Technical Anybody running Hoosier 7” vintage slick 18950
Discussion in 'The Hokey Ass Message Board' started by Roadsir, Sep 12, 2022.
  1. Roadsir
    Roadsir
    These are the spec tire for the SEGA super stock cl***. I bought a pair for the 40, curious on air pressure ( awaiting a call back ).
  2. Junior Stock
    Junior Stock
    I just put some of these on my 57 Chevrolet sedan delivery Junior Stocker and ran 24 lbs. in them with no problem. This is a 3300lb. car with a 220hp 283 and a powerglide with a 4.88 gear.
    Roadsir likes this.
  3. Roadsir
    Roadsir
    Hey thanks for the reply! I did get a call back from Hoosier. They recommended 9-12lb. Lower than I thought. Right now I have them aired up to about 16lb and did a quick hit in the driveway to get the nubs off and the pattern looked fairly even. So I think I might start there and drop it from there.
    I should be right at 3000lb, 450hp 410, Super T-10 and 3:90 gear.
  4. ironandsteele
    ironandsteele
    I have run them as low as 10 pounds. I usually start at 15 or so and work my way down, depending on conditions.
    ironandsteele.com​
  5. squirrel
    I have similar size M&H on my Chevy II, I run 20 lbs in them...M&H says to start high and drop if it spins, mine hook, so I run them that high. Helps handling too...it's pretty sketchy at lower pressure. Being altered wheelbase might have something to do with it.
    bobss396 likes this.
  6. Roadsir
    Roadsir
    Thanks, that quite a range how do you like them? I'm hoping a lot better than towel city recaps. They seem soft....and light.
  7. 51box
    51box
    from MA
    I also have the M&H version and run them at 22psi but I’m probably 100hp less and car weighs 2,400lbs stick shift.
