Technical Adapting 38 Ford truck frame to 32 roadster body
Discussion in 'Traditional Hot Rods' started by tankcmdr, May 8, 2022.
  1. My DMV could care less.
    Wear it out and post pics
    BamaMav and Okie Pete like this.
  2. Mo rust
    Mo rust
    Also, if you decide that you actually want to do this, Brookville roadster sells the front frame horns for a 32. I talked to them last week to see if they were available and how long they are so I can use them on a 32 frame that I'm working on. They actually only have one of one side in stock for some reason and none for the other side but they expect to have more available within a month. They are 20" long and run $105 for a pair. This might make your old frame look a bit more cosher.
  3. hotrodjack33
    hotrodjack33
    You will never get the correct "hot rod" proportions using the '35-'40 frame.
    If you notice, all Ford frames up to 1934 have the radiator mounted over the front axle. 0.48.jpg
    While the '35-'40 frames have the engine over the axle...leaving the radiator too far forward. 0.49.jpg
      92.8 KB
      492.6 KB
  4. sloppy jalopies
    sloppy jalopies
    memory says the '35 to '40 frames are about 4" wider than the A and '32s at the firewall area......
    the x member really can't be narrowed that much and still have room for the ******...
    lots of work to make the frame / x members fit the earlier body...
    you might get away with just using the rails and make your own x and cross members to the new width...
    draw a little print to see how what you want goes with what you have...
  5. Mo rust
    Mo rust
    We're using 35 to 48 X members on 32 frames but we trim them on the outside before welding them in. I think that's what he would have to do too and that's a lot of work to do to accomplish a piece of junk..
    I think I've tried things like this before and finally made a nice car out of it only to realize that I also still have the car that I started with and didn't use.
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    Sorry you aren't hearing what you'd like. It is not a good idea – but Florida as a whole will love it.
    Just Gary, X38, Happydaze and 2 others like this.
  7. chucka
    chucka
    Thank you, Kevin, exactly right
  8. flatout51
    flatout51
    Iron Trap put a T body on a 46 Ford ch***is. Cut it into pieces to make it look half way right. Anything can be done...
  9. hotrodjack33
    hotrodjack33
    Also, wheelbase isn't really the issue here. On the 2 pics (above), note the distance from the firewall location to the rear wheels . You would either have to shorten the frame AND torque tube, or lengthen the body a great deal.
  10. I'm an optimist, but also a realist. I don't think an A or '32 roadster body would look right on a later frame unless the frame was narrowed and the body was channeled. A high boy roadster would be hard to pull off with this combo. Furthermore, using stock cross steering from your ch***is can be difficult in the earlier bodies. The column must be as far forward as possible, just about where the V8 is living. The front axle is not ideal either. As far as the ***le goes, I'm sure there was a lot of 26-31 roadsters ***led as 32 trucks, fordors, tudors, and such. Back in the day, you ***led a car by the frame, engine, or transmission stamping, so who cares what's on the ***le. The bodies were NEVER ***led in the early Fords. If you can fab the frame and body to marry them together and you like it, then do it. But this will not be a bolt together project. Lots of cutting and welding in your future. That is my two cents. If you build it, post the build thread.
  11. junkman8888
    junkman8888
    As I've said before, the best use of that frame is to create a home-built sports car like shown in "Mechanix Illustrated".
  12. ClarkH
    ClarkH
    Sounds like your primary motivation in this is to avoid the ***ling process. Have you personally investigated the ***ling process in Florida? Nothing against your friend who had difficulties, but I'd want to know for sure before launching into a great big engineering work-around. Maybe his was an unusual case? Maybe he's not in Florida? I don't know, I live on the other side of the country. But I will say, I've heard many horror stories about the difficulty of ***ling, and yet I've done it twice. And it was much less of a headache than some of the frame/body contortions described in this thread.
  13. Laws are different everywhere, but here in Michigan, I can ***le a vehicle off the numbers on a frame, engine block, or transmission. If the roadster was ***led as a 38, wouldn't it just be considered a "Special"? I have ***led many of my projects from numbers and filed for lost ***les. There are ways. I guess my point is, I don't think its critical if the year matches the body. Most DMVs recognize that these Hot Rods are custom built anyway. It's just numbers that mean nothing to the person driving the car.
  14. hotrodjack33
    hotrodjack33
    I totally get it! You are not interested in building a car from scratch...you already have a running ch***is and WANT TO USE IT.
