Hot Rods B&M Hydro transmission help to identify
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Jan 9, 2020.
  1. steven e ryder
    steven e ryder
    Picket up this B&M Hydro and plan to adapt it to a 392 Hemi.
    So far I think it was a 57 Chevy truck core and the UC to the right is unblown comp.
    I have a Wilcap adaptor plate for Hemi to Chevy but need to find or make the crank shaft spacer.
    Does anyone make these anymore? Can I re-drill the Torus plate for 8 hole pattern with a machined spacer and gasket?
    Saw the earlier pictures of the B&M Hemi bell and Torus and wondering if I can get there home grown with a very skilled friend and his Bridgeport.
    Reading all the posts I can find on these transmissions but still feel like the guy who slept in the Holliday in Express last night.
    Any info and opinions are much appreciated.
    Deuces and elgringo71 like this.
  2. steven e ryder
    steven e ryder
    Deuces likes this.
  3. drumyn29
    drumyn29
    i have an adapter
    Deuces and steven e ryder like this.
  4. d2_willys
    d2_willys
    from Kansas
    I have seen adapters for Hydro to Hemi. They probably use the "back" bell housing from either Olds or Pontiac, then provide the "front" adapter bell housing. A crank adapter will also be needed.
    I don't think you can go wrong with either hydro motive or B&M. The only issue is that the B&M looks pretty rusty, meaning that the insides are probably stuck too.
    I am in the process of grafting a hydro to an extended bell 331 hemi. It is much easier as far as an adapter, being it is a plate that accepts the "back" bell housing, then gets bolted to the extended bell housing of the hemi. It will use the hydro flywheel, which will couple to hemi flywheel using an adapter. Starter is hemi, so no adapter needed.
    Having an extended bell housing engine block makes adapters for the hydro much easier to produce. I am also grafting the hydro to Buick nail head, and Packard 374. Both have extended bell housings. Again, these will have hydro and engine flywheels. Starters are from engine manufacturer.
    Both B&M, and Hydro Motive used the slant pan type hydros, since they were the strongest. Another company that did the adaptations was C&O, that I believe was in the Los Angeles area. If I were to do something similar to what you want to do, I would use an R54, R55, or R56 hydro. The valve body was equipped to start in First gear in any of the ranges. The Pontiac hydros started in 1st only when in DR4 or DR3. Lo range started in 2nd.
    Other information: Olds transmissions had a very wide 2nd to 3rd ratio, thereby dropping RPMS during that shift. Pontiac transmissions had a tighter 2nd to 3rd ratio, and also had a very lo 1st gear compared to Olds.
    Deuces and bchctybob like this.
  5. drumyn29
    drumyn29
    hydromotive is going in my willys
    IMG_0883.jpeg IMG_0884 2.jpeg IMG_0886.jpeg IMG_1103 2.jpeg IMG_2940.jpeg IMG_8353.jpeg
    Deuces, elgringo71, warbird1 and 4 others like this.
  6. drumyn29
    drumyn29
    Deuces, elgringo71, bchctybob and 3 others like this.
  7. rod1
    rod1
    Who rebuilds those today? Cool stuff!
    Deuces likes this.
  8. mgtstumpy
    mgtstumpy
    Great old resource if you can locate one, an unobtainium paperback these days! Mine is packed away and not readily accessible. I had a breakdown of B&M hydros but can't seem to locate it.
    Deuces, bchctybob, rod1 and 1 other person like this.
  9. dirt car
    dirt car
    from nebraska
    I have a B&M built C-4 in my 32 Sport Coupe that was equipped by the previous owner, when it came time to service fluid & gather gaskets etc. I called B&M proper with tag info.to verify fluid type, probably caught the rep at a busy time didn't expound beyond telling me to use type 'F' this is typical for Ford units by build date.
  10. drumyn29
    drumyn29
    I am going to have my B&M hub for my 392 replicated/machined so I can have a few extra, does anyone know where to find this br*** pilot bearing?
    Deuces likes this.
  11. drumyn29
    drumyn29
    I'm just using my local trans guy, not a lot of choices these days.
  12. steven e ryder
    steven e ryder
    Summit Racing
    National Bearing Pilot Bearings NNTPB656HD
    4.75 out of 5 stars ( 7 )
    Part Number: NTL-PB656HD
    Estimated Ship Date: Today
    $9.99
    Brand:
    National Bearings and Seals
    Manufacturer's Part Number:
    NNTPB656HD
    Part Type:
    Pilot Bearings and Bushings
    Product Line:
    Summit Racing Part Number:
    NTL-PB656HD
    UPC:
    724956022137
    Pilot Bushing Type:
    Solid
    Pilot Bushing Material:
    Br***
    Outer Diameter (in.):
    1.094 in.
    Inside Diameter (in.):
    0.594 in.
