Technical Novice Question on King Pin Cotters
Discussion in 'Traditional Hot Rods' started by 66Coronet440, Sep 8, 2022.
  1. 66Coronet440
    66Coronet440
    I was mistaken on that. It has a repair of some sort, but isn't dropped.
  2. RICH B
    RICH B
    If your axle has 2" perch bosses; it is probably a '33-'36 not a Model A.
    Easy to add a shim washer between the yoke and bottom of the axle.
    I usually cut a hole in a piece of 1/4" plate with a 1-1/2" hole saw, smooth the edge of the drop out, and drill the center out to 11/16". Looks better than the commonly used pair of 3/4" flat washers.
    Kelly Burns and Budget36 like this.
  3. 66Coronet440
    66Coronet440
    Yeah, it may be. It appears to have been narrowed at some point. Apologize for the paint; it will be resprayed black if used.
  4. Nice! I may have to "borrow" that idea!
  5. RICH B
    RICH B
    ^^^^ '47-'48 axle, with the perch bosses milled down in height. Narrowing not so good.
    Seems it would be worthwhile to build up around a suitable axle
    X38 likes this.
  6. hotrodA
    hotrodA
    Ditto on the 46-48 axle ID.
    33-36 Axle cores are relatively cheap. That narrow and weld job would persuade me to change it out.
    X38 and Kelly Burns like this.
  7. 41rodderz
    41rodderz
    from Oregon
    Just going to say it. It is not a cotter pin .:oops:
  8. gimpyshotrods
    gimpyshotrods
    It is, and it is not.
    The exact same thing on a vintage bicycle crankset is indeed called a cotter.
    https://www.sheldonbrown.com/cotters.html
    Google the term: "split pin" and post a picture of what you find.
    williebill likes this.
  9. gimpyshotrods
    gimpyshotrods
  10. X38
    X38
    Whether the cotter could engage or not, I'm glad we got to the bottom/reality of the axle situation! And that's a good thing.:)
  11. 66Coronet440
    66Coronet440
    I used to work on old bikes with those, which is why I call them cotters. I think I met Sheldon at Harris Cyclery back in the day.
  12. gimpyshotrods
    gimpyshotrods
    He built wheels for me, back in the day.
    66Coronet440 likes this.
  13. 41rodderz
    41rodderz
    from Oregon
    Specifically speaking , we are not talking bikes and this discussion is USA slanted not other countries relative terms. :D So I am rightfully right .:p But I would be incorrect if I was drinking a pint in England and discussing bikes , babes and beam axles.:D
  14. X38
    X38
    So, what are you calling it?
    gimpyshotrods likes this.
  15. 41rodderz
    41rodderz
    from Oregon
    More important is getting him safe . So get your cotter issue fixed as I add some semblance of culture added to aid my refinement .:)
  16. 41rodderz
    41rodderz
    from Oregon
    Lol I am not cultured enough to be a hoodlum here.:D
  17. 41rodderz
    41rodderz
    from Oregon
    A retaining pin/ stop bolt etc. As I said I am not cultured, so I didn’t know it was automotive term in Ol’ England.
  18. Ducbsa
    Ducbsa
    from Virginia
    FWIW, Bratton's calls them locking pins.
  19. RICH B
    RICH B
    Green Book says "B 3122 Pin (spindle bolt locking) 28-48".
  20. 66Coronet440
    66Coronet440
    I think "locking bolt" is the preferred nomenclature.
  21. The37Kid
    The37Kid
    I like that, Ford used a long nut on the back of them that acted as a steering stop, do the repro parts include them? Cotter pins are the UK version of split pins IMO. Bob
  22. Maybe so, but they have different words for EVERYTHING: boot, bonnet, wings (fenders), dynamo (generator), chips (French fries), the list goes on. AND.... they drink WARM beer!!
    Oh.... and they drive on the wrong side of the road!
  23. X38
    X38
    In my world:
    Split pin:
    Cotter pins:
    A Ford type pin or locking bolt also has a raised tang or key to engage the king pin.
    Happydaze, gimpyshotrods and The37Kid like this.
  24. williebill
    williebill
    The late, great Sheldon Brown discussed on the HAMB.
    I've seen everything now. (I'm in the bike biz). Carry on.
    66Coronet440 and gimpyshotrods like this.
  25. Dan Timberlake
    Dan Timberlake
    https://www.jalopyjournal.com/forum/attachments/pxl_20220909_191233992-jpg.5507757/
    Maybe it is just the camera angle, but the parting line looks to be mighty thin, suggesting the axle is a casting.
    Generally speaking when vintage parts like axles and con rods were forged the forging dies didn't t close completely and a bunch of metals oozed out all around the edge. The excess was removed quickly by grinding or shearing.
    Here is a picture showing the wide band left after removing the forging flash on axles .
    https://www.undiscoveredcl***ics.com/wp-content/uploads/1972_June_Street-Rodder_005.jpg
  26. RICH B
    RICH B
    Some kingpin kits used to include them; they were the same length; but smaller hex than Ford stop nuts. Recent kits just have a plain hex nut.
    Definitely a late '47-'48 original Ford forged axle.
    No Chinese cast mystery metal repops of those axles.
  27. Ducbsa
    Ducbsa
    from Virginia
    Bratton’s kit has the long nuts.
    The37Kid likes this.
  28. Just find a good 33-36 original Ford axle and have it dropped by Sids, Ansen or someone else on here, get them to also drop the steering arms on a set of original round back spindles, have them install a new king pin set at the same time. It's pricey but will last you forever and be safe, this way you can mock up and build with what you're going to use.
  29. The37Kid
    The37Kid
    Took a while buy I found a pin and long nut. That spot faced area on the spindle is were the two touch. DSCF0167.JPG DSCF0168.JPG DSCF0169.JPG
