim, brEad, Shadow Creek and 2 others like this.
  29. the-rodster
    the-rodster
    Motor mounts installed, mocking up the front axle.
  30. the-rodster
    the-rodster