    My suggestion would be to find a '35-'36 Ford truck cab, hood and grill. (1-1/2 Ton would work), it should pretty much bolt on...and they look OK fendeless. Then find/build a pickup box to fit...as pickup boxes are not "wheelbase/wheelwell specific"
  15. Happydaze
    Happydaze
    Is there a limit to the modifications to a frame beyond which the original iden***y is lost for legal registration purposes?
    If no, start cutting and welding until the 38 frame closely resembles that of a 32.
    If yes, establish what is doable and whether you'd be happy with the results.
    In the UK pretty much any frame alteration (shorten, lengthen etc) results in the loss of registration and the presents the opportunity to re register after p***ing a difficult, some say impossible, and expensive test.
    I have a cat but really would like a dog. I can't get the cat to bark.
    Chris
    KevKo likes this.
  16. Each state is different in regards to ***le laws. In Michigan you can alter as much as you want as long as the original VIN# is still in the factory location. No inspections are necessary after the original vehicle is ***led. Some states require inspections on all new to you vehicles, especially if they are bought out of state. It is best to have a conversation with your local DMV. And some states require safety or emissions inspections. Michigan is pretty much a free for all. Cut and weld as much as you please.
    Okie Pete likes this.
  17. Some States, such as mine don't really care. Law Enforcement would rather see it ***led based on what it resembles; IE a 32 Ford Roadster regardless of frame. I have seen folks build a car around the chunk of frame with the Serial Number stamped n it.
    Haven Hills Auto Club likes this.
  18. nobby
    nobby
    put a 35/6 ford pickup body on it
    Outback likes this.
  19. 41rodderz
    41rodderz
    from Oregon
    Not true on the box not being wheelbase specific. 1) you don’t put an short bed on a 8 foot box frame or vice versa. 2) Model A’s as well as my ‘48 F1 have bolt holes and indentations at wheel section.
    Outback likes this.
  20. hotrodjack33
    hotrodjack33
    Agreed, some boxes are wheelbase specific. A '35-'37 Ford box would work perfectly...or, as I mentioned, just build a box. Built the box on my old '40 Ford PU in an afternoon.
  21. fuzzface
    fuzzface
    I know you wanted to modify the frame to fit but how about ******* off the purist and cut the body up and extend it to fit the frame instead? Hopefully you are a bigger guy and that will help in the argument. Hey, I am talking legroom here, keep focus.
    if bad chad can do it so can you or anybody else.
    ok, enough pot stirring, felt good, haven't done that in a while.
    anyways I know you wanted to build the 32 but have you thought about selling it? You might be able to build the truck for free depending how rough your 32 body is and what you get for it. I know I sold off a few things I really didn't want too but I was able to build something else without touching any other money sources.
    with that said, NO, the GTO and the Pheonix are not for sale for the guys that keep sending me messages. Those are 2 of the 4 that I am almost certain the estate will have to clear up, rest might be fair game on the right day but that day is not today.
    Outback likes this.
  22. finn
    finn
    I will probably get sent to band camp for this recommendation, but I would look into a set of 32 reproduction rails or a complete aftermarket 32 frame before using a 35-40 frame under a 32 body.
  23. wheeltramp brian
    wheeltramp brian
    His Name Escapes me right now but the owner of Circle City Hot Rods has a Model A coupe that he built years ago maybe his first hot rod that has a 35 to 41 frame underneath it I believe with the Hemi in it. It looks good but you can tell it's different
  24. Except Jimmy White has talent and didn't have to ask..........................
  25. Stole it off the internet. It looks to have a lot of cutting done to it to make it fit. Definitely not LEGOs. jwc2.jpg
    Outback likes this.
  26. wheeltramp brian
    wheeltramp brian
    Yep that's the one Jimmy White.
    Outback likes this.
  27. Kevin Lee
    Kevin Lee
    Super Moderator
    If my memory is still good with Jimmy's car that's not even a Ford frame. (Es***?)
    Now... just go do what you want – you're obviously set on it already.
    You should actually try to look up Florida Mike and see if he still has those plans for putting a later Pontiac sedan on a Model A swamp buggy ch***is. Just flip them upside down and you'll be on your way.
    alchemy, X38 and Tman like this.
  28. Mike
  29. BamaMav
    BamaMav
    from Berry, AL
    That sounds like a reasonable alternative. Look at the measurements on a larger car like a Lincoln or Packard or something. Then measure the frame and cut and fit until you have a "big" roadster. It won't be a 32 or a Model A, but more a custom roadster. You could mod an original steel car or fibergl***. Bet it would make folks scratch their heads...
    hotrodjack33 likes this.
  30. flatout51
    flatout51
    I REALLY hope he pulls it off and builds a *****in hot rod so everyone here throwing a fit has to eat crow.
