SOLD!!!!!!!!!!! Up for sale is my 31 full fendered Deluxe Roadster. Clean ***le in my name. Needs nothing just a new owner. Health issues have moved the sale up sooner than I expected. The build was detailed very well here on the Hamb. It was two years in the making sourcing all steel sheet metal with no patch panels or rust. The patina was the theme here to have a look of a 50's build just pulled from the barn. Hours were spent sourcing parts with actual patina if I could find them. Aging acid and chemicals helped a lot. Like I said no detail was over looked. Every nut and bolt. If that is not your thing this car is not for you. It's a driver and not a shiny trailer queen. Ford 1931 Model A Deluxe Roadster all steel Model A frame 40 banjo rear 3:54 gear No noise! Late 1936 3 speed. No noise! 4" dropped front axle 40 spindles, brakes, mc torque tube. Ford 16" 35 wire wheels and original hub caps. Firestone 7.00x16 and 4.75x16 new tires. Split wishbones Hyd shocks all 4 corners. Lowered as low as possible. 51 F1 steering gear box tight. Full 12V vintage Stewart Warner gage package including fuel level gage and Sun football tach that works like it should. 38-39 banjo steering wheel. 1953 Ford Flathead 8ba professionally built by NASCAR legend Rich Bickle Sr. 276" Merc 4.00 stroker .010/.010 3.312" bore SS valves adjustable lifters(Isky) Regrind L100 cam Eddy heads and offy 3x2 intake Full functional original Stromberg 97's that don't leak! Progressive linkage. Mallory/ Petronix dizzy Custom built lake headers with baffles. Not for the faint of heart. Custom copper/br*** model a radiator for a 8ba flathead necks. Super cool unit never overheats. Will run 65 mph all day long. LED/ halogen lighting, Signals etc. Comfortable bench seat with fold down access. Trunk mounted battery/ gas tank, tool bag, and fire extinguisher. A top is available with oak bows and header. Chrome side irons with rear window frame Enjoy!
