Technical 1959 Buick Steering column Horn Issue
Discussion in 'Traditional Customs' started by 1959Buick, Sep 14, 2022.
  1. 1959Buick
    1959Buick
    from BC Canada
    Hello from Canada.
    how does the horn wire in a 1959 Buick works. On my car the horn is on all the time. I belief I have a short in the column. Does anybody REBUILD a 59 column and has picture?
    Thanks for any help
    Herbert
  2. goldmountain
    goldmountain
    First off, you need to determine if the problem is in the steering column or not. Find the horn relay. Should have three wires. Disconnect it and place a test light from the hot wire to the one that makes it light up. That would be the one going to the steering column. Disconnect the plug at the steering column. If the light goes out, the problem is in the steering column. If it stays on, the problem is in the wiring harness. If it is in the steering column, you need a steering wheel or harmonic balancer puller to remove the steering wheel to further examine the problem. Good luck.
    vtx1800 likes this.
  3. vtx1800
    vtx1800
    I'd advise you to take the horn ring off (don't ask me how yours works...many you just push in and turn a bit and the lugs let go) and see if you see a wire that is abraded and grounding. I just completed marrying a 58 Pontiac upper portion to a 61 Studebaker lower portion (I had a space issue for the transmission lever on the T it is going in) and the columns are really pretty simple once you figure out they aren't magic inside:) Just take pictures as you go, I don't have a photographic memory..those pictures really help!! You might want to purchase the shop manual, I bought both the shop and parts manual when I built my Studebaker and it saved me a lot of headaches.
    Good luck!!
    Edit...@goldmountain gave you better diagnostic advice than I did..he was typing at about the same time:)
  4. squirrel
  5. 325w
    325w
    The horn wire may be like the tri fives. It has a br*** ring at the top of the column. Press the horn the contact is made. If the wire has broken loose from the br*** ring it will honk all the time if it’s grounded. Get the shop manual to go after the wire. I have found several tri fives that broke this way. If this is the problem and you can’t find one for the Buick look at the tri five it could work.
  6. 1959Buick
    1959Buick
    from BC Canada
    Thank you for all your help. I forgot to mention that I checked the relay and removed the steering wheel. I have to work in the next 3 days and I will take your advice and check the electric again. I restored 2 steering columns from GM cars from the 70"s , but the 59 Buick is different. I will upload 3 pictures The horn wire comes out in the center of the steering shaft. On the lower end of the steering shaft is a switch with a contact to a br*** ring inside the shaft. I belief Cadillac did have the same setup. so how the the wire connected to the br*** ring?
  7. vtx1800
    vtx1800
    Studebaker used the hollow steering shaft also. Looks like you are on the right track!!
  8. 1959Buick
    1959Buick
    from BC Canada
    So how does the wire runs in the shaft?
  9. 327Eric
    327Eric
    It runs down the shaft and comes out the steering box. On a 59 Buick it is brown
  10. goldmountain
    goldmountain
    Hopefully, the problem lies in the harness before the steering column. Pinched wire,easy fix. Somehow, I doubt that. I'm from the 70's street rod era where we ditched the old steering columns for fancy tilt columns so I'm of limited help. With the wire coming in from the bottom of the column, it would need a brush type contact to overcome the problem of a steering wheel that rotates. That would be that br*** cylinder in your picture. The spring loaded contact would need some sort of insulator to keep it from grounding out and honking the horn. Start looking there. You probably will have to fabricate parts.
  11. 1959Buick
    1959Buick
    from BC Canada
    Thank you for your help. I wish I had pictures of the parts in the steering.
  12. BJR
    BJR
    The wire goes inside the steering shaft and is soldered to the br*** ring, which is on top of an insulator to keep it electrically separated from the steering shaft. The steering column tube has a spring loaded wiper that rubs on the br*** ring with a connector on it.
  13. i7083
    i7083
    I used Willys Jeep parts when I made my column. They used the br*** ring and wiper set-up.
  14. 1959Buick
    1959Buick
    from BC Canada
    Thank you BJR
  15. 1959Buick
    1959Buick
    from BC Canada
    Good to know. Thank you