    Width (in.):
    0.750 in.
    Quan***y:
    Sold individually.
    National Bearing pilot bearings provide you with a job done right. Their quality bearings will replace your worn-out pilot bearings with an OE fit and confidence. National anti-friction bearings are precision-made to keep your transmission and clutch aligned for trouble-free operation. Bearings wear out--replace them with National pilot bearings.
    Deuces and rod1 like this.
  13. drumyn29
    drumyn29
    cool, thank you. I spoke to my machinist and I'll drop this sample off on friday, he's very quick.
  14. steven e ryder
    steven e ryder
    M5, M5A1 Stuart... Tank Hydro
    On Ebay now, I thought someone might like to have it!
    Deuces likes this.
  15. bchctybob
    bchctybob
    Wow, hard to believe that big old lump has survived all these years in its original box. Looks good.
    Deuces likes this.
  16. drumyn29
    drumyn29
    MAN thats cool!
    Deuces likes this.
  17. drumyn29
    drumyn29
    I emailed Mark Williams today and they can make the yolk, I ordered one today and I will have it in about 3 weeks. Here's the part number if anyone needs.
    Deuces likes this.
  18. drumyn29
    drumyn29
    Torus looks like it's in good shape.
    Deuces likes this.
  19. bchctybob
    bchctybob
    I don’t see any brazing material around the tabs, are you going to open it up and check the vanes?
    Good info on the yoke, thanks. Mark Williams is great. They keep amazing records on everything they do, even one-offs. When I needed bearings and seals for my Austin I called and gave them the number off of the axles. He looked them up and could tell me everything about them. I think they were made in like 1970, iirc. Shipped me the right stuff, right away. They did the axles for the narrowed Olds rear end in my roadster too.
    Deuces likes this.
  20. drumyn29
    drumyn29
    I'd like to check the vanes, is it early easy to open it up?
  21. bchctybob
    bchctybob
    Just unbend the tab on the main shaft nut and take it off. The outer torus wheel will slide out easily. There’s a big spring in there pushing it out. IIRC, there is a snap ring holding the inner wheel in. Keep any thrust washers in order and surfaces in order. The front seal rides on the snout of the torus cover (the big bowl). You may want to replace the front seal while you’re in there and inspect the sealing surface of the snout.
    The compe***ion units usually have furnace brazed vanes but there are exceptions. Br*** has been flowed between the vanes and the body and usually shows around the tabs on the back.
    I’ll be getting into mine very shortly but it’s been years since I messed with one, don’t remember the torque value. Good old Motor Manual should have it or one of our resident experts, maybe willys36 or Speedy Canuck?
    Deuces likes this.
  22. Will pull my manual this evening and circle back ;)
  23. drumyn29
    drumyn29
    My machinist asked me to help him last night. We worked on these adapters until about 1:00am. I only needed one but decided to make a few extra in case someone else needs one. Pretty much impossible to find this obscure coupler that connects the Hemi to a Hydro transmission.
  24. drumyn29
    drumyn29
    ARE ALL HYDRAMATICS THE SAME FLYWHEEL?
    Mine has a worn out spot in the teeth.
  25. bchctybob
    bchctybob
    I believe all of the Oldsmobile hydro flywheels are the same. The Chevy version is a smaller diameter with fewer torus cover bolts. The Pontiac, Cadillac, Lincoln, etc will have different crank bolt patterns.
    Deuces likes this.
  26. bchctybob
    bchctybob
    Don’t toss the damaged one, I’ve successfully welded and filed the teeth in a pinch.
    Deuces likes this.
  27. drumyn29
    drumyn29
    So have I!
    I thought about doing that but it seemed half ***ed, maybe I should re consider welding it.
  28. bchctybob
    bchctybob
    The days of going to the parts store or the dealer and ordering a new one are long gone, same with just hitting the local boneyard for one. Sometimes you gotta do what you gotta do. Since we don’t drive these old things everyday like we used to, a repair like that lasts a bit longer. I got one off of eBay some time ago for $30-35 and it was perfect but they will continue to get harder to find each year.
    Deuces likes this.
  29. Charles L Coker
    Charles L Coker
    That's not a UC after the P55, on the right side of the B&M tag is where the transmission is ID as SS, = strip/street version. I have a unblown compe***ion Hydro Stick, and the UC is stamped on the right side. FB_IMG_1675226918720.jpg FB_IMG_1675226918720.jpg
    rod1, Deuces and elgringo71 like this.
  30. pontiac1953
    pontiac1953
    from missouri
    Sorry, but the P55 Hydro Stick transmission is coded SS, that stands for Street/Strip version of the Hydro Stick transmission, I own a 54 Oldsmobile slant pan that B&M made into their Unblown Compe***ion Hydro Stick.
    Speedy Canuck likes this.
