Projects Achievable Pre-War Supe Job Build
Discussion in 'Traditional Hot Rods' started by RyanAK, Sep 17, 2022.
  1. RyanAK
    RyanAK
    We’re finally starting.
    Watch this space…
  2. SUHRsc
    SUHRsc
    Hell yea!
    RyanAK likes this.
  3. RyanAK
    RyanAK
    A while back I started a thread asking about a pure and achievable pre-WWII build. That thread went on for 5 pages and is filled with superb advice that builds confidence that a guy can get a traditional car built.
    ACHIEVABLE PRE-WAR BUILD
    So now is the time. Late Thursday night I rolled into my central PA home with a running Model A ch***is and a loose plan. Let’s see where this goes.
    A64A62AE-57DD-400B-B37A-B20C69D4F62E.jpeg 6400E073-4725-4276-907E-9CADC5A6C355.jpeg
  4. RyanAK
    RyanAK
    A few more views of the starting point. Motor sounds strong.
    1555680C-863C-4911-852D-B9DEBCEA27A2.jpeg 2447607B-88C2-4578-AABC-B1D7DCC63AFC.jpeg 3FE49DEF-5DAF-4381-9EB7-B3EA54F3883E.jpeg
    duecesteve, Jdmcrx, OzMerc39 and 29 others like this.
  5. Mikko_
    Mikko_
    from Sweden
    I'm in, looks like a great start.
    Stogy likes this.
  6. Rand Man
    Rand Man
    Keep at it, a little bit every day.
    Stogy likes this.
  7. You need one of these cam covers!
  8. RyanAK
    RyanAK
    Thanks, fellas. Right now the only plan is an open car on an A ch***is with a 4.
    The 4-cyl starts and runs strong. Water pump needs rebuilt or replaced. Fuel tank needs confirmed that it doesn't leak and then fuel shutoff/sediment bulb procured, installed and plumbed to carb. Choke rod needs installed, but this will be back burner since I plan on running a downdraft. Cowl is solid, firewall is a bit hacked up. Steering column quadrants need gone through. Needs shocks - there aren't any. This thing is actually set up with juice brakes (backing plates and drums... not sure on internals yet) on all four corners, but not piped and no master... which is good since I want to run mechanicals on this car.
    Lots for Spencer and I to do with just a ch***is. For those who may not have picked up on my other threads, Spencer is 7 and on the Spectrum. He's brilliant and p***ionate and when he discovered you can build a car from basically nothing, well... we just gotta, don't we? Nora has a hot rod heart. The ever fetching Mrs. RyanAK does not want to go 100mph (Spencer's stated goal) in ANY car... especially a Model A-based jalopy.
    This should be Spcl. :cool:
  9. RyanAK
    RyanAK
    Brother, I need a lot of things! Mostly education. I don't even know where that goes!
    Sharpone, sko_ford, BrandonB and 3 others like this.
  10. trevorsworth
    trevorsworth
    Take that air filter off for 10 free hp. No joke.
    Sharpone, Outback, Okie Pete and 3 others like this.
  11. Hitchhiker
    Hitchhiker
    Did someone say Pre-war?
    Sharpone, sko_ford, Outback and 6 others like this.
  12. RyanAK
    RyanAK
    Why, yes. Yes I did. And... that was fast! I was expecting ya to show up... but that was fast. You got some sort of secret coconut telegraph going that gives you alerts?
    Sharpone, 41 GMC K-18, brEad and 5 others like this.
  13. Hitchhiker
    Hitchhiker
    Smoke signal based.... but same idea.
  14. Watchin’…
    Stogy and winduptoy like this.
  15. RyanAK
    RyanAK
    In other news… once this jalopy is on its way, I’m considering finding a new home for the Olds and dailying an A Tudor. Your pickup thread lent a lot of credence to that idea for me. I’ve had such fun with the Olds, thought I’d give something a bit older a go.
  16. RyanAK
    RyanAK
    Hello, friend. I do remember your advice. Gearing and the horsepower to compensate! :cool:
    Sharpone, Okie Pete, Stogy and 2 others like this.
  17. RyanAK
    RyanAK
    Oh yes. Eventually that Zenith and intake will get swapped out when we start hopping things up a bit.
  18. RyanAK
    RyanAK
    Going to need to address the electricals sooner than later…
    And the firewall…
  19. RyanAK
    RyanAK
  20. Ducbsa
    Ducbsa
    from Virginia
    Get a 6:1 head and Mitchell overdrive.
    Sharpone, Stogy and winduptoy like this.
  21. RyanAK
    RyanAK
    6:1 is on the build sheet and I'd love input. Mitchell isn't in the budget unless I find one attached to a $50 swap meet torque tube. Maybe when I sell the Olds and build a daily a Mitchel will come into my life... Eventually.
    But a head is certainly something I could use input on for this prewar car.
  22. RyanAK
    RyanAK
    I guess I'll post the general 'recipe' for the banger:
    6:1 Head of yet to be determined design
    'B' Distributor
    Downdraft intake and carburetor of yet to be determined design
    How's that for simple and non-descript? ;)
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Good to see you back in action on this project. Congrats on the ch***is! The engine sounds great. If I were you, I'd focus on the body, ch***is and brakes before diving into speed equipment. I know how detail-oriented your previous projects have been, so this one is going to be very fun to follow. Keep up the good work!
  24. RyanAK
    RyanAK
    Thanks, man. If it’s half the car and community you’re building, we’ll have a grand time. Now that I know the banger will run we’re diving into the suspension and brakes. This thing has juice drums and backing plates, so it’ll be sorta different to be backdating to mechanicals. Ha!
  25. Hitchhiker
    Hitchhiker
    May I suggest 32 brakes if you're going that route?
    Sharpone, Outback, Stogy and 2 others like this.
  26. hfh
    hfh
    from Western MA
    Looks like a lot of fun.
  27. RyanAK
    RyanAK
    You can! Educate me.
    I also need to get around to writing up my philosophy statement so everyone that checks in here knows what I’m trying to accomplish.
  28. Hitchhiker
    Hitchhiker
    It's a pretty easy swap. But will net you cast iron drums, and much less brake fade. 11 vs. 10 inch brakes as well. I might have enough to put together another set. But shipping would be killer!
  29. nrgwizard
    nrgwizard
    from Minn. uSA
    Good start.
    Marcus...
    Sharpone and Stogy like this.
  30. harpo1313
    harpo1313
    from wareham,ma
