Technical Steering Arms
Discussion in 'Traditional Hot Rods' started by 66Coronet440, Sep 18, 2022.
  1. 66Coronet440
    66Coronet440
    I am putting a drop axle together and have a question about steering arms. I am using Speedway spindles with '40 outers, and have to buy steering arms. These are cheap ones that I'm mocking up, but looks like Super Bell copies. Anyway, they don't fit. Do I need the CE bolt-through style that drop down from the spindle?
  2. RICH B
    RICH B
    I have used CE arms several times with no problems. I like the fact the bolts go thru instead of screwing into a blind hole. May not be as "pretty" as some arms; but I think they are next best thing to bending stock arms.
    LSGUN, olscrounger and Kevin Ardinger like this.
  3. Hitchhiker
    Hitchhiker
    I don't know what the answer is, but I had that same fitment issue with a set of bolt on arms I tried out.
  4. big duece
    big duece
    from kansas
    Hair pins or wisbones? The So Cal dropped arms are through bolt and have a couple options . gt2_front_deep_spindle_arms_b.jpg
    olscrounger likes this.
  5. krylon32
    krylon32
    from Nebraska
    It's a combination of the Chinese spindles and arms. I've struggled with this problem many times with aftermarket spindles and arms. I still like the thru bolt steering arms versus the blind hole arms. I get my arms from Roadster Supply. I suspect they're still made overseas?
    seb fontana and olscrounger like this.
  6. 66Coronet440
    66Coronet440
    Wishbones.
  7. big duece
    big duece
    from kansas
    I believe these are 37-41 wishbones with tie rod to travel underneath bones... Socal dropped arms. 2014-12-23 23.08.08.jpg 2014-12-23 23.08.23.jpg
  8. 66Coronet440
    66Coronet440
  9. dana barlow
    dana barlow
    from Miami Fla.
    After market arms,can be handy,but many are designed an made too work=ether way, front steer* or rear steer*,an have zero built in Ackerman :(. They sell that ;with out telling you:mad:,an keeps them from having 2X as many instock.= Not really very good to use!
    Except if you fit/bend/adjust* them ,so the way you do use them, gets something close to good Ackerman. It is wroth doing it right,an not just bolt stuff together.
    If don't know what I just said,take the time to read up and learn about Ackerman.
    https://en.wikipedia.org/wiki/Ackermann_steering_geometry
    rpm56 likes this.
  10. Fordors
    Fordors
    I’ve used plenty of early V8 spindles but on a project I’m doing instead of cutting off the steering arms I bought Speedway spindles fitted with king pins. The forgings look great and dimensionally they are the equal of Henry’s parts. I’ll be using Super Bell steering arms.
    Regarding the arms the OP has even if the bolt holes did line up the snag grinding to remove the forging flash is heavy handed and has plenty of stress risers. Quality parts can and do come from overseas but those steering arms are not in that category.
  11. 66Coronet440
    66Coronet440
    These things are definitely cheap ****. I was planning to buy Super Bell arms, but I'm leaning towards the P&J now.
  12. 31Apickup
    31Apickup
    What wishbones are you using?
  13. 66Coronet440
    66Coronet440
  14. Illustrious Hector
    Illustrious Hector
    I'd look for bones from a '30s car, beefier. You want bolt through arms, I ran the blind ones when I first built, after a thousand miles or so, they kept backing loose and wobbled.
    big duece likes this.
  15. dmar836
    dmar836
    If backing out, safety wire would be in order BUT my bigger opinion is(and no offense to the SR crowd) this is what happens when using multiple catalog parts.
  16. 66Coronet440
    66Coronet440
    I bought the P&J/CE arms. I think the only catalog items I'm using are the spindles. The drop axle is believed to be 70's era, and at least as heavy duty as a Ford axle.
    dmar836 likes this.
  17. dmar836
    dmar836
    So what did you ultimately do?
    D
  18. dirt t
    dirt t
    I used Pete & Jake's.
    You can not beat the quality.
  19. When I see those really smooth designs from Speedway and So-Cal, I have a really hard time believing they are forged - they sure look cast to me. So-Cal does not list the manufacturing process - while at Speedway the 1 3/4 drop arms are listed as forged, while the 3 3/4 drop arms do not mention forged . . . Hmmmmmm? Does anybody have the details/answers on forged or not - from what supplier? The Super-Bell ones from P&J are obviously forged.
